| Register | Home | Forum | Blog | Calendar | Arcade | Gallery | Surveys | Groups | Search | Today's Posts | Mark Forums Read |
| F800 Centre: Garage | Hall of Wisdom | Registry / Results | Farklepedia | Rider Map | Track Days | Classifieds | 2010 Rally |
#1 | |
Forum Administrator
If you have S1000RR Questions, they have answers. I'm looking for questions to forward over to BMW North America's Lawrence Kuykendall regarding the S1000RR. The cutoff for receiving your questions is Monday @ Noon EST. Here is what I have so far:
| Sponsored Links |
NOW IN STOCK @ S1000RR Riders Depot AC Schnitzer Frame Sliders -- World's finest framesliders for the BMW S1000RR priced at $289.99 Remove this advertisement & get other GREAT benefits by becoming a Sponsoring Member |
#2 |
Here are the questions that Laurence and I have been discussing,
1) Will it be possible to turn off the 186 MPH top speed limiter as we plan to run the S1000RR on the Bonneville Salt Flats next summer. 2) Will full race ECU programing be available to those of us that plan to race the S1000RR 3)What, if any, continguency programs will be available. As you might know......"what wins on Sunday, sells on Monday".....or something like that. | |
#3 | |
Volunteer Moderator - F800S/ST, S1000RR
+1 on the race ECU option, to go along with a full race exhaust. Some of us will race it, others...simply will run non-street legal kit on the streets
Oh, and will a WSBK-spec under fairing (full length, to use with race exhaust and conforming to WSBK rules (can catch and hold oil if spilled from the engine), be available from someone? | |
¡Rocinante!
#4 | |
The accessories being offered do look very nice, but for me, I would want to upgrade the suspension first and foremore. At the moment the accessories being offered do not include suspension upgrades. I would be interested to know what the officially blessed BMW upgrade path for the suspension is.
Rumor has it that the 46mm forks are meant to be easy to upgrade to Ohlins. Can Laurence confirm or deny this? Which Ohlins forks in particular are they thinking about if this is true? Does the stock triple clamp that permit fitment of the FGR 900? If not, will there be an accessory to do so? What about a TTX40 for the rear? | |
#5 | |
I imagine the top-shelf Ohlins should bolt right on; the bike was designed around the WSBK suspension components.
¡Rocinante!
#6 | |
Volunteer Moderator - F800S/ST, HoW
from everything i've heard form the rep's the stock suspension is actually quite good and you wouldn't notice a difference going to ohlins unless you were very..very good.
When are we going to see actual dyno numbers? Will BMW ever offer heated handlegrips? | |
2007 F800S: Pullman/Spokane Wa.
check out my bike in the garage! http://f800riders.org/forum/garage_v...w_vehicle&id=9 |
#7 | ||
Quote:
All the WSBK race machines that I've seen pictured have FGR900s on the and to my knowledge, not a single bike on the market can fit those with the OEM supplied triple clamps. | ||
#8 | |
Global Moderator - BMWSR.org
+1 Simon. No way the fine tuning you get with race quality Ohlins is going to be the same as showroom shocks.
"Misdirected inertia is sure to have dangerous if not catastrophic results" by Nail24
Bubba Edwards BMW '08 R1200RT BMW '08 HP2 Sport #39 |
#9 |
My suggestion for BMW is that the next time they update their bikes' computer program they include a battery voltage tester that checks the voltage of the battery when the starter is used to help determine the condition of the battery. When the battery starts to look weak, the instrument panel could inform the rider that the battery will need to be replaced. That would be really helpful considering that none of the current BMW motorcycles will run if the battery voltage drops below a certain level. I hate pushing a motorcycle!
Richard - Current bikes: 2009 Electric Motorsport SepEx GPR-S
, 2009 BMW F650GS |
#10 | |
Forum Administrator
Questions Richard - not suggestions.
If that was what they were looking for, I'd have a friggin boatload. | |
#11 | |
I suggest that Bmw start tracking the unbelievable number of fuel strip failures on the R1200RT. My '08 is about to have the 4th one installed. When I called the customer service number they had never heard of the problem. Customer service needs to be able to start a tech fault.
#12 | |
Ohlins, I thought it was just a name and a way to milk you out of exobitant amounts of cash, but my experience was night and day - 848 with basic suspension, 1198S with Ohlins. I simply could not believe how much easier it was to get the bike to do things that were one step ahead of my abilities. I had to work and fight the 848 a bit; the 1198S was telepathic, and I felt like an instant race god
¡Rocinante!
#13 |
Mods, quickly remove the above post, Payday loans are one of the biggest scams of the century.
#14 | |
#15 |
Thanks
#16 | |
visit alpharacing.com the guys in germany are the racing team BMW in SBK and factory sponsored for S1000 racing parts on sale via BMW dealers.In Castelloli wich I was the manager of Alpha told us that the bike in dyno runs stock at 186 hp and full racing kit at230 hp.and believe me the racing kit has many things.and you can also send your bike to their headquarters and send it back fully ready at your specs.Cheap and cool mod was that they sell a Bitubo cartrige for the Sachs fork.
#17 |
Factory sliders for trackday prep?
Other trackday prep instructions from factory: e.g. lights defeat via CANBUS switch sequence for US-spec motorcycle, radiator flush, tail piece removal, turn signal removal? These bikes should see a lot of trackday time, so why not address the necessary bike preparations in orgranized fashion? | |
2007 F800S
2004 R1150R Rockster 2003 Buell XB |
#18 | |
This might be a bit too technical, but getting a better understanding of DTC and wheelie control.
Is the bike using a 3-axis gyro to keep it from elevating the front wheel past a certain angle? Or, is it simply using the wheel speed sensors. The marketing docs are a bit unclear on this. | |
#20 | |
Forum Administrator
There were 690 pre-sales in the US. I don't think production was limited to just 1000 motorcycles.
#21 |
My dealer, who had just returned from the US introduction, told me that there would be 2300 S1000RR bikes imported into the US this year. At least that is what I think I heard. Perhaps one or the other of us was confused and it was 2300 units produced for all markets in 2010. I am sure that I heard "2300", though.
, 2009 BMW F650GS |
#22 | |
Yeah, I heard initial production units was somewhere around 2,000 to US (or North America) and then BMW bumped it up to 2,400. I have to imagine that based on the price point of it not being a exclusive bike, that if BMW sells all the units, it will bump up production. Anyone know how many CBR1000RR Honda produced last year?
#23 | |
Hi,
can you help with an issue i have with the clutch lever on the s1000rr. When starting off the clutch lever is full and firm. When coming to a stop after changing down the clutch lever becomes sloppy with alot of play. Why does this happen. Please help | |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Solo Female rider--seeking answers from others | Shrosa | F800S & F800ST Discussion | 73 | 08-23-08 10:06 AM |
| Couple o' questions.. | Mike | F800S & F800ST Discussion | 11 | 03-08-08 11:01 AM |
| Few questions | batamali | The Inside Line (News & Help) | 31 | 12-21-07 04:47 AM |
| Other questions, sorry. | Hammam | F800S & F800ST Discussion | 4 | 07-06-07 04:36 AM |
| 2 questions | remdgp | Français F800 Discussion | 5 | 04-25-07 02:01 PM |
