F800GT valve clearance - BMW F800 Riders Forum & Registry
Results 1 to 31 of 31
    Points: 534, Level: 10
    Marcus
    Singapore
    Dec 2019
    '15 F800 GT
    Hi guys, I know such topics may have been discussed intermittently in other threads (I did my homework in searching the forums!) but I thought I'd just start another thread to gather more statistics regarding valve clearance/adjustments or the need of it. Perhaps you guys can share your experiences here in the below format
    Bike/Year:
    Current Mileage:
    Done valve clearance check at which mileage: ##,### km / never
    Bike usage: %highway/%city
    Average cruising speed:
    Gear shifting RPM:
    Fuel consumption:
    If done VC check, need to replace shims, and how many? Yes/No; 1-8
    If shims replaced, what improvements/restoration observed:
    Other remarks:
    I'll start
    Bike/Year: 2015 F800GT
    Current Mileage: 31,000 km
    Done valve clearance check at which mileage: never
    Bike usage: 90% highway/ 10% city
    Average cruising speed: 90-100 km/h
    Gear shifting RPM: between 3000-4000 rpm
    Fuel consumption: 24-25 km/l
    If done VC check, need to replace shims, and how many? not applicable
    If shims replaced, what improvements/restoration observed: not applicable
    Other remarks: May not consider doing VC check so long as there's no significant decline in my fuel consumption from current state.
  2. ThanksDaboo thanked for this post
    LikesDaboo liked this post
    Points: 49,054, Level: 100
    13,271 / 8 / 110 / 2177
    It's a bit involved inquiry. My 08 ST had the valves checked at the prescribed interval until 24K miles. The dealer said no adjustments were made so I didn't have it done again until a deer killed the bike at 57K miles. The mileage was good, up to 72.9 mpg, in Colorado.
    Basically your last line was my feelings. If it ain't broke don't fix it.
    Points: 43,864, Level: 100
    4,193 / 0 / 9 / 3
    Bike/Year: 2014 F800GT
    Current Mileage: 25,000 miles
    Bike usage: 50% highway/ 50% city
    Average cruising speed: 35-70 mph
    Fuel consumption: 51 mpg
    If done VC check, need to replace shims, and how many? none
    Marcus
    Singapore
    Dec 2019
    '15 F800 GT
    oh deer (pun intended), was the deer alright? and more importantly, were you all right? 72.9 mpg is insanely good consumption thou.
    Points: 2,142, Level: 29
    Bike/Year: 2016 F800GT
    Current Mileage: 23,900
    Valve Clearance Checked: 12,000 miles not sure if adjustments were made
    EDIT: 24,000 miles:Intake 0.20 0.20 0.23 0.20 Exhaust 0.20 (set to 0.33) 0.30 0.30 0.30
    Seems to be a bit stronger now but not dramatically.
    Gear Shifting RPM: Having fun - at redline, otherwise 5,000 to 6,000RPM
    Bike Usage: 50% fast road/interstate 45% secondary road 5% city
    Average Cruising Speed: Interstate 80MPH or flow of traffic, Secondary Road - speed limit/flow of traffic
    Fuel Consumption: Low of 40MPG, High of 65 to 70MPG
    Will take it in for 24,000 mile service in January. Waiting to get thru crazy busy season at dealer. They will check valves, replace the drive belt etc.
    EDIT: Kept the old belt as a spare - no cracking or noticeable detonation, can tell its been run for a while but I wouldn't hesitate to put a lot of miles on it.
    4,193 / 0 / 9 / 3
    ... replace the drive belt etc.
    I'd save the belt. It would make a nice spare.
    Sundog52's Avatar
    Points: 5,365, Level: 50
    Geoff
    Birmingham in Alabama
    '94 R1100RS
    Bike/Year: 2013 F800GT
    Done valve clearance check at which mileage: 12,000 miles
    Bike usage: 60% highway/ 40% city
    Average cruising speed: 35-75 mph
    Fuel consumption: 52 mpg
    If done VC check, need to replace shims, and how many? not sure if adjustments were made
    Sundog
    MinnesotaF800GTRider's Avatar
    Points: 396, Level: 7
    Oct 2019
    '91 907 Ie [ Paso ]
    '13 S1000RR
    Current Mileage: 12,400 miles
    Valve clearance check at which mileage: 12,000 miles
    Average cruising speed: 65+ mph
    Gear shifting RPM: between 6000+ rpm
    Fuel consumption: high 40s mpg
    If done VC check, need to replace shims, and how many? 2 shims at min clearance, one close. Purchased 3 shims, shifted around others to place all valves at max clearance
    If shims replaced, what improvements/restoration observed: personally, I don’t think a few thousandths of additional clearance will be noticeable in the seat of the pants.
    Other remarks: I don’t think my local dealer does many valve adjustments on these. The parts department didn’t even know what a semi-sphere was. I had to special order the shims. If you decide to replace shims, make sure to lock the crank in place during cam re-installation, and double-check the valve timing by manually turning over while tensioned. It took me three tries to get the cams correct.
