Relocating the front turn signal lights - BMW F800 Riders Forum & Registry
Results 1 to 24 of 24
    Points: 519, Level: 10
    Feb 2020
    Hey All,
    I'm about to procure a 2007 F800ST, and a bit worried about the lower fairing - more attention than I would like for where I live, a lot of cheddar if it drops.
    I would like to remove them while I'm learning the bike, and use them for weekend touring gigs. They look easy enough to remove and replace with the torx screws, but I'm not sure what to do with the signal lights.
    It occurred to me to maybe attach them to the sides of the windscreen, which I don't mind poking (It's a dark non-OEM one from the previous owner).
    In such scenario, what do you do if the electric wire leading to the turn lights isn't long enough to reach the windscreen? Is there another BMW with longer wires that I can procure? Is generic wire good? I heard beemers won't start for any but their own parts..
    Another thought was to get simple one-sided handlebar wind protectors, and connect led strips to them which will run independently. This way (I figure?) it would be possible to restore the original turn lights, just by reattaching them to their original wires.
    I can't add a link or image, for they run for 10$ on ebay, and the leds aren't pricey as well.
    If I have all the parts, I can probably just ask a BMW mechanic to set it all up. Not sure what's the move though..
    What would you advise? Would generic LEDs even work on the beemer?
    Sorry if this sounds silly, I haven't modded any electric related bike parts before
    Points: 6,633, Level: 56
    Lansing, Kansas
    Aug 2012
    '12 F800ST
    Kaz, welcome from the coast of Kansas.
    And since you asked: yes, it sounds silly to me. But lots of mods that folks do to their bikes sound silly, and unnecessary, to me. Hope you enjoy the result, however it turns out.
    Royce
    On the coast of Kansas
    2012 F800ST
  4. Likeskaz liked this post
    MGD109's Avatar
    Points: 3,258, Level: 37
    Lancashire
    Apr 2018
    12 Minutes Ago
    If you are changing indicators you will need to replace with something of similar current draw otherwise the bike will register a fault (extending the wires will not cause an issue). ST was available with either halogen as standard or LED as an option. The bikes "ECU" has to be set to the correct one either at a Dealers or by using one of the ECU readers. The electrical socket for the indicator is BMW specific but is available just not sure where. If you don't like the lower fairing why not get an S? As for Cheddar it's a fine cheese but I would urge anybody that's looking to invest in some new cheese to try the Red Leicester that Aldi currently stock. I'll go so far as to say it's the finest hard cheese I have ever tasted.
    PS Welcome.
    Sorley missed Honda TLR200
    Enjoy the ride
  6. Likeskaz liked this post
    Feb 2020
    Quote Originally Posted by Royce View Post
    Thanks
    PS Welcome.
    Will the ECU maneuver you mention work only for bmw LEDs, so I would need to procure and extract them from those upgraded bulbs? Is the socket you mention part no. 65?
    I actually prefer the ST, as the lower fairing may come handy on long trips, while removing it also removes all the beemer bling if I want to go more low-key. Also, they were only a handful of these sold in Israel, there are mostly GSes around here (I actually stumbled on the ST when looking at 2nd hand bike ads, and was quite surprised).
    Will definitely look up Leicester cheese in Aldi on my next sally to Cyprus
    MGD109's Avatar
    Lancashire
    Apr 2018
    12 Minutes Ago
    Quote Originally Posted by kaz View Post
    The halogen bulbs are 10 Watt, I don't know what the current consumption is for the BMW LED units (OEM LED indicators are complete indicator units not replacement bulbs in the halogen lamp holder) but it will be a lot less. The bikes "ECU" (I'm not actually sure which of the bikes electronics modules it is but I'm sure somebody will let us know the correct one in due course) is set to either halogen or LED it is then expecting a certain current draw when you use the turn signal (20 Watt in the case of halogen, less in the case of LED) and if there is too much variance from what it is expecting it will show an error, in the case of too much current it will also shut the power to the circuit in effect acting as a fuse. So any replacement (halogen or LED) must match the current draw of the bikes original halogen or LED and must be same front and back. Some aftermarket LED units draw more current than they need and use a resistor to bleed the excess off as heat this means the bike's "ECU" can remain set to halogen but will not trigger bulb warning.
    You clearly have your reasons to want to run without the lower fairing. Easiest way has to be simply extending the wires on your original indicators and mounting in a convenient place. Next would be to get some aftermarket 10 Watt halogens and using the part you have shown make up your own wiring. Any LED option you have to know the current draw and see how that compares to either the 10 Watt halogen or the BMW OEM LED units. If it's 10 Watt make up wiring and away you go if the same as the LED, make up wiring, get same for rear and set bike's "ECU" to Indicators LED either at Dealer or with MotoSan app/GS-911 tool.
    Enjoy the ride
  10. Likeskaz liked this post
  11. #6
    Points: 9,003, Level: 65
    TBH unless you drop the bike next to a kerb or an object on the floor (rocks, railing etc), the fairings are ok. The handlebars stick out far enough to offer protection for them if the bike is laid over. They don't stick out far from the frame or engine as the bike is tightly packed.
    They also offer the fairing they attach to more rigidity too - so this will not be as secure on the bike.
  12. LikesMGD109, kaz liked this post
  13. #7
    Feb 2020
    Didn't realize I'd have to change the back turn signals as well, thanks for the insight.
    "blinker fix error" on ebay yields these 2$ 12-Volt 10W 10-Ohm resistors, I guess this leaves me with maybe finding some kind of longer BMW style electric harnesses wires for my 1st attempt.
