HOW: Change air filter - BMW F800 Riders Forum & Registry
Results 1 to 8 of 8
  1. Joined
    Apr 2007
    San Martin de los Andes, Neuquen, Argentina.
    Jump to Comments
    7 Comments by Pancho Published on 07-20-07 10:19 PM
    To do this first be familiar with:
    HOW:remove fairings on F800ST
    Tools needed:
    Torx N25
    Phillips screwdriver
    Flat screwdriver
    Fingers
    After removing false gas tank, and upper fairing (you don't need to remove lower fairing) you will see the air box and air box intake:
    80.82KB
    To remove air box intake/air filter holder you need to remove two big plastic safety clips.
    28.15KB
    If you proceed as in the picture, using your thumb, clips goes out really easy.
    62.63KB
    44.98KB
    49.55KB
    With both clips out, pull up the air intake/air filter holder.
    60.39KB
    Here it is, just remove the old filter, clean everything, and place new filter in holder.
    106.74KB
    Rewind the movie (pull down into original position air intake/air filter holder, install securing clips, lower fairing, mirrors, false gas tank and seat) and hit the road!
    Any doubts PM me!
    F800ST, one space ship with two wheels
    LU7YWC
    S40 08.199 W71 16.737
  2. Thanksskodadog, dpancerz, Willy, mervingry, talexan and 2 others thanked for this post
  3. Total Comments 7
    Comments
  4. #2
    Rob's Avatar
    Points: 195,953, Level: 100
    Rob Werksman
    Pittsburgh, PA, USA
    Sep 2005
    5,186 / 3 / 158 / 851
    '90 K1
    '10 F800GS
    Added to the Hall of Wisdom - 7/22/07
    Forum Owner Emeritus
    Rob Werksman - Owner, Motorcycle Insight, LLC
    F800 Depot | S1000RR Depot | Adventure Motorcycle Depot | Twalcom USA
    North American Importer - Globescout, Twalcom, Wild@Heart, Hornig, AC Schnitzer (Motorcycle)
  5. ThanksAntman thanked for this post
  6. #3
    Moon, VA.
    May 2007
    Another winning post.
    Aigeas's Avatar
    Νίκοs
    Land of Gods
    Nov 2006
    Thanks Pancho!
    Useful topic
    Life begins at 200
    Solna's Avatar
    Sweden
    Oct 2007
    I have just changed my air filter. Thanks to this great post even I, that are mechanically impaired, managed to succeed.
    /Nus
    dpancerz's Avatar
    Garland, Texas
    Apr 2008
    Nicely done, Francisco! Thanks so much for the post and sharp pictures.
    David
    elchino's Avatar
    Alex
    Miami, FL, USA.
    May 2007
    632 / 0 / 47 / 29
    Great post. Curious did you go with an OEM filter or a K&N?
    Grey F800ST/V Stream/SW Motech Risers/Sargent Custom Seat/Hyperlites/Motolights/Zumo/Kaoko Throttle lock
    Daneil
    Stockholm
    May 2008
    Ah, thanks this was just what i was looking for. Great post!
