So today I was inspecting my radiator hoses to see if they were creeping off... (they weren't)
BUT I noticed a wet oily spot about the size of a nickle under what I "assume" is the weep hole for the water pump. It's on the bottom side of the pump housing up toward the front.
I cleaned it all up and will just keep an eye on it and see if more oil appears.... might just be left over from the machining and assby process...
But ... of course I wondered if anybody else had noticed something similar?
A common design on water pumps is to have an air gap between the waterside seal and the engine drive/oil seal. This is to ensure that a seal failure results in water leaking out of the hole rather than into the engine.
As you say it could just be residual assembly oil having run out. If it continues it's more likely to be the engine side oil seal failing.
Time will tell.
Yep - I had the water-side part of the seal fail on mine. When the engine got good and hot it leaked coolant out the hole.
Was fixed at the 12k service when they introduced the post valve check cam cover oil leak - I'm sure they do that just to prove they had the cover off..... might fix that one myself over the winter.
Gezzzzzzzzzzzzz I realize these engines are NOT the easiest thing in the world to work on for what the shop is charging for labor rates.................
I'm really having trouble figuring out how engine oil could make it to the weep hole.... but the pictures in the manual really don't have a good shot of the view that would be needed....
On the Funduro was it the "water side" seal or the "oil side" seal that failed...
I guess there are the pair of o-rings around the outside of the pump with hole in the middle?
Maybe that is what drains down to the weep hole???
And then whatever seal exists around the driveshaft its self ...
The first diagram shows a cut out just below where bolt 1 screws in. This is, I believe a drain channel from up behind that black rubber or plastic disc and where the oil would come from.
If that part held in by bolt 1 was removed you'd see the seal after the engine side bearing. This seal is the one that would have failed.
The two seals indicated on the second diagram are water retaining seals not oil.
It looks like there is an air gap, as expected, between the water seals and the oil seal and it's that chamber that is vented via the drain hole.
Fortunately I never had a water pump failure on my bike, but my recollection from reading all of the complaints about water pump failures was that the water side failed and water would start dripping out of the hole. When the pump was removed the seal and pump vanes would be found to be worn out. It must have been a set of bad pumps from the manufacturer.
My only failure was the steering head bearings. They went out within 8K miles. When I had them replaced under warranty, it was found that the grease had run out of the bearings due to using grease that could not take the heat from the aluminum frame. Of course the quality of the bearings might have had something to do with it. The replacement bearings were from Bulgaria and cost $5.50 each. However, when properly greased with that water-proof blue stuff, I never had another problem for the next 28K miles.
That's again the Funduro you're talking about, right? The one with the oil tank in the frame? That would certainly melt the shb grease out quickly.
But then the F650GS singles are also fairly hard on their steering head bearings - we've had to replace them twice in 90,000 kilometers on ours which was well greased, at least for the second set.
In fact aside from tires, oil, sprockets and chains, that's the only thing we've had to replace on that bike in the whole time we've owned it.
I might add that the water pump used in the Funduro looks very much different than the one in your diagram. My recollection is that it was made of plastic and had those wavy conical vanes that you see in car water pumps.
I am noticed a small oil and coolant leak from the weep hole at mark 7000km, just a few drops, i start to believe that it is related to the rattling noise that also comes from the coolant pump (from day one, there is a thread on this).
In addition a friend of mine has also bought an F800GS and i noticed small trace of oil coming out from the weep hole (that was the day the bike was delivered). As always the service shop responded "it is nothing to worry about" even though at mark 1600 the cylinder head was soaked in oil, it looked like a cylinder head gasket leak but was actually the weep hole once again.
I need to find a service shop that will not treat me like i am a complete retard.... (yes sir of course it is supposed to only have one wheel....).
Maybe i should plan a road trip to Germany and have them check my bike....
From reading the manual the impeller is just "screwed" on to the end of the drive shaft and you remove it by sticking the tips of a pair of plyers into two holes and giving it a twist...
I wonder if yours just needs a twist in the opposite direction to tighten it up a bit perhaps it has just worked loose?
My bike got it too though just ever slightly. 1300kms on the clock now. I'll have the dealer look at the water pump when I take it in to get the forks done under warranty.
I could be wrong but I don't think its left over lube seal, looks too much like engine oil.
I would set an appointment up with the dealer, tell them you have an oil leak and it is getting all over motor. Small exageration but if it bothers you. There should be no seepage. BMW's come from a place that fails a car if it has a leak during the biennial inspection.
It is not normal for internal fluids to be on external parts. I think that is all I would say to the dealership if they tell you it is normal. I would probably call BMW Motorrad NA if they still did not want to fix it, as well as look for another dealership (if you are that lucky).
