HOW: Changing the Oil and Filter - BMW F800 Riders Forum & Registry
Results 1 to 18 of 18
  1. Joined
    May 2006
    Canberra ACT
    Jump to Comments
    17 Comments by Petro Published on 07-20-07 01:17 AM
    I should start by saying I’m no mechanic.
    Changing the oil a few months ago on the F800ST was the first oil change of my life on anything. Needless to say, I sought and took some advice before I started.
    So apologies to the mechanics.
    My only foray into oil changing will likely be at the mid-point between 10,000kms services. The good advice seems to be to “drop” the oil at this stage. Part of the 10,000kms services, of course, will be oil and filter change – so the mid-point “drop” will be all that’s needed by most riders.
    I know some of you will do the oil change at the 10,000kms marks also. In this case a filter change will be necessary (as if you didn’t know!).
    There may be some variation of opinion as to whether a filter change is needed at the mid-point “drop” (see below).
    The first step is to acquire the following tools (a little initial capital investment may be needed):
    1 A special oil filter removing tool (if you’re going to change the filter) (see picture 1).
    2 A ratcheting socket tool with 19mm head (picture 2)
    3 A ratcheting socket tool with a 24mm hex socket attached (picture 3) (Unfortunately there doesn’t seem to be an adapter that will allow the 24mm hex socket to go on the smaller socket ratcheting tool) NB SEE NOTE AT END
    4 A sump oil tray (no pic: I used a has-been baking tray but it was a bit small)
    5 A funnel of some sort (I used an old jug but it wasn’t easy)
    6 The required amount of new oil of your preference: 3 litres.
    7 A new oil filter from your local BMW dealer (optional – see below)
    Note that Picture 3 shows a 12 point head but you may wish to use a 6 point: see RLG's advice in posting lower down in this thread.
    Once you have assembled your tools and oil, take the bike for a ride to warm up the oil (10 kms should be enough). This ensures the contaminants get spread around the oil and drain out; and do not stay at the bottom of the sump.
    The bike is best placed on its side stand on level ground to allow maximum drainage of the sump oil from the outlet (see picture 4). Place the sump oil tray under the sump outlet. The 24mm hex socket undoes the oil sump cap (see picture 5). Undo this cap. Let the good (sorry, bad) oil flow! Note that the outlet is a little to the side, so oil will flow accordingly - as bo_vk discovered (see posting lower down in this thread).
    Now the filter: One opinion will say that it is counter productive to change the oil and leave a dirty filter with dirty oil inside it. So the filter should be changed with each oil change. A second opinion will say that the amount of dirty oil in the filter is minimal – and the oil won’t be all that dirty anyway, so pretty much all the benefits of new oil will be attained without a filter change at the mid-point “drop”. So, under this view, the oil filter change at the 10,000kms periods will be sufficient.
    Some further views on this would be good. Does it make a difference, for example, if your use of the bike is predominantly highway travel or predominantly city commuting? I understand that commuting will dirty the oil much more quickly than highway travel. (I only do open highway travel – advantages of being retired).
    If you change the filter, undo it with the ratcheting tool with 19mm head and special tool (see picture 6). Discard the old filter environmentally appropriately. Pour some new oil into the new filter so that it fills up (won’t take much). When fitting the new filter take some new oil and wet the gasket on the new filter (use your finger tip and smear some oil on the rubber gasket). Wipe the rim of the filter clean.
    Hand tighten the filter + 1\2-3\4 turn with filter tool.
    Q for the mechanics: Is there any benefit in draining the old filter of the old oil and priming it with new oil? The idea would be that you get rid of more contaminants and save some money by not having to buy a new filter.
    Let the oil drain – let it run for a while so the last bits have time to drain back into the sump and out the outlet.
    Important step: Replace the sump cap and tighten with the 24mm hex socket. I think there was a small gasket in the cap that might need to be changed at the 10,000kms marks. (mechanics, advice please on this!).
    Pour in the new oil through the normal oil intake (see picture 7 – just in case you weren’t sure!). The manual says capacity is 3 litres “with filter change”. I guess this means it will be a little less if you don’t change the filter.
    The manual also says “0.3 litres additional, if swing-arm shaft cover is removed”. That’s way outside my league!
    Dispose of old oil in an environmentally appropriate way.
    That should be it!
    Wait for the mechanics to comment before you leap into it.
    Petro
    NB: As advised by another contributor to this topic, try to get a six point socket. The photo shows a twelve point one, but I have just (19/9/07) experienced the problem of the soft edges. Could not move the plug and have frayed the edges. Went and bought a sixpointer and got it undone relatively easily.
    Picture 1
    24.07*KB
    Picture 2
    25.46*KB
    Picture 3
    29.11*KB
    Picture 4
    37.21*KB
    Picture 5
    52.28*KB
    Picture 6
    42.9*KB
    Picture 7
    41.82*KB
    Love my blue F800ST.
    My next bike already is the F800GS
  2. Thanks DaveG2000, Jagson, Aigeas thanked for this post.
  3. Total Comments 17
    Comments
  4. #2
    Rob's Avatar
    Points: 118,691, Level: 100
    Rob Werksman
    Pittsburgh, PA, USA
    Sep 2005
    5,127 / 700 / 104 / 5
    '90 K1
    '10 F800GS
    '10 S1000RR
    Great Thread! Thanks Petro!
    (I've edited your title though )
    Pancho's Avatar
    Francisco
    San Martin de los Andes, Neuquen, Argentina.
