Cutting out at low revs - BMW F800 Riders Forum & Registry
Results 1 to 12 of 12
    Rabbitwar222's Avatar
    Points: 767, Level: 15
    Dublin, Ireland
    May 2019
    Hello all,I'm looking for advice on my F800ST, (42000km)
    Cold weather all week and riding 50 miles/day. This morning the bike started on the button, moved into 1st and she cut out. Started again no problem, in 1st with more revs and moved off fine, changed into 2nd and she cut out. Started again no problem but had to keep revs up, went round the block in 1st, came back to my house (400m) and as soon as I stopped she cut out again. Parked up and took the cage to work!
    Similar problem 4 months ago was fixed by replacing the battery BUT at that time the dash would reset or go blank when starting - this time time the dash is perfectly normal so I'm thinking it's NOT the battery but something else?
    All/any advice on what I should be looking for would be very much appreciated
    TIA
    Buzzz's Avatar
    Points: 1,383, Level: 21
    Laurent
    Belfort (France)
    Oct 2018
    alternator maybe.
    Points: 7,704, Level: 61
    It would be worth checking the voltage, but I doubt that's the problem. If voltage was so low to cause a stall, it would be way too low for it to start. An engine requires a small fraction of the amps to run compared to turning it over to start.
    More likely is a problem with the idle air controller. It could be dirty, or there could be a pinched vacuum hose.
    Points: 11,045, Level: 72
    I always give the same advice for stalling at idle. Before adjusting or replacing anything reset adaptations (use GS-911 or Motoscan app) to see if that fixes the issue.
  7. LikesBoxerBits liked this post
    Dublin, Ireland
    May 2019
    She's not stalling at idle, only when changing gear and letting clutch out, unless I keep the revs up
    Quote Originally Posted by Rabbitwar222 View Post
    Advice still applies.
    pigmy's Avatar
    Points: 4,777, Level: 47
    Carl
    England
    Aug 2017
    '18 F800 GT
    '98 VFR800
    '06 F800ST
    '06 F800ST
    Sounds to me like you have fuel starvation if it is cutting out as you ask the engine to give more revs? Check your fuel pump and filters attached to it. ( BMW call it a strainer, hopefully the picture has uploaded)
    https://www.realoem.com/bmw/enUS/sho...iagId=16_06440
Name:	fuel assby.jpg
    As other posts say:
    Failing that the EGR valves can be problematic and breather pipes having kinks, I assume you have checked these, as is easy fix.
    Points: 8,394, Level: 63
    a) does it idle ok - no issues, stalls or misfires?
    b) does it rev ok when not in gear, at a stand still? again, no misfires, or stalls?
    The idle circuit and throttle bodies are independent of one another.
    Dublin, Ireland
    May 2019
    Well, this is slightly embarrassing.
    Thanks for all the advice, much appreciated.
    Today I found the +'ve terminal battery lead was slightly loose, like a quarter turn. 30 min ride with no problems!
  13. LikesDaboo, ccramerusc, MGD109 liked this post
    better to be something simple and easily solved, than a thorough check of multiple items!
    Dublin, Ireland
    May 2019
    Too true!
    Gazk's Avatar
    Points: 463, Level: 9
    Gary Wardle
    Leicester UK
    Sep 2019
    Quote Originally Posted by pigmy View Post
    As other posts say:
    I had an issue when I'd been running for a time then came to a standstill the bike cut out it did it for a week then I check the fuel filler and it was like it was sealing too well, I only noticed it when I went too full up and there was an audible a gasp as I opened the filler, I cleaned the filler neck and it was fine. Then next day I found the breather was kinked and was not letting air back into the tank problem solved.
