Hi there,
My bike was idling poorly so I decided to try and fix the kinked hoses as you described. I didnt have springs to stop the hoses from kinking so i tried to use a thicker hose pushed over the standard ones. Put it all back together and OOPS it cant even idle!!!
Pull it all apart again, scratch my head for 5 minutes, then decide to re-route the hoses around the throttle bodies instead of between them (as seen in your last pic). Put it back together...and SUCCESS idles like a inline 4 (Ok not quite but its perfect now). Going around the throttle bodies prevents the hoses from kinking when you push the air filter back down into place, EASY FIX!!!
