Adjustment on front shocks? - BMW F800 Riders Forum & Registry
Results 1 to 8 of 8
    Points: 662, Level: 13
    Pittsburgh PA
    Seems that my front shocks just are too stiff. Minor bumps are hard hits. Had fork oil changed and new seals put in, helped a little bit this still seems not right.
    Are there any adjustments that can be made to increase damping ?
    Points: 157,199, Level: 100
    8,717 / 15 / 698 / 2031
    I have been extremely happy with the improvement in front fork action that occurred when I dropped in a set of RICOR Intiminator valves in the forks of my 2009 F650GS about 6 years ago. They were very easy to install and completely transformed the action of the fork. However, I have no idea if they make Intiminator valves for the GT, or if the company is even still in business.
  4. Likesl8_apexer liked this post
    Points: 675, Level: 13
    Parksville BC Canada
    May 2019
    '15 F800GT
    They are definitely still in business, I have used the Intiminator valves in both my last 2 Triumphs and loved the results. Not sure if they make them for the F800 series or not.
    2015 F800GT
    Pittsburgh PA
    Thanks. They don’t list anything for the GT on their site
    Points: 3,222, Level: 37
    Neville Goldsmith
    Nairn
    Oct 2017
    I've just fitted "Race Tech" Emulator Gold valves in mine, but their recommended set up ( Blue Springs, 4 hole valve plate and 15w oil ) didn't make them compliant enough for me, so I have now used the softer Silver spring with an additional short lighter spring as well, making the valve opening more progressive, and with 7.5w oil. I also modified the 4 hole valve plate by tapping out the four holes to 4mm and screwing in four "Cheese" headed screws that have 2mm deep heads. This gives a 2mm gap under the valve plate, instead of the holes, for low speed oil flow, while leaving the full surface area of the plate for larger oil flow rates to act on.
    I had done this same set-up in the forks of my Moto Guzzi 750 Breva earlier in the year, but I used YSS valves in that, which are virtually identical. The Race Tech ones come as a kit for the F800GT, but as YSS didn't do ones specifically for my Guzzi, I had to make up an adapter to fit on the top of the damper tube.
    In both cases these valves transform the action of the forks and you can play around with various springs and oil grades until you get the ride quality you want. Nev.
  9. LikesRoy Barnes, IanA liked this post
    Points: 352, Level: 7
    Marcus
    Singapore
    Dec 2019
    '15 F800 GT
    Quote Originally Posted by l8_apexer View Post
    Hi, how much fork oil did you put in each fork? I couldn't find any info regarding the amount of fork oil needed for the GT. is it the same as the ST, 520ml per fork?
    STARSHIP's Avatar
    Points: 6,790, Level: 57
    Derek
    Toronto, Ontario
    Jan 2013
    '11 F800R
    '11 F800R
    I recall that the measurement from the top of tube should be 120 mm without the spring and fully compressed. This way you can make certain that both tubes have the same amount of fluid. There are several threads on here.
    The Mariner's Avatar
    Points: 3,041, Level: 35
    Adelaide, Australia
    Nov 2017
    '09 Drz400sm
    '09 F800R
    If minor bumps are hard hits you need to decrease compression damping, not increase it.
    Regards,
    Phil.
