Lamp warning - BMW F800 Riders Forum & Registry
Results 1 to 6 of 6
    Points: 659, Level: 13
    Stourbridge west Midlands
    Nov 2016
    Hi all, my bike is a 2016 model. I recently washed it and it's now showing a lamp fault, all the lamps are fully functional. This is still showing after a few weeks, has any one else had this issue? I'm guessing I got some water into a connection which is giving the fault I'm wondering if dropping the power to the battery will sort it.
    Many thanks
    Points: 2,072, Level: 28
    Guenther
    Colorado Springs, CO
    Nov 2017
    '17 F700GS
    It's in your Owners Manual: If the the light bulbs/LEDs have been fixed then a restart of the bike should clear the LIGHT fault indicator.
    Did you check low+high beam lights, parking light, brake/tail light and all turn lights?
    /Guenther
  4. LikesDaboo liked this post
    Points: 784, Level: 15
    Mclean, VA
    '08 F 800 ST
    Quote Originally Posted by CARL2477 View Post
    Many thanks
    Could be a valid signal in that a bulb or wire got loose somehow: in that case guenner is right and you too in maybe dropping power to the battery will solve it. Or it could be that the water just needs to dry up, in that case an excuse to take it for a ride
    Points: 7,702, Level: 61
    Check the little "sidelight" that's next to the main headlight. Mine has gone out twice and it's hard to notice when it's out.
  8. Likesruffyz liked this post
    MGD109's Avatar
    Points: 2,811, Level: 34
    Lancashire
    Apr 2018
    The other one, if nothing is obvious, is the tail light bulb. If it fails a reduced voltage is sent to the brake light filament so that shows as a normal tail light it looks as though nothing is wrong.
    Sorley missed Honda TLR200
    Enjoy the ride
  10. Likesruffyz, padaek, oxytotl liked this post
  11. #6
    Guenther
    Nov 2017
    '17 F700GS
    Disconnecting the battery is really not necessary. It requires to reset the date either by the dealer or a GS911 kind of tool.
    /Guenther
