handlebar position - BMW F800 Riders Forum & Registry
Results 1 to 22 of 22
    james c lowe's Avatar
    Points: 712, Level: 14
    england
    Oct 2016
ID:	250489 The Rox risers improve the riding position and rotating the bars forward has helped even more
    WildWilly's Avatar
    Points: 72,288, Level: 100
    SE Iowa
    6,787 / 15 / 214 / 1480
    Like the BMW logo on the bar ends. Nice finished look.
  4. Thanksjames c lowe thanked for this post
    yoav's Avatar
    Points: 1,050, Level: 18
    Carlisle, England
    Mar 2016
    Where did you buy them from? And how difficult were they to fit?
    england
    Oct 2016
    I got them second hand off ebay,but they are easy to source,only slight difficulty fitting is adding in brake line extension,but fairly easy.
    Points: 39,729, Level: 100
    10,079 / 8 / 110 / 2177
    When I got the Rox risers, I was at a rally in Nor Cal and paid about 70 bucks. Great addition for comfort.
    There was a tutorial for rerouting the cables and such that some Swede had done for the ST. At least on the ST, new brake lines and cables were not needed but they were at the limit of their stretch ability.
    I recently got a couple sets of risers from this forum, I think, and put them on my Wee Stroms. Making life a bit better.
    england
    Oct 2016
    Rerouting the cables was easy,but dont think you would get away without adding the brake line extension.
    Points: 2,178, Level: 29
    Ken Wright
    Workington Cumbria
    Jan 2016
    I've got 20mm bar risers that didn't require too much maneouvering, but want to bring bars closer to me. So I'm interested in your solution, but where did you get a brake line extension kit?
    england
    Oct 2016
    The extenson piece is available from MV Verholen direct just email them and tell them you only want the extension piece,costs around £10 plus pretty expensive £10 postage,but arrived within 2 days.
    Ken Wright
    Workington Cumbria
    Jan 2016
    Quote Originally Posted by james c lowe View Post
    Thanks!
    Ken Wright
    Workington Cumbria
    Jan 2016
    I'm thinking of getting the sort of bar risers that can be adjusted for position which are clamped in the normal bar clamps. But I don't know what diameter the handlebar is!
    yoav's Avatar
    Carlisle, England
    Mar 2016
    Handlebar diameter at the clamps is 1 1/8".
    I assume that's a standard size and what you are after are generic bar risers, not specific to the GT, which fit into the GT's handlebar clamps?
    Ken Wright
    Workington Cumbria
    Jan 2016
    Quote Originally Posted by yoav View Post
    Many Thanks, you are right!
    yoav's Avatar
    Carlisle, England
    Mar 2016
    Quote Originally Posted by Rev Ken View Post
    You're welcome. Perhaps when you find the risers you want then perhaps you could let me know. I've also been after a pair but confused by the choice.
  17. #14
    Ken Wright
    Workington Cumbria
    Jan 2016
    Me too! When I find time for another search I will order some and if they work I'll let you know.
  18. #15
    yoav's Avatar
    Carlisle, England
    Mar 2016
    Thanks. I could even come and see them as we don't live too far apart.
  19. #16
    Ken Wright
    Workington Cumbria
    Jan 2016
    I've found some that MIGHT fit. They fit R1200GS LC 13-17/ Adventure 14-17, but I need to know the spacing of the cap fixing bolts. The bars are the same diameter and they look as if they might fit,. If you are ever near Lloyds could you possibly measure the spacing? Crudely I reckon the spacing on my GT is around 40mm, but I'll have to measure them more accurately. Otherwise I'll have to wait until I have time to pop up to Lloyds with a ruler!
  20. #17
    Points: 1,528, Level: 23
    California
    Feb 2016
    Are there regular Rox risers and then vibration dampening ones?
    http://www.twistedthrottle.com/rox-a...ycles-2in-rise
  21. #18
    yoav's Avatar
    Carlisle, England
    Mar 2016
    Hi again.
    I take it you mean the spacing between the centres of the 2 bolts that hold the handlebar clamps in place:
    So,
    F800GT - 38mm
    R1200GS and R1200GS Adventure - 45mm
    (That's new bikes at Lloyds)
    Hope this helps (or not)
  22. #19
    Ken Wright
    Workington Cumbria
    Jan 2016
    Hi again.
    So,
    F800GT - 38mm
    Thanks, it just so happens I popped in to-day - so sadly my idea won't work. Went to the spares department and they suggested Roxy adjustable bar risers from Twisted Throttle. Verholen risers also would do the job, but they suggest you also need new throttle cable, Cutch Cable AND Clutch lever (form the ST) which also entails a resetting of throttle etc and recommend it be done my a BMW agent. The whole lot comes to around $400 before importing them and paying for fitting - so Roxy it is going to be (even that isn't cheap and obviously requires a longer brake hose, but I hope I can get away with my current cables. I'll let you know the damage!
  23. #20
    WildWilly's Avatar
    SE Iowa
    I have the Verholen on my GT and the only thing required was the included brake line extension. The throttle cable was relocated but didn't require any new cables.
  24. #21
    yoav's Avatar
    Carlisle, England
    Mar 2016
    Do you mean something like these?
    http://www.twistedthrottle.com/rox-h...odels-aluminum
    Am I correct in assuming that 28mm is the metric diameter of the GT's bars at the clamp?
    (BTW if the parts have to be ordered from abroad, and the postage is expensive then if you wanted to then we could both order the kit and save on postage. Send me a PM if you want to go with this. Otherwise, I'll wait to find out how it goes with you.)
  25. #22
    Ken Wright
    Workington Cumbria
    Jan 2016
    Correct! We can save $48 on postage for the ROX bar risers if we order them together, but I don't know what the customs duty and handling charge on this side of the water will be, so I'm still wondering whether an alternative from Europe for 136 euros that comes complete with a brake hose extension pulling the bars back and up around 50mm would be cheaper (MV Motoradd 90028F). Apologies for being so indecisive, as I still haven't researched what it would cost to just purchase the brake hose extension as a separate purchase necessary with the ROX risers. Do you have a preference?
