DOT Helmet Failure Rate Is Now 43 Percent - BMW F800 Riders Forum & Registry
Results 1 to 11 of 11
    Points: 40,496, Level: 100
    4,048 / 0 / 9 / 3
    Interesting article.
    __________________________________________________ _________
    MOTORCYCLE NEWS
    WADE THIEL FEBRUARY 7, 2020
    In The Government’s Own Sanctioned Testing
    The National Highway Traffic Safety Administration (NHTSA) employed Act Labs—an independent lab in California—to test DOT helmets for labeling and performance from 2014 to 2019. During that time, the lab tested 167 helmets. 62.8 percent of the helmets failed the labeling portion and a whopping 43.1 percent of the helmets failed the performance tests. This is an increase over last year’s numbers.
    This is especially concerning because DOT approval is a self-certification process, meaning the company itself is responsible for ensuring that its helmets mee the U.S. Department of Transportation Federal Motor Vehicle Safety Standard 218 (DOT FMVSS 218).
    Helmets that fail the testing will be forced to issue a recall and potentially be fined. This is good, but those helmets never should have been sold in the first place. There’s a lot of argument out there about what is the best helmet safety standard. ECE is what’s used in Europe. Then there’s SHARP, Snell, and FIM standards. They all claim to be the best.
    I’m not here to argue which standard is best.
    What I am here to do is showcase that many of the DOT-only helmets for sale out there fail to meet the standard, which is a standard many in the industry agree is already outdated and doesn’t provide the level of protection needed for riders. However, around 43 percent of the helmets tested couldn’t even meet these inadequate standards.
    Act Labs tested Bell, Scorpion, Shoei, and HJC helmets as well as many other helmets. You can see which ones failed the tests by checking out the Office of Vehicle Safety Compliance website.
    So what should you do?
    At the very least, I’d check at the website above to see if a helmet you’re considering was tested and passed the testing. You could also consider buying a helmet that has been approved by one of the other helmet safety standards out there. Snell and FIM standards seem to me to be the best. The bottom line? DOT means pretty much nothing. Don’t trust it.
  2. ThanksMGD109 thanked for this post
    4,048 / 0 / 9 / 3
    The easy way to do the database search is to chose "218" as the test in the far left column. Then pick your helmet brand from the next column over. Below the table is a button labeled "LIMIT TEST". That'll bring up the results.
    MGD109's Avatar
    Points: 2,585, Level: 32
    Lancashire
    Apr 2018
    That's actually quite shocking, find it difficult to believe manufactures can self certificate.
    I always check any prospective helmet with the UK SHARP list, but a helmet has to be on sale BEFORE it can be tested which to me is just madness.
    Sorley missed Honda TLR200
    Enjoy the ride
    Points: 156,997, Level: 100
    8,704 / 15 / 698 / 2031
    Well, I am not surprised. While I am concerned about the performance failures, the problem about labeling not being correct doesn't faze me in the least, as long as it says "DOT" on the back of the helmet to keep the cops happy.
    Points: 48,095, Level: 100
    12,927 / 8 / 110 / 2177
    Well, for what it's worth, I destroyed a Shoei RF200 and a Scorpion 1000 crashing and my head survived reasonably well those two times.
    There's DOT, Snell and the European rating. DOT being the least trustworthy?
    Points: 13,314, Level: 79
    It's an issue of practicality (testing literally millions of products in a few central facilities) while maintaining innovation in the market and managing taxpayer expense.
    If you think DOT is abused, you'll never plug in an electrical device if you knew of the abuse of UL.
    The manufacturer maintains the model number of the product so as not to require further testing. But the electrical guts change over time. Meaning the original certification does not relate to the current product. Or, the UL is stamped without any testing. Or the UL is used across multiple products from the same company.
    It's all a calculated risk - manufacturers know that the sheer volume of items in the market place make enforcement nearly impossible.
  10. LikesRichard230 liked this post
    Points: 4,888, Level: 47
    Ken Wright
    Workington Cumbria
    Jan 2016
    Strangely I still value what is left in my brain, hence if I buy a helmet I like to know it is better than a tea pot cosy. 'Sharp' testing helps to get us the best value for money as it isn't necessarily the most expensive helmets that offer the best protection. However I sadly have an 'expensive head' as none of the cheap helmets seem to fit me!
    zulujams's Avatar
    Points: 6,007, Level: 53
    Jason
    MA
    Jul 2014
    Interesting. I checked out HJC as brand 'HJC Helmets' which only brings up one result (which passed). Brand 'HJC' brings up 26 models, some that passed and some that failed. My current helmet is an RPHA ST. The only possible match is an RPHA 90 but this is from 2019. I bought the ST at least 2 or 3 years ago. Looks like mine has never been independently tested. I think I'll go with a SNELL or other certification next time around. Thanks for posting this.
    used 2004 R1150RT -> new 2014 F800GT
    4,048 / 0 / 9 / 3
    One of the things they said, was that if the helmet failed in testing, the company would replace it. I expect that a company as well known as HJC, would stand behind their product.
    Points: 638, Level: 12
    FWIW I looked up my current helmet, a Shoei GT-Air. Fairly well-rated most places, and the most expensive piece of gear I own, but somehow it *failed* the DOT testing!
    I was shocked until I looked at the report. It failed because the date of manufacture sticker wasn't as permanent as the testing regulations prescribed.
    TheMeteor's Avatar
    Points: 30,536, Level: 100
    Gerry
    Central NJ
    Jul 2008
    32 Minutes Ago
    3,798 / 10 / 423 / 559
    '09 F800ST
    When there self-certification there will be abuse. What surprises me is the number of respected name brands on that list. I did not expect that.
    I am going to check my helmets when at my computer later (reference link GUI very small on the mobile phone) to see how they fared. I actually have an RPHA Carbon on order since December. Revzilla says HJC has delayed shipments until April.
    2009 F800ST (Night Blue Metallic) l 1999 SV650 (Naked & Red) l 2016 GSX S1000 (Naked & Blue)
