Gearbox Issues - BMW F800 Riders Forum & Registry
Results 1 to 20 of 20
    Alfodr's Avatar
    Mauro Cantoni
    Cheltenham, UK
    Nov 2014
    '14 F800R
    Hello,
    Thought I might try tapping into the collective wisdom to see if anyone else is experiencing the following gearbox issues with the F800R. Note that this only happens very occasionally - so fully prepared to accept that the following may be caused by "operator error" i.e. me.
    - Getting a "false" neutral between 5 and 6 gear
    - Falling out of gear when in first (i.e. just drops in neutral by itself)
    - Struggling to transition from 3 to 4 gear (noting this is only whilst max out on full throttle).
    Any thoughts / pearls of wisdom most welcome.
    Offcamber's Avatar
    Points: 26,665, Level: 100
    NC, USA.
    Nov 2006
    538 / 2 / 43 / 93
    '11 F800R
    '12 R1200GS
    I know it's not much help, and it's one data point, but I've found the F8R transmission to be smooth and consistent.
    Sure, I'll ride that.
    FrankV's Avatar
    Points: 7,892, Level: 62
    Frank
    Geldrop (Netherlands)
    Nov 2013
    The F800R engine/transmission is about the same as for the F800GT, isn't it? Transmission of my GT is very smooth, never experienced troubles as you described. Sometimes shifting down from 2 to 1 can be a bit problematic, but not something I worry about.
    2013 F800GT Valencia Orange
    guidoveloce's Avatar
    Points: 90,252, Level: 100
    Guido
    Collesano, Italy
    Apr 2010
    21,446 / 19 / 1216 / 2033
    With the F800S I usually used to upshift and often also to downshift without pulling the clutch, the gear box was very smooth and I never had problems.
    Points: 1,870, Level: 26
    Greg Mook
    Oxford, UK
    Mar 2015
    My R only has 800 miles on the clock, but I find getting up from 4th and 5th to regularly take 2 or 3 prods.
    danham's Avatar
    Points: 34,343, Level: 100
    Dan H
    Harwich, MA
    May 2009
    3,463 / 3 / 188 / 793
    '09 F800ST
    Quote Originally Posted by Alfodr View Post
    Hello,
    How many miles on your bike? My ST did some of these things (false neutral 5/6 especially) when it was new, but within about 1000 miles it calmed down and has been fine ever since.
    One tip: when upshifting, preload the shifter with your toe before pulling the clutch lever. Just a little pressure seems to help a lot.
    The only symptom of yours that would worry me a bit is popping out of first. Don't be shy about shifting into first with a good solid movement of your boot -- not stomping, but also not "easing" it into gear. If this one persists, it's warranty time.
    -dan
    Blue '09 F800 ST: ABS, toasty grips, trip computer, center stand, sport panniers, Ventura luggage, Valentine 1, Garmin zümo 660 RAM mounted, Sena 20S, P3 LED tail lights, Grip Pups, Centech AP-1 fuse panel, Go Cruise control, Shoei GT-Air, Gerbing's jacket liner, MRA X-creen Sport.
    Points: 4,965, Level: 48
    Jack
    London, UK
    May 2012
    Hello,
    I occasionally get a false neutral between fifth and sixth gear but I think it's operator error. The gap between fifth and sixth just seems to me to a bit bigger than the gaps between the other gears so when I go to shift up to sixth if I don't consciously push it all the way up it sometimes drops back to fifth...
    Alfodr's Avatar
    Mauro Cantoni
    Cheltenham, UK
    Nov 2014
    '14 F800R
    Thanks all for the pointers and advice. Ill try preloading the shifter to see if that helps. To be fair the gearbox is fine most of the time; its just the occasional hiccup now and again. The bike has about 2000 miles on it, so still quite new, and well within warranty. If it gets any worse Ill ping another post on the forum.
    Thanks again.
    STARSHIP's Avatar
    Points: 6,790, Level: 57
    Derek
    Toronto, Ontario
    Jan 2013
    '11 F800R
    '11 F800R
    Sorry to ask but what boots are u wearing? Lots of miss-shifts can be attributed to boots that are clunky or too big and do not provide proper feel.
