As our Auxiliary Fog Light switch has been quite popular, we've updated the kit to also select the BMW switched power lead (GPS connector) as well as the female 3-pin plug connection to allow an even cleaner install without cutting off the connector at the end of the switch!
The Kit can be seen here, and will be on special through the end of the year: http://f800depot.com/bmw-aux-lighting-switch-kit.html
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