I wiped it off again and will call the service dept. and inquire if it keeps up!
I'm not sure how well stocked they are on parts so they may want to order up ahead...
I'm going to have to look at the DVD again... besides the two o-rings around the outside of the housing it would "seem" that there should be another seal of some sort around the drive shaft also, but that seal may be intregral to the pump assby (at only $157)
I have never worked for BMW motorrad, but if it is similar to the car side:
The waterpump will not be considered a serviceable item, strickly remove and replace. You can probably get the parts and if you feel tenacious, do the repair yourself. I think it is more effort than it will be worth in the long run, but that may be your thing. I work on my stuff less and less the older I get...
I for one highly recommend the dealership do it for you for two reasons:
An American mechanic gets paid to do the work (and hopefully is good at his job)
BMW pays all the associated costs for the repair (takes euros from the Germans and puts dollars in our economy)
Oh, and a third, they still warranty it for the rest of the warranty or for the parts warranty, whichever is longer. Depending on how anal the dealership is about checking stuff, if you take apart the water pump, regardless of why, they are no longer responsible to fix the bike unless you can provide documentation to back up your skills. It can become a long drawn out fight for something that is basically free to you and costs the dealers money.
I take my bike in more often than it truly needs (I would ignore a lot of stuff it if wasn't under warranty) and the dealership gets paid for looking.
The link, is that to the Lynchburg, VA dealer (Edit: Never mind, I read the second header after staring at the parts)? They aren't far from where I call home (not that I am ever there).
the Lynchberg dealer is the only one I know that has the microfiche on line... I'm sure there are others but theirs is handy.
I'm not going to disassemble since the bike is only a few months old, I will let dealer do it if I conclude it needs doing...
I only hesitate for fear of some unintended consequence ... i.e. something gets dicked up as a result ....
I would presume a new water pump, gaskets & o-rings + new anti-freeze would fix it ... if there even is a problem....
I am going to let it ride till later in any event!
thanks!
Keep us posted....
I thinking that if mine does not get any worse I'll just push it off until the service interval for a coolant change and maybe get a free one? ;-)
I do agree, it does look like motor oil but hard to say for sure.
My local dealer is ready to replace if I ask, no push back expected.
Ya see "In the old days" .... when I was a famous mechanic we would have put a small packet of (harmless) fluorescent dye in the engine oil and asked the customer to come back in a week and then inspected it with a black light.
Now they have all this modern "taste test" technology ;-)
Like you my local dealer seems fine to work with, and I did not buy bike there... (long sad story ... I wanted to buy local but ..... it didn't happen)
I wanted to buy local or close enough, they were great to deal with, but..... there was a three month wait. I ended up buying from a dealer further away. They had the model I was after sitting in the showroom all ready to go.
BTW new water pump is in now, they did the radiator hose recall at the same time. The only diffrence is the coolant is green.
I have the same problem with weep hole seepage of oil from the water pump. I just noticed the problem during a visual inspection the following day after riding hard the day before in extremely hot conditions (105-108 heat indices) Looks like the oil seepage trailed around the cylinder heads at the seam ( i hope that is the case) or I have a gasket problem too. Going to take it to the dealer today.
I've got my bike (2008 F658) at the dealers at the moment for similar (weeping water pump seal and rocker cover leak). They've had it for 4 days now and told me they're having trouble getting the water pump out and are now talking slide hammers (pulling) as it appears frozen on the shaft...
I read somewhere that the impellor is srewed onto the shaft. Can anyone confirm this? Have searched for diagrams etc but the ones I've found don't show clearly.
A slide hammer isn't going to leave a pretty picture if this is the case. I would like to assume they know their product...and I can't really complain too much as they've given me a new K1300S to use (bike is my every day transport) while mine is in hospital. Dangerous from my perspective as I'm rapidly getting to like it.
My bike still has 12 months warranty on it (has done 17,000 km), so I'm reasonably comfortable that they'll cover - and their service has always been good.
However, any knowledge on the pump assembly (from those with access to a manual) would be appreciated.
Sorry can't help out with a manual, but my pump took a day to change over. The sad thing is just after a couple of months there is mist around the weep hole again. I'm not sure if I should just let it slide as it really is bugger all oil coming out.
My understanding is they just replace the internals of the water pump. I saw the box mine came in and it looked like the size of ring box...lol. Not sure of the impeller but it looked like all I had for my water pump replacement were the seals. [sure] so far so good though.
I did question my dealer if they would rebuild or replace the water pump. Then he pulled out the new water pump (box was about the size of tennis ball) and told me it would be a complete replacement not rebuild. Don't know why but they told me the water pump is a non serviceable unit.