    Apr 2007
    That's really good Petro, Rob will you create then a How To Forum to put them all there?
    If so, I can prepare a How To change turning lights, remove side fairings on ST, access air filter, access battery....
    F800ST, one space ship with two wheels
    LU7YWC
    S40 08.199 W71 16.737
  6. #4
    Zelhem, Gelderland, Netherlands. de100kb is offline Volunteer Moderator - Global
    de100kb's Avatar
    Points: 12,297, Level: 76
    Karim
    Aug 2006
    2,240 / 202 / 72 / 4294967295
    '10 R1200R
    Yes and maybe you can start the how to forum with a 'how to submit (a request for) a how to-thread' were people can drop ideas for 'how to' treads.
    For the Dutch F800forum: click here
    Pat H's Avatar
    Points: 85,292, Level: 100
    Pat
    Ware, Herts, UK
    Aug 2006
    38 Minutes Ago
    10,885 / 1045 / 142 / 3
    Great Post and a great idea.
    Some thoughts from my part:
    Emptying the filter if not replacing it: I'd say no. The oil seal on it's not designed for more than one removal and fitting. I'd either leave it as it is or better still, for the cost, replace it anyway.
    Coventry, Warwickshire, UK
    Oct 2006
    Hi Petro,
    Excellent first post, for the new mechanical how to section. I would change the filter along with the oil too. I'm looking forward to the fairing removal "how to" as well.
    I think this is an excellent idea for those of us who aren't so mechanically minded and who would like to have a go and how to do various jobs.
    Andy
    Geir's Avatar
    Points: 5,486, Level: 50
    Oslo, Norway
    Jul 2006
    Hello Petro
    oilfilter change, always when you change the oil.
    When fitting the new filter take some new oil and wet the gasket on the new filter ( use your finger tip and smear some oil on the rubber gasket)
    Not necessary with BMW tool,get a cheap filter tong from any automotive store.Make shure it will fit the filter,they come in many different sizes.
    For the copper washer on the tapping plug,get new one,(can be reused many times)if you get a leak an old trick is to heat the copper washer red hot and then cool down in water,it is then as good as new and can be used many times over
    Geir
    There is only one thing wrong with the alps,it is not by the sea.
    Pancho's Avatar
    Francisco
    Apr 2007
    I will post this afternoon how to: remove fairing (ST), acces air filter, change front brake pads. Unless someone is already on it!
    LU7YWC
    Beaumont, Texas, USA.
    Jun 2007
    I maintained my R100GS, R1100RT and will do F800 as well (This introduction is just to keep my self-esteem after the following comedy).
    I changed the oil and filter. Nobody mentioned that the hot oil does not come out downwards (as on R1100RT) and it does not come out slowly (it is a 1" plug!). Between seeing the dark hot mass coming towards me, half of it missing the oil pan, and my wife asking: "Do you need a napkin, BO?" I realized I just lost all my credentials.
    So, Petro, maybe a warning in that part of the procedure would be justified :=)
    Bo
    Points: 4,027, Level: 42
    Kokomo, Indiana, USA.
    May 2007
    Thought I'd add a comment made by the Chicago BMW dealer. They recommended using a 6 point socket rather than the 12 point due to the softness of the aluminum and the chance of rounding the corners.
    49.35KB
    2007 BMW F800ST & 2003 Scorpa SY250
    Rob's Avatar
    Rob Werksman
    Pittsburgh, PA, USA
    Sep 2005
    '90 K1
    '10 F800GS
    '10 S1000RR
    Added to the Hall of Wisdom - 7/22/07
  14. #12
    Points: 4,050, Level: 42
    Seattle, WA, USA.
    Jun 2007
    For those who like numbers; tighten oil filter to 8 ft-lbs, drain plug from a low of 1/4 turn past seating of crush washer to a high of 29 ft-lbs (opinions vary). SAE 15/16-inch also works on the drain plug.
  15. #13
    Washington DC
    May 2007
    Very valuable - outstanding. Thanks
  16. #14
    Aigeas's Avatar
    Points: 3,833, Level: 41
    Νίκοs
    Land of Gods
    Nov 2006
    Thanks Petro!
    Life begins at 200
  17. #15
    Spartanburg, SC, USA.
    Is there a PureOne or Mobil 1 filter that fits the F800? If yes, can you provide the part number? Thanks.
    Expatiate
  18. #16
    Petro's Avatar
    Points: 4,329, Level: 44
    Robert
    Canberra ACT
    May 2006
    '09 F800GS
    '06 F800ST
    RLG: Your advice was good. The plug must have been tightened more at the 20,000k service than it had been at the 10,000k service. Had no problem getting it undone last time, but this time I couldn't budge it. Eventually ended up damaging the soft endges, They are all frayed and so the twelve point plugs just slips all the more. Went out and bought a six pointer and got it undone ok.
    I've added a note to this effect on the instructions.
  19. #17
    Petro's Avatar
    Robert
    Canberra ACT
    May 2006
    '09 F800GS
    '06 F800ST
    Upstaterider: sorry, can't help. I did see some filters at an el cheapo motor accessory store at the weekend that looked the same! (I'm not into this sort of stuff.) In any event, they were a few dollars more expensive than the BMW one (surprisingly).
  20. #18
    Points: 3,702, Level: 40
    BENONI, GAUTENG, South Africa.
    May 2007
    '80 R80G/S PD
    '03 R1150GS ADV
    What Oil Should One Use To Refill?