    MotoScan looks very handy, added OBDLink to my future to-buy list.
    That is great to know. Prudent Germans!
    I would still like to have the option of fast removal (hope the reduced rigidity doesn't prove critical), this detail made me think of a possibly easier variant for the LEDs - use the same location, just with bulbs that are thin enough to get the fairing in and out without hassle. Need to get measurements and ebay it further.
    Thanks
  14. #8
    MGD109's Avatar
    Lancashire
    Apr 2018
    12 Minutes Ago
    Only if you change the front to low power LED (ie no 10 Watt emulator). There is no option to have LED front/LED rear in the "ECU" it's all LED or all Halogen.
    Enjoy the ride
  15. Likeskaz liked this post
  16. #9
    Feb 2020
    That makes it easier then. I think I found an initial set I can try out.
  17. #10
    Feb 2020
    While I'm reaching 5 posts to put a link - I noticed that the center stand press peg, passenger peg and side luggage attachment thingie, all go out a bit farther than the exhaust pipe. With the bike leaning to the same side as the exhaust, is it possible that a cover won't be touching the exhaust at all, and I could just throw one over on arrival?
  18. #11
    Feb 2020
    (And.. can put links now)
    Found this on Aliexpress -
    www.aliexpress.com/item/4000065563034.html
    Front/rear set, seems to have an internal relay and the emulator resistors. Diameter is 1.8cm, perhaps it'll allow the fairing to slide in/out without changing location?
  19. #12
    Points: 415, Level: 8
    Greater Manchester UK
    Jan 2020
    Why not get some crash bars that will protect the lowers in a fall probably cheaper and easier to all the messing about you will be taking on, only asking?
  20. #13
    Points: 8,296, Level: 63
    I'm not the OP, so he might have some other reasons for wanting to do this, but unfortunately they (everyone) stopped making crash bars for the ST a few years ago. I know several people who want them but can't find them. I rely on mine as mounting points for auxiliary lights and highway pegs.
  21. LikesDaboo, kaz liked this post
  22. #14
    Feb 2020
    Quote Originally Posted by ericatcse View Post
    Removing the fairing has the added value (for me) of not attracting as much attention with the beemer insignia.
    I would like to get bars eventually, but they're quite expensive.
    Do yours protrude beyond the handlebars? I actually thought that if/when I get a pair, I could mount some tool tubes there.
    Shouldn't GT bars work on our ST as well?
  23. #15
    MGD109's Avatar
    Lancashire
    Apr 2018
    12 Minutes Ago
    ......Shouldn't GT bars work on our ST as well?
    Not the same fit I'm afraid.
    Enjoy the ride
  24. Likeskaz liked this post
  25. #16
    Feb 2020
    Update
    I've been postponing this for a long while, today finally removed the lower plastics. I ended up reconnecting the turn signals with one of the fairing bolts:
    Don't know how durable this is, see how it holds until I figure out an alternate location (Have some LED blinkers and sticky LED strips from aliexpress)
    Also found a plastic type cowl around the radiator beneath the fairings, removed it too:
    Do you think it will do any harm to leave it out? I don't see a cowl on the F800S / F800R models.
  26. #17
    The plastic cowl helps to channel air to the radiator, rather than let it escape around the side.
    on a side note, is that your steering damper hanging down in the top picture?
  27. Likeskaz liked this post
  28. #18
    Feb 2020
    Yes. Is it out of form?
  29. #19
    Points: 3,626, Level: 39
    Robert
    Poland, Gdansk
    Mar 2017
    I think the dense foam (or something like that) spacers above and bellow the damper arm have disintegrated. You can buy them from BMW.
  30. Likeskaz liked this post
  31. #20
    Feb 2020
    Are you referring to this part?
    http://www.ebay.com/itm/Genuine-BMW-...7/193376869600
    I think you'tr right, mine has no cushings.. thanks for the heads up!
  32. #21
    Robert
    Poland, Gdansk
    Mar 2017
    Yep, that's the part. There's one more at the other bolt (as you can see on the diagram). The manual states that the bolts have either mechanical or Loctite lock, don't remember right now. I have used Loctite on mine with good effect. Torque should be roughly 20Nm.
  33. Likeskaz liked this post
  34. #22
    Not a problem! Whilst the damper is off it's a good time to check the headstock bearings, and the damper too.
    Headstock bearings; gently move the bars side to side and see if there's any notchy feeling. Usually this will be near the straight ahead position. Also check play by grabbing the front wheel (with it off the ground) and trying to pull it forward/upwards.
    Damper; move the rod in and out slowly. Should be a smooth pull/push with no judders & littler friction. Then move it fast and it should 'stop' give hard resistance.
  35. Likeskaz liked this post
  36. #23
    Feb 2020
    In the pre-purchase check, the mechanic played with the wheel like you describe, so I know the bearings are done.. I figured if they're dropping the entire front, I should probably check/change telescope oil too (or not?), but haven't researched it yet so I'm kinda postponing.
    If the damper doesn't work properly as per the check you describe, is it feasible to ride without it while I'm waiting for a replacement?
  37. #24
    if it's never been done it's worth changing the oil and the seals. Be aware that BMW changed the qty needed in the forks (increased it) from the original qty.
    Personally I buy all oils & seals from BMW, even though it is a bit more expensive. But for a once in a 5 year job it's worth (in my opinion) paying the extra to ensure it's right and will last.
    You can ride without a steering damper, but be careful if the front end goes light as you'll have no assistance if it kicks.
  38. Likeskaz liked this post
