Puig Hugger on an ST - BMW F800 Riders Forum & Registry
Results 1 to 11 of 11
    Panuno's Avatar
    Points: 6,696, Level: 56
    Peter
    Suffolk, UK
    Just fitted this Puig Hugger for the GT on the ST.
    Quite a bit of f***ing about to actually get it to fit, and fit well, but worth it I think.
    Thank god I have a workshop and machines I can make bits with, would have been even more of a pain without it.
  2. ThanksDaboo, Superduper thanked for this post
    LikesCheesy rider, padaek liked this post
    Cheesy rider's Avatar
    Points: 5,866, Level: 52
    Mouse
    Brooklyn ny
    Oct 2014
    '07 F 800 ST
    '06 K1200S
    '16 Thruxton
    '75 CB750-4 S/S
    '07 F800 ST
    And that’s why everyone don’t have one. It certainly was not a plug and play.
  5. Likesccramerusc, Panuno liked this post
  6. #3
    Points: 3,765, Level: 40
    Peterborough, cambs
    Went straight on to my GT.
    Other than a fiddle to fit the swinging arm bolt (changed for a hex head screw), fitting was no problem
    Panuno's Avatar
    Peter
    Suffolk, UK
    That's because it's made for a GT, not an ST
    It's a LOT of fettling to get it to fit. I had to make a new stepped washer with an eccentric hole (offset 4.25mm if anyone needs to know..), re-machine 2 mounting holes, and make a reinforcing bracket out of 3mm thick spring steel. As I said, lucky I have a workshop (machine shop) to make the bits in.
    I do think it's the best of the available huggers though, looks OEM on the ST & the GT
    Randyjaco's Avatar
    Points: 1,204, Level: 20
    Randy
    Friendswood TX
    So what does the hugger actually do for your ST?
    2010 F800ST
    Panuno's Avatar
    Peter
    Suffolk, UK
    Quote Originally Posted by Randyjaco View Post
    It's like a secondary mudguard. Keeps water/stones/debris/dirt from being flung up against the fuel tank and the shock.
    We get a lot of rain over here and debris washed on to the road by the rain, and the back tyre does pick stuff up and fling it against the underside of the tank and elsewhere.
    This will help minimise that.
  11. LikesDaboo liked this post
  12. #7
    Buzzz's Avatar
    Points: 1,379, Level: 21
    Laurent
    Belfort (France)
    Oct 2018
    Quote Originally Posted by Panuno View Post
    Nice addon.
    Would you mind selling a fitting kit? How much would it cost?
  13. #8
    Panuno's Avatar
    Peter
    Suffolk, UK
    Quote Originally Posted by Buzzz View Post
    Nice addon.
    No, just like doing bits for myself now.
    You can everything you need with a hacksaw, a drill, a couple of files, and some patience. Just take your time, others have done using just those things.
  14. #9
    Buzzz's Avatar
    Laurent
    Belfort (France)
    Oct 2018
    OK, I thought it was more complicated than that. 🙂
  15. #10
    MGD109's Avatar
    Points: 2,790, Level: 34
    Lancashire
    Apr 2018
    I fitted a rear hugger to my GT and I'm still surprised how much still gets past it especially this time of year in the UK. Would love something like this that appears to be original on the Ducati SS
    I like the way it wraps around the wheel.
    Sorley missed Honda TLR200
    Enjoy the ride
  16. #11
    Points: 8,367, Level: 63
    I think as much as they can stop stop debris getting thrown up, they probably cause areas of low pressure and vortexes causing the same mud, water, crud to be thrown all over the place.
    The main place I see that gets coated is the inside of the exhaust, link pipe & swingarm that sit directly in front of the rear wheel. The spray up the rear of the bike is inevitable and will only be prevented with either the standard rear plough, or a rear wheel guard like on a GS or Multistrada. I'm more tempted to try something like that if I can figure out a way to fit it.