  12. LikesDaboo liked this post
    Good idea, hadn't thought about that. Thanks
    Points: 3,775, Level: 40
    Dahlonega, GA
    Sep 2018
    Interesting discussion. My 2014 F700GS is coming up on 10,000 miles, and I think I will just bypass the 12,000 mile valve check and expensive service visit. I still have a 1999 RT, for which valve adjustments are fairly trivial (and rarely needed), but the F-bike engine is an entirely different beast.
    paul sternburg
    thousand oaks, ca.
    Jan 2009
    2009 f650gs with 42,000 miles. Valves were checked by the bmw shop at the 12,000 service with no adjustment needed. I checked at 24,000 miles and they were within specs. I checked again at 36,000 miles and had little or no change. I think I’ll skip the 48,000 mile check.
    paul sternburg
    thousand oaks, ca.
    Jan 2009
    I should add that I’ve done a lot of 5,000 rpm miles pacing my buddy’s 1200gs. And while passing traffic on 2 lane roads I run at 5000 rpm plus for the best full throttle acceleration. Gas mileage is generally 55 mpg but goes to 60 plus with more moderate speeds.
  17. #13
    RoadRogue's Avatar
    Points: 6,340, Level: 54
    JR
    Eagle, WI, United States
    Feb 2012
    '19 F750GS
    '14 R1200GS
    '07 F650GS (Single)
    This is a great topic and it's interesting to hear everyone's responses. I'll add a couple of bikes to this story but they're not all F800s. My 2009 F800ST had 29,000 miles on it and I believe I checked it at 20. It didn't need any adjustment.
    I have a 2007 F650GS with 80,000 miles on it. I checked the valves about every 25 to 30,000 miles. It needed two shims at 40,000 and it needed all 4 shims at 75,000.
    My 2014 R1200GS Had 45,000 miles on it until the alternator fried this year and I traded it for an F750GS. I checked the valves every 20,000 and they were always in spec.
    it turns out all three of these bikes take the same 10mm shims. The first time I changed shIms I bought the individual shims. The next time I went on eBay and bought a kit for about $70. Considering the shims work on all the motorcycles I think it's a deal. No more running back to the shop if (when) I made an error in measurement.
    Unfortunately all of the bikes are shim under bucket instead of shim over bucket. Even though they're easy to check, The camshafts must come out to change any of the shims.
    On a sidenote, I had a K75RT That I put over 110,000 miles on. At 50,000 miles I change two shims and at 100,000 miles I put the same two shims back in the same valves. The net valve adjustment over all of those miles was zero. After having many Bikes with nut and screw tappet adjustments, I have to say that the shim system truly lowers valve adjustment intervals but they make you work for it!
  18. LikesRichard230, Albervin liked this post
  19. #14
    Marcus
    Singapore
    Dec 2019
    '15 F800 GT
    Quote Originally Posted by MinnesotaF800GTRider View Post
    so it's always better to err on larger clearance than smaller clearance?
  20. #15
    Marcus
    Singapore
    Dec 2019
    '15 F800 GT
    On another related topic, has anyone had their F800 (or other bikes)'s engine blow up or anything catastrophic because of bad valve clearances?
  21. #16
    Points: 5,064, Level: 48
    Steve Clarke
    Bay Village, OH
    May 2013
    Current Mileage: 60,000 mi
    Bike usage: 60% highway/ 40% back road twisties
    Average cruising speed: when I cruise: 75 mph
    Gear shifting RPM: between 3500 - 6500 rpm
    Fuel consumption: avg 53 mpg
    Other remarks: No noticeable decline in performance, still runs, idles very smoothly
  22. #17
    bembura's Avatar
    Points: 4,337, Level: 44
    Damir
    Boulder, CO
    Jan 2016
    16 Hours Ago
    Quote Originally Posted by RoadRogue View Post
    Could you please share some info on the shim kit you found on ebay?
    F800 shims are spherical and don’t look anything like regular shims.
    Thanks!
  23. #18
    RoadRogue's Avatar
    JR
    Feb 2012
    '19 F750GS
    '14 R1200GS
    '07 F650GS (Single)
    Quote Originally Posted by bembura View Post
    Thanks!
    Hi Damir,
    After some searching, I found my purchase was on Amazon, not Ebay. Here's the link:
    Wiseco VSK3 Premium 10.0mm OD Valve Shim kit https://www.amazon.com/dp/B0065739LY..._6-FcEbF4TPNSH
    I'm not familiar with the "spherical" shims you mention since I've never had to replace the shims on my F800ST nor the F750GS, so the listing may not be correct for those bikes. These shims from Amazon fit my 2007 F650GS (single) and my 2014 R1200GS LC (wet head).
    Out of curiosity, what do spherical shims look like? The shims I've used on all my bikes with shims (over or under) all looked like flat-sided coins of various diameters and thicknesses. Maybe someone can share a photo, meanwhile I'll have to do some homework. The Amazon listing includes photos of the standard 10mm shims I used.
    Thanks for the heads up on the different type of shim for the newer F bikes. If you find a listing for them, please post! I hope the link can help some other owners out.
