Static and rtace sag 2017 700GS Calcs - BMW F800 Riders Forum & Registry
Results 1 to 3 of 3
    Points: 1,323, Level: 21
    Merida, Mexico
    Jul 2017
    Hello all. Noob post.
    Looked for info on setting rear suspension preload/sag on new 700GS - not much to be found online. Here are my calcs so if anyone can set me straight - appreciated.
    - 170mm travel (2017 - from BMW site)
    - 30% race sag (static plus rider) so 51mm (30 percent of 170) preferred (I got this 30% number from several sources including Touratech (can't post link -
    too new - see below on how to find the article) because there are no numbers in the book or online for actual 700 race sag). I can't find a ratio for the 700 (135:65 for the 1200) so using the recommended 30%
    Unloaded - 377mm centre axle to to the grab bar)
    Static - 352mm (no rider, same points fo measurement)
    Static sag (pretty consistent - includes top box) = 2.5cm (25mm)
    So, if I have 25mm static sag and need need 51mm for prefect pre-load, correct race sag to (51-25) - 26mm with rider(s) - in other words, whoever is on the bike, the bike should go down by 26mm - so adjust preload to correct (obviously, with pillion rider, more turns to the right to achieve 26mm drop)
    Sound good? What do I have wrong?
    PS - I know what the book says - this is more an exercise in nerdism.
    PPS - to find the Touratech article, paste this into a google search and it's the first link "Touratech HOW-TO: SETTING SUSPENSION SAG"
  2. ThanksLag thanked for this post
    Points: 2,447, Level: 31
    Jake
    Central Utah
    Jan 2017
    I need to set up the girl friends 700 also, thanks for the info !
    Points: 2,043, Level: 28
    Thanks Andy, your work looks very good and has reminded me that I need to have a look at this as well!!
    Have you noticed any improvement since setting yours up?
