F800S/ST Bracket Kits - BMW F800 Riders Forum & Registry
Results 1 to 8 of 8
    ezymount's Avatar
    Garland, TX, USA.
    Nov 2007
    Work is still in-progress on these kits. A delay was encountered due to a request to build a kit for another light mfg., which is also still under development. My kit will still place lights under mirror, outside of fairing. Extensive re-work has been accomplished along with an adapter plate, required to allow necessary standoff of the bracket from the fairing body panel.
    The mirror extender work has been discontinued due to high labor material costs associated with the type of work required to produce the kit.
    Jim Lawson
    Ezy-Mount Products
    Auxiliary Light Mounting Solutions
    www.ezymount.com
    ezymount's Avatar
    Garland, TX, USA.
    Nov 2007
    This kit back in-shop today for minor changes.
    Jim Lawson
    Ezy-Mount Products
    www.ezymount.com
    avboden's Avatar
    Spokane, Wa, USA.
    Oct 2007
    3,260 / 2 / 18 / 568
    pics?
    ezymount's Avatar
    Garland, TX, USA.
    Nov 2007
    not available yet.
    Jim Lawson
    Ezy-Mount Products
    www.ezymount.com
    ezymount's Avatar
    Garland, TX, USA.
    Nov 2007
    F800S/ST Kit
    Finishing 650/800GS kits this weekend.
    Put those to bed and will be finishing 800S/ST kit.
    Bracket already done. Final work on adapter base that will mount under bracket arm, providing elevation space off fairing panel for brackets. This adapter base will have a wire slot machined at bottom, to allow light wiring to run thru, beind mirror base, thru drilled hole in plastic, between the mirror studs that are screwed into to mount side mirrors. End result, wire from light is tied to underside of bracket arm, close to fairing panel and disappears into bike. Confusing right ! Really very simple to execute. Brackets will be 'cold-rolled-steel, black powdercoated and pre-punched for various PIAA and other mfg. lights..
    Bracket designed to hug fairing panel and keep lights tucked close-in. Aux lights will be in-line, on horizontal with headlamp bulbs...
    May have some pics next week for viewing. I had already posted something on this, but the original design has been changed to keep things tight, bracket arm has been shortened to eliminate vibration and material has been beefed up, as well. Powdercoat material will be black, semi-gloss, mil-spec (non-fade) polymer..
    Jim Lawson
    Ezy-Mount Products
    www.ezymount.com
    WildWilly's Avatar
    Points: 326,226, Level: 100
    SE Iowa
    23,577 / 15 / 214 / 1480
    Jim: Any update on the ST kit?
    ezymount's Avatar
    Garland, TX, USA.
    Nov 2007
    I had been working a couple of under-mirror solutions for some time and they got sidetracked in favor of other higher priority projects.
    I am resurecting the project in a week, or so..
    Coming soon...!
    Jim Lawson
    Ezy-Mount Products
    www.ezymount.com
    Sherrill Elm
    jim,
    Any new developments with the ezymount light brackets for the ST?
Similar Threads
  1. New F650/800GS Light Bracket Kits
    By ezymount in forum Ezy-Mount Products
    Last Post: 04-08-09, 07:38 AM
  2. Brakelight kits for top cases
    By wuj3888 in forum F800S & F800ST Discussion
    Last Post: 05-24-08, 10:07 PM
  3. Footpeg Lowering Kits
    By 800STDUDE in forum F800S & F800ST Discussion
    Last Post: 05-06-08, 10:27 PM
  4. Powerlet kits for 800
    By Barance in forum F800S & F800ST Modification Nation
    Last Post: 04-18-08, 10:49 AM
  5. Punctures & Puncture Kits
    By SMB in forum F800S & F800ST Modification Nation
    Last Post: 07-03-07, 01:26 AM