  24. #19
    GTOz's Avatar
    Points: 601, Level: 12
    Ric
    Perth WA
    Jul 2019
    23 Hours Ago
    '18 F800 GT
    '01 R1100S
    The spherical shims fit a number of bikes;
    https://www.realoem.com/bmw/enUS/sho...diagId=11_4003
  25. #20
    RoadRogue's Avatar
    JR
    Feb 2012
    '19 F750GS
    '14 R1200GS
    '07 F650GS (Single)
    Quote Originally Posted by GTOz View Post
    Thanks for the diagram and parts listing! I try to keep learning but it doesn't seem to help . . .
  26. #21
    RoadRogue's Avatar
    JR
    Feb 2012
    '19 F750GS
    '14 R1200GS
    '07 F650GS (Single)
    I just used your provided link to check shims for the 2019 F750GS and they look like the usual disk-type. It doesn't mention diameter but I'm guessing they're the same 10mm used on many other models. Maybe my shim kit will live yet another life.
  27. #22
    bembura's Avatar
    Damir
    Boulder, CO
    Jan 2016
    16 Hours Ago
    Thanks!
    Hi Damir,
    Yup, f650gs single uses standard disks while gt uses these half spheres.
    So far I haven’t be able to find shim kit for gt.
  28. #23
    Points: 11,198, Level: 73
    And just to really mess with your mind in the service manual BMW calls them "oil sinks".
  29. #24
    Womble's Avatar
    Points: 4,280, Level: 44
    Adrian
    Somerset, UK
    Mar 2017
    Bike/Year: F800GT 2014
    Current Mileage: 18,000 miles
    Bike usage: 90 highway/10 city
    Average cruising speed:50-60 on A roads, 80+ on motorways
    Gear shifting RPM:4,500rpm
    Fuel consumption: 65 imperial mpg
    If done VC check, need to replace shims, and how many? Yes/No; 1-8 -N/A
    If shims replaced, what improvements/restoration observed: N/A
    Other remarks: Decided not to bother at 12,000 miles, will leave until 24,000 then decide, though may change the bike before then
    No immediate intention to change the belt at 24,000 miles either nor have I changed the spark plugs at 12,000 miles... must just be mean
  30. #25
    24,000 mile service recently completed, edited my original post to include new clearances
  31. Likessilvermoon1407 liked this post
  32. #26
    rhugh02's Avatar
    Points: 326, Level: 6
    Robert
    Rocklin, CA
    Feb 2020
    I just made a post about the 12K service, I was given a service quote of $1,300.oo bucks... OUCH! I already changed the oil, air filter and I can change out the coolant myself. I think the valve check/adjustment will have to be left as is. If it ain't broke!
  33. #27
    emlevy's Avatar
    Points: 14,196, Level: 82
    emlevy
    Evergreen, CO
    1,886 / 2 / 6 / 59
    Since you’re not the original owner and don’t know the bike’s history, it’s possible your engine spent a lot of time at redline. If so, a valve clearance inspection could be money well spent. Or not.
    I’ve never taken my GT over 5000 rpm and am in no hurry to have my clearances checked.
    2013 BMW F800GT | 2015 BMW R1200RT | 2014 Honda CB1100 DLX | 2019 Honda Monkey
  34. #28
    Points: 1,843, Level: 26
    '17 SV650
    '13 F800GS
    Quote Originally Posted by rhugh02 View Post
    That seems excessive. My shop told me that's what they charge for a 'major' service. i.e. the one where they do everything in the book. Parts are extra of course (oil, gaskets, plugs, etc), but we're even talking fork service at that price. FWIW, that's in the Bay Area so it's not like we're talking small town pricing here either. Just a valve check should be closer to $600 if they measure out ok, add another $200 or so if they need to make adjustments.
  35. #29
    Albervin's Avatar
    Points: 6,126, Level: 53
    Alyn
    Wollongong. NSW. Australi
    Jan 2014
    I really wonder about the BMW service schedule. It is not like they are 1990s Ducatis. I told my mechanic at the last service I "may" have a valve check at 50,000Km. He said that he was OK with that as he has NEVER had to re-shim an F800GT.
    What I DO find amazing is people saying they are getting over 70 mpg. I have never come close. I can just about hit 60 mpg (Imperial) on a lazy tour otherwise it is more like 50 mpg. These figures are converted from l/100km.
    I have rarely needed to rev above 5,500 in the intermediate gears as I think the torque is sufficient. I guess I am old school because my old OHV V twins max out at about 5,500.
  36. #30
    Points: 167,771, Level: 100
    9,110 / 15 / 698 / 2031
    I average around 65 mp(US)g while riding my F650GS and that is with 10% ethanol fuel. The few times I have managed to find E0, my gas mileage went up to 70 mpg.
  37. #31
    emlevy's Avatar
    emlevy
    Evergreen, CO
    1,886 / 2 / 6 / 59
    I can’t get less than 70 mpg on my F800GT. It’s thanks to the elevation of the roads that I ride (10,000’ +).
