F800R Display Brightness. - BMW F800 Riders Forum & Registry
Results 1 to 5 of 5
    Blackieburger's Avatar
    Points: 799, Level: 15
    N Yorkshire Moors
    Aug 2019
    Is it possible to adjust the display screen brightness, I can't see any mention in the handbook. I could do with it a bit brighter at night.
    Thanks
    RobA is offline F800Riders.org Supporter
    Points: 1,370, Level: 21
    Rob
    Rugby UK
    May 2019
    '14 F800R
    I don't think it can be changed. The intensity of the brightness is controlled by a small sensor on the dash. One possibility is to put a small piece of black tape over the sensor which should give you full brightness all the time. Rob.
    N Yorkshire Moors
    Aug 2019
    Thanks RobA. appreciated.
    Points: 5,793, Level: 52
    Quote Originally Posted by RobA View Post
    I think that is backwards.....if the sensor doesn't sense any light and believes it is dark - it will likely make the dash run in the dim mode all the time. Does the dash light on the bike change from day to night?
    N Yorkshire Moors
    Aug 2019
    Yes, the display goes a sort of orange at night. A bit disappointing that it can't be altered. probably to keep the cost down?
