Its Running and riden! - BMW F800 Riders Forum & Registry
Results 1 to 21 of 21
    Stormbringer@53's Avatar
    Points: 3,853, Level: 41
    John Albone
    St Albans England
    Mar 2017
    Finally got the callipers and wheel on,
    took for a short ride .
    Still got a few small jobs to do .
    Points: 42,120, Level: 100
    9 Minutes Ago
    4,125 / 0 / 9 / 3
    Looking good!
    John Albone
    St Albans England
    Mar 2017
    Thanks .And may the forks be with you .
    steve n rose's Avatar
    Points: 60,630, Level: 100
    Steve
    Morwell, Vic
    Dec 2007
    10,701 / 8 / 151 / 893
    '10 F800ST
    Forking well done!
    As of Mon, 1st Feb 2016- ;
    Yesterday is history, tomorrow is a mystery,
    Today is a gift (that's why it's called "the present")
    #1 tip I ride by: Ride as though you're invisible, not invincible
    Bikes so far: Honda CB250-Traded, Suzuki GS500F-Traded, '07 F800ST Matt Graphitan-Deceased, '10 F800ST Night Blue-sold, at present bikeless
    John Albone
    St Albans England
    Mar 2017
    I took the air box and cam cover off yesterday ready to check valves clearance's.
    WildWilly's Avatar
    Points: 209,359, Level: 100
    SE Iowa
    19,827 / 15 / 214 / 1480
    You guys with the forks jokes, quit forking around.
    Looks good John.
    2013 F800GT Graphite Metallic
  9. Likessteve n rose liked this post
    Points: 13,614, Level: 80
    Congrats on accomplishing this. Very industrious of you.
    sweatmark's Avatar
    Points: 7,312, Level: 59
    Mark
    Oregon USA
    Aug 2009
    Quote Originally Posted by [email protected] View Post
    That setup should stop nicely. One-finger braking on my S1000, and glad I have ABS for those moments (when) I grab too much front brake.
    Now: R1150R Rockster, F800S, S1000R, K1300S
    Then: R850R, R1100R, R1150R, R1200C, Buell, usw
    John Albone
    St Albans England
    Mar 2017
    Got an R1200RS front mudguard today the last piece in the Jigsaw .
    Its all back together so just need to decide on a paint scheme.
    BMW F800S 2010
    BMW F800GS 2008
    John Albone
    St Albans England
    Mar 2017
    I could not get the brakes to bleed having filled up the calipers and 3 pipes that I had empty.
    I did the normal bleeding but the levers still came all the way back to the bars .
    I left the lever tied back to the bar overnight but still able to pull the lever all the way back to the bars ?
    Tried again last night but left bike on side stand instead of upright on padock stand .
    When I released the lever this morning I flicked the lever several times and hey presto out bubbled the air .
    Brakes working .
    Took the first test ride over to Lind Motorrad in Welwyn Garden City to show the guys who have done so much to help me with my project.
    The handling and braking are so much better but most of all the look is bang up to date .
    Also big thanks to James Sherlock BMW South Moulton Devon and Motorworks BMW Yorkshire.
    BMW F800S 2010
    BMW F800GS 2008
    John Albone
    St Albans England
    Mar 2017
    Its finished.
    BMW F800S 2010
    BMW F800GS 2008
    TelemarkTumalo's Avatar
    Points: 27,878, Level: 100
    Mark
    Bend, OR
    Oct 2011
    4,831 / 21 / 167 / 1251
    '16 R1200GS ADV
    '13 CRF250L
    Good on you John. Truly one of a kind. I dig it. Any plans for the rear suspension?
    WildWilly's Avatar
    SE Iowa
    Looking good.
  17. #14
    John Albone
    St Albans England
    Mar 2017
    Thanks .
    Yes ohlins rear shock .
    BMW F800S 2010
    BMW F800GS 2008
  18. #15
    Mokkybear's Avatar
    Points: 45,330, Level: 100
    Mark H
    Canberra ACT AUS
    Jun 2008
    2,396 / 5 / 154 / 637
    Brakes working ...
    The BMW maintenance manual recommends placing the bike with the steering to the left so the master cylinder is at highest, then short-pulling the lever to expel bubble. In the case of a full drain/fill, leaving it stand overnight n this position would allow time for any fine bubbles to make their way to the top.
    The result looks great, John - hope it serves you well!
    R1200R-LC ​Exclusive in Thunder Grey with Touring Pack. Formerly Graphitane F800ST 04/2007. I rarely visit the forum these days ...
  19. #16
    John Albone
    St Albans England
    Mar 2017
    I will add a sat nav bracket for my Garmin on the handle bar clamp .
    These F800R bars make the bike so much more comfy.
    BMW F800S 2010
    BMW F800GS 2008
  20. #17
    milago's Avatar
    Points: 4,249, Level: 43
    Nicolas
    Quebec City, Canada
    21 Hours Ago
    Excellent job, want the same set-up now....
  21. #18
    John Albone
    St Albans England
    Mar 2017
    I Rode to the National Motorcycle museum today .
    The new set up is so much better than the standard.
    Brakes are fantastic as is the handling with new forks .
    When using the heated grips they expand and rub on the bar end weight .
    Unwilling move the brake lever over a bit to cure the problem .
    I have also ordered the F800r brake pipe from the master cylinder as it is longer and will go under the bottom yoke rather than over it as the F800s one does .
    I have also got a new F800r clutch cable to fit .
    BMW F800S 2010
    BMW F800GS 2008
  22. #19
    John Albone
    St Albans England
    Mar 2017
    To the person that messaged me re the fairing its AC Shnitzer.
    BMW F800S 2010
    BMW F800GS 2008
  23. #20
    John Albone
    St Albans England
    Mar 2017
    My new project bike ,Almost done .
    BMW F800S 2010
    BMW F800GS 2008
  24. #21
    Points: 7,882, Level: 62
    Simon Humphreys
    Horsham West Sussex
    May 2011
    401 / 0 / 10 / 61
    '09 F800S
    Re bar end, remove, and insert washer between bar and bar to resolve the clearance with the grip. Worked on my S.