    Alfodr's Avatar
    Mauro Cantoni
    Cheltenham, UK
    Nov 2014
    '14 F800R
    I normally wear the BMW urban boots - they are fairly lightweight so I can feel through them quite well. I have found that if I position the shifter closer towards the centre of my foot (rather than the tip) I tend to get a better response. I'm still relatively new to biking, so with experience things will probably improve.
    trevor's Avatar
    Points: 39,299, Level: 100
    Trevor :-)
    Auckland, New Zealand.
    Nov 2006
    4,055 / 5 / 483 / 1418
    '14 F800GT
    '06 F800ST
    My St was horrible until I got heavy boots and it got run-in took about a year and I came from a K100RT.
    It's been said many times BMW use second hand tractor gearboxes, but on the plus side you could go million miles until they fail.
    My GT (which is the same as the R) was perfect (in a BMW way -which is nothing like a Japanese way) , but I've had two false neutrals in nearly a year, so infrequent I can count them.
    One thing to check is the lever has been setup correctly and is not catching on the casing or is sloppy in anyway. Check everything is tight as any slack will make an already clunky box even worse (I think somebody found the lever was slack on their new bike a few years back - so worth a check).
    Then it's "operator error"
    What's it like to bike around NZ? https://picasaweb.google.com/1043074...59485/BikeTrip
  14. #12
    Backliner's Avatar
    Points: 34, Level: 1
    Daniel Colchado Rodriguez
    Lima, Peru
    Mar 2017
    hello, i got a G650gs from dealer as "demo" (2016 with 1100 miles), when i got it i can't engage first gear or neutral, it was very difficult, representative personel said the same thing: "it maybe your boots" (i was gearing a Harley Davidson boots) i got all the f*** day having issues with first/second gear and neutral, after i take back the GS i test another from a friend (2012 with 15000 miles) and had no issues, same boots, same bike, after that dealer said to me it was an issue because it was a "demo" motorcycle, and it is wear as sh*t. I think it had a bad gear box. Now i'm thinking in acquire a F800r, i test 2 of it and rides like a silk, very smooth, i love it. Try 2, one 2014 with 6000 miles and one 2012 with 3300 miles, love both of it, now i want to test new version, i read a lot and find that gears are different, -2014 1st gear is very long (till 60mph) and 2015+ 1st is (very short) up to 20? it's that real? thanks in advance.
  15. #13
    danham's Avatar
    Dan H
    Harwich, MA
    May 2009
    '09 F800ST
    I have to wonder whether a simple clutch adjustment would have fixed the 650 GS.
    -dan
  16. Likes Gary liked this post
  17. #14
    Points: 97, Level: 1
    Mar 2021
    Hello,
    any idea why so diffficult to get back to Neutral. I can't do it with my foot !
  18. #15
    Mar 2021
    good to hear it supposed to be . my 2018 with 13km is impossible with feed to get it to Neutral ? All others ok . Something is amiss
  19. #16
    Mar 2021
    anything obvious to check to see why getting back to Neutral is so difficult ?
  20. #17
    Randyjaco's Avatar
    Points: 3,599, Level: 39
    Randy
    Friendswood TX
    '10 F800 ST
    '10 F800 ST
    '10 F800 ST
    Other than the 5/6 neutral my bike exhibits none of the problems you mention. In fact my ST probably has the best gear box of any bike that I have ever ridden. The 5/6 neutral is really annoying, but it is happening less now. I guess I have unknowingly modified my technique. The 1/2 shift is probably the least annoying of any of my previous bikes. I hope you find a solution.
    2010 F800ST
  21. #18
    Points: 10,668, Level: 71
    1,099 / 0 / 2 / 32
    Quote Originally Posted by thaied View Post
    Is your oil level between min/max? Anything outside of this can cause shifting issues. It is usually easier to shift into neutral from 2nd, as it only take a small amount of pressure to move.
  22. #19
    SamJones's Avatar
    Points: 60, Level: 1
    Mar 2021
    Non ho mai avuto una cosa del genere.
  23. #20
    Points: 2,924, Level: 35
    Preston UK
    Jul 2017
    '17 F800 GT
    Ive also had a couple of false neutrals between 5 and 6 - not a pleasent feeling!!! I have a 2 year old 800rs with around 4000 on the clock. My biggest problem is getting it in neutral. I have to do a bit of manovering to get it into my shed so am not releasing clutch fully and then can't get inti nuetral from 1st or 2nd.
