Soldering and splicing wires - BMW F800 Riders Forum & Registry
Results 1 to 3 of 3
  1. Joined
    Jump to Comments
    2 Comments by Richard230 Published on 01-06-17 09:33 AM
    Here is an article published by Motorcycle.com regarding splicing and soldering wires that you might find interesting and useful:
    http://www.motorcycle.com/how-to/mo-...y-splice-wires
    Richard - Current bikes: 2016 BMW R1200RS, 2014 14.2 kWh Zero S, 2011 Royal Enfield Bullet 500 Classic, 2009 BMW F650GS, 2005 Triumph T-100 Bonneville, 2002 Yamaha FZ1 (FZS1000N) and a 1978 Honda Kick 'N Go Senior.
  2. LikesMokkybear liked this post
  3. Total Comments 2
    Comments
  4. #2
    Mokkybear's Avatar
    Points: 33,094, Level: 100
    Mark H
    Canberra ACT AUS
    Jun 2008
    2,085 / 5 / 154 / 637
    My only concern would be the in-line splice, where electrical tape rather than heatshrink is used. I don't believe electrical tape is a reliable insulation medium in automotive applications.
    I've used waterproof T-piece crimp connectors to good effect. They're reliable and if you choose the correct size, there's no risk of damaging the wire.
    R1200R-LC ​Exclusive in Thunder Grey with Touring Pack. Formerly Graphitane F800ST 04/2007. ABS, BMW panniers & topcase, trip computer, clear indicators, Ricor Intiminators, SW-Motech frame and R&G front axle sliders, coolant level check light, GS911
    Elgin, Scotland ST404 is offline Volunteer Moderator - GT
    ST404's Avatar
    Points: 22,354, Level: 100
    Pat
    Elgin, Scotland
    Jun 2011
    4,991 / 4 / 83 / 746
    '15 F800 GT
    +1 for the Pozi-tap connectors. Very easy to use and non permanent if you want to remove or replace the accessory at a later date.
  6. LikesTelemarkTumalo liked this post
