Headlight mount bolts - BMW F800 Riders Forum & Registry
Results 1 to 6 of 6
    Tim
    Toowoomba QLD
    Jun 2009
    '09 F800GS
    When you get your bike home from the dealer, undo the headlight mount bolts and locktite them back in. Of the six I know who have 800GS'S, they have all come undone when riding rough terrain.
  2. Thanks Ebbs15 thanked for this post
    Brandon
    Biloxi Mississippi
    May 2009
    I've heard this too... though honestly... I'd be going over every bolt that isn't removed often for maintenance and locktite'n them... just to be safe...
    Crested Butte, CO owl is offline F800Riders.org Supporter
    owl's Avatar
    Al
    Crested Butte, CO
    Feb 2009
    220 / 0 / 27 / 29
    '09 F800GS
    Count me in as #7. Had to stop in the dark in Death Valley and fix them to continue on.
    Aug 2009
    That makes me #8.
    All in 180 miles offroad. (I had checked them all within about 200 highway miles.)
    The dealer nearest to me didnt have any in stock (and believe it or not, they only cost $1.78 each...must be bmw's cheapest part), so I did the hardware store fix.
    There are drawbacks to skipping the weird rubber grommets...I tightened everything down harder (on the road, don't have a torque wrench on me, so I can't be quantitative) because I didn't want it to happen again...and now I have cracked the windscreen around the leftmost side, currently (and probably always) being reinforced with duct tape.
    I didn't have TT's windscreen attachment on during the 180 miles offroad when I lost the screws, but I think I did when I cracked the windscreen. The extra weight definitely puts more leverage and torque on the screwheads.
    Points: 9,983, Level: 69
    Roy Barnes
    Pasco Wa.
    Jan 2009
    I removed the stock bolts and replaced them with hex head bolts so I do not have to remove the wind shield to check/tighten/ or adjust the lights.k A end wrench will fit in the space.
    I also used loctight. Blue.
    Riding for the SON
    Points: 875, Level: 16
    Sep 2020
    20 Hours Ago
    Old thread, but I'm on the side of the road attaching my headlight with rock straps right now and seeing if I can order a part to arrive for next week. Argh. Just came off road as well.
    Sent from my AC2003 using Tapatalk
Similar Threads
  1. bolts rattled loose from frame mount
    By pogi in forum F800S & F800ST Discussion
    Last Post: 05-10-08, 05:34 PM
  2. Recall: Tightness of engine mount bolts
    By Mouth in forum F800S & F800ST Discussion
    Last Post: 01-17-08, 05:39 AM
  3. Engine Bolts
    By BMW-Dick in forum F800S & F800ST Discussion
    Last Post: 07-01-07, 12:55 AM
  4. Loose Bolts
    By bdking in forum F800S & F800ST Discussion
    Last Post: 05-25-07, 06:38 PM
  5. loose bolts
    By Pancho in forum F800S & F800ST Discussion
    Last Post: 05-14-07, 07:05 PM
