Wanted BMW G450X Long range tank and aftermarket seat - BMW F800 Riders Forum & Registry
Results 1 to 5 of 5
    Points: 256, Level: 5
    Charl du Plessis
    Wesatern Cape, South Afri
    Sep 2016
    Hi All
    I am looking for a long range tank and some sort of more comfortable aftermarket seat.
    Anyone got some to sell.
    I am in South Africa, so might be best to drop me a mail at [email protected]
    Thanks
    Impala's Avatar
    Points: 2,292, Level: 30
    Matt
    Yorkshire, UK
    Dec 2016
    '15 F800 GT
    Hi Charl,
    You may want to look at this for the fuel tank. You can get front mounted or rear mounted :-
    http://safaritanks.co.za/
    can't see anything for the G450X tho'. Their american site does though, so the SA branch may be able to order from USA.
    rear mount
    http://safaritanksusa.com/product_in...?products_id=2
    front mount
    http://safaritanksusa.com/product_in...?products_id=1
    Not sure about the seat though. It looks like sitting on a razor blade!
    Allroad's Avatar
    Points: 9,827, Level: 68
    Juha
    Finland, west coast
    Feb 2016
    '09 G450X
    '97 R1100GS
    '00 TT-R90E
    '09 G450X
    '07 R1200GS ADV
    From year 2010 forward the G450X seat model is a little more comfortable with a different profile and softer foam than the previous version had. You can check the part number underneath if you're not sure which version you have. I have a 2010 seat for sale and other seats also that could be easy to modify with some foam and cover to your liking
    Stangger1's Avatar
    Points: 1,004, Level: 18
    Be rad
    Ftmcmurray ab canada
    Apr 2018
    Where does the gravity feed line attach for the rear safari fuel tank.
    Allroad's Avatar
    Juha
    Finland, west coast
    Feb 2016
    '09 G450X
    '97 R1100GS
    '00 TT-R90E
    '09 G450X
    '07 R1200GS ADV
    Quote Originally Posted by Stangger1 View Post
    You attach it to the air breather near the original tank cap, the vacuum drains the fuel form the safari tank and the safari tank breather is then your new breather. So detach the breather hose from the original tank and that is where you put the fuel line from the safari tank.
