Break in suggestion / first service should I do or dealer? - BMW F800 Riders Forum & Registry
Results 1 to 5 of 5
    Points: 505, Level: 10
    Philly Suburbs, PA
    Jan 2020
    '17 F800GS
    Any suggestions on Break - in? New bike.
    Also, should i perform the first service or let the dealer do the first one.
    Points: 43,864, Level: 100
    24 Minutes Ago
    4,193 / 0 / 9 / 3
    Ahhh...an oil thread, sort of.
    My suggestion is to ride it like you plan to ride it the rest of its life with you.
    I had a new bike once and took that route. I found it used just a wee bit of oil...so little that by the time I needed to add any, it was time to change it. A couple years later, I bought another of the same bike. I followed the Motoman method of revving it hard and backing off, over and over and over again for the first 20 miles or so. Basically, "ride it like I stole it." I found it used just a wee bit of oil...so little that by the time I needed to add any, it was time to change it. Does that last sentence sound familiar?
    Bottom line is it didn't make any difference at all.
    As for having the dealer do the first service, I'd say it depends on what they do. You can go through checking torque on the bolts as easily as he can and I find it fun to "bond" with my bike that way. Changing the oil is no big deal. Anyone can do that. If...and that's a big "IF", they check the valves...then I'd have them do it. But to just do a simple oil change? Nah.
  4. Likesnotacop liked this post
    Points: 167,771, Level: 100
    9,110 / 15 / 698 / 2031
    It has been my experience with the BMW boxers that if you break them in too easily, the rings will not seat-in properly and the engine will burn oil for the rest of its life. Don't be afraid to use the throttle and run up and down through the revs. Just keep the rpms below the recommended limit during break-in per the owner's manual. If anything goes wrong during the first 600 miles the dealer might claim it was the result of exceeding the rev limit. On some bikes the how many times you exceeded the limit during the break-in period gets lodged in the computer as a fault.
  6. Likespadaek liked this post
    padaek's Avatar
    Points: 13,668, Level: 80
    Jurgen
    Shellharbour Australia
    Nov 2016
    1,044 / 0 / 0 / 0
    '19 Super Cub C125
    '02 Sprint RS
    '90 Le Mans
    '15 F800R
    Run your new bike in as you'd normally ride it. Don't bounce it off the rev limiter though. Vary the engine speed as much as possible but try not the lug the engine.
    About the first service, get it down by the dealer you bought it off. Depending on the country and/or manufacturer, you could void the bike's warranty if the dealer doesn't perform the first service. Get your service manual stamped.
    Philly Suburbs, PA
    Jan 2020
    '17 F800GS
    Thanks. Plus the other advantage is that dealer can reset the maintenance reminder.
  10. Likespadaek liked this post
