Want a slip on, bike is too quiet..what fits? - BMW F800 Riders Forum & Registry
Results 1 to 15 of 15
    Points: 1,060, Level: 18
    Kerry
    Rhode Island
    Apr 2016
    Any other model slip ons for the GT? Not a ton to pick from. If I remember correctly, anything made for the 800r fits, true? Anything else?
    Ty
    FrankV's Avatar
    Points: 3,997, Level: 42
    Frank
    Geldrop (Netherlands)
    Nov 2013
    There is really a lot of choice:
    Akrapovic, Remus, Arrow, AC Schnitzer, Two Brothers, Delkevic, SC Project, GPR, Scorpion,....
    As far as I know the F800R slip-on exhaust also fit the GT (maybe only from a certain model year?)
    2013 F800GT Valencia Orange
  4. LikesTelemarkTumalo liked this post
    Points: 1,528, Level: 23
    California
    Feb 2016
    Just on cycle gear, not that I am a big fan, there is a ton
    https://www.cyclegear.com/motorcycle...query=&tab=all
    and how is it too quiet?
    Kerry
    Rhode Island
    Apr 2016
    I've seen all the options for the GT, curious if there was more.
    "How is it too quiet" not sure how to answer that question without the obvious answer. I like a louder bike, not loud enough for me. So with your question I'd guess you think it's plenty loud enough...
    mboban's Avatar
    Points: 1,445, Level: 22
    Mate
    Croatia
    Nov 2015
    '14 F800GT
    I just posted here about same topic - http://f800riders.org/forum/showthre...und-of-our-gts
    I bought Akrapovic, check photos and problem with euro 4 norm slip on.
    Points: 2,290, Level: 30
    Seoul, South Korea
    I've got a Leo Vince on my GT and it is loud as hell. Completely changed the character of the bike (and Korean taxis don't cut me off as frequently)
    TelemarkTumalo's Avatar
    Points: 23,445, Level: 100
    Mark
    Bend, OR
    Oct 2011
    4,248 / 21 / 167 / 1251
    '16 R1200GS ADV
    '13 CRF250L
    I am running an Akrapovic on my ST and very happy with the sound using the dB killer insert. Without the insert, it is too loud for my comfort.
    Mark
    Bend, OR
    Oct 2011
    '16 R1200GS ADV
    '13 CRF250L
    Without dB killer
    Mark
    Bend, OR
    Oct 2011
    '16 R1200GS ADV
    '13 CRF250L
    And here is a nice compilation video of several pipes
  13. Thanksnkaj thanked for this post
    Likesnkaj liked this post
    Bulkheadphil's Avatar
    Points: 814, Level: 16
    Chesapeake, VA
    '15 F800 GT
    Quote Originally Posted by TelemarkTumalo View Post
    Without dB killer
    Can you briefly explain how you removed the DB killer? I prefer the louder, beefier sound. Thanks.
    2010ST -->2012RT -->2015GT
    Points: 3,849, Level: 41
    steven
    castle rock wa usa
    Feb 2013
    On my Akrapovic titanium slip-on there is a small screw that goes through a hole then into a welded-in nut in the DB killer.
    I removed mine yrs ago, had to use a slide hammer to *pull* the DB killer out, mine really fight tight, so tight I think it would stay put without the screw.
    This Akrapovic was an option on my '07 ST when new.
    And like Mark said, mine was too loud (for me) without it, so it stays in.
    07 F800 ST
    94 miata zoom zoom
  16. ThanksTelemarkTumalo thanked for this post
  17. #12
    California
    Feb 2016
    Quote Originally Posted by scf View Post
    I had something similar in the Staintune on my VFR, installed the system left it for months and months, went to take them out and they were sealed in there after so many heat cycles. So what I did was when I put it back in gave the contact surfaces a coating of anti-seize compound. A year or so later I was able to remove it again, no problem.
  18. LikesRichard230 liked this post
  19. #13
    Points: 25, Level: 1
    George Florentin
    Belgium
    Jun 2017
    Hi guys,
    Do you need to load a new ECU map (or use power commander) with an aftermarket slip-on? On my Street Triple I had to, or else the bike felt worse, not better.
    Did anyone test the fuel consumption before and after the exhaust swap?
  20. #14
    FrankV's Avatar
    Frank
    Nov 2013
    Yes, no difference (Akrapovic slip-on). New ECU mapping not necessary. No performance increase or decrease, just a bit more noise (without the dB killer a lot more....)
  21. #15
    Mark
    Bend, OR
    Oct 2011
    '16 R1200GS ADV
    '13 CRF250L
    Quote Originally Posted by Bulkheadphil View Post
    Yes Steven, as Phil noted: there is a retaining screw on the bottom of the tail pipe at the very back. Remove the screw then, grab the end of the dB killer with a pair of pliers, twist and pull and it should slip out. If it is corroded in there, you might have to remove the can, then "drop" the pipe onto a piece of carpeting until it smacks out, or even use a broom handle to poke it out from the proximal end.
    As Frank noted, the real advantage of most of the aftermarket pipes, is the sound. The other advantage is the weight difference of ~4 lbs lighter for the Akra pipe.
