weird engine noise - BMW F800 Riders Forum & Registry
Results 1 to 13 of 13
    Points: 173, Level: 3
    Mar 2020
    hello everyone
    since yesterday, a new noise appeared from my engine after 5-10 mins of riding
    My mechanics said it wasn't worrying him, but still, never ever heard this noise from previous f800's
    Should I worry?
    Randyjaco's Avatar
    Points: 1,750, Level: 25
    Randy
    Friendswood TX
    23 Hours Ago
    I agree with your mechanic. I didn't hear anything to worry about.
    Randy
    2010 F800ST
    padaek's Avatar
    Points: 13,668, Level: 80
    Jurgen
    Shellharbour Australia
    Nov 2016
    1,044 / 0 / 0 / 0
    '19 Super Cub C125
    '02 Sprint RS
    '90 Le Mans
    '15 F800R
    Sounds normal to me.
    Cheesy rider's Avatar
    Points: 6,179, Level: 54
    Mouse
    Brooklyn ny
    Oct 2014
    '07 F 800 ST
    '06 K1200S
    '16 Thruxton
    '75 CB750-4 S/S
    '07 F800 ST
    Sounds like a sewing machine full of marbles, that’s means it’s fine.
  7. Likespadaek, gtutunjian liked this post
    Points: 550, Level: 10
    Boise, ID
    Dec 2019
    '15 F800R
    I don't hear anything odd, but it might be helpful if you describe the noise you are referring to? What does the new noise you are worried about sound like?
  9. LikesDaboo liked this post
    Points: 46,667, Level: 100
    11 Minutes Ago
    4,318 / 0 / 9 / 3
    I'm with sharkerty...and the others. I thought it sounded normal, but could be missing what you're hearing. Can you describe it?
    Sometimes when we hear or feel something "new", we then begin thinking the bike is falling apart. When in fact, it was there all along and we just didn't notice it before. I wonder if that isn't what you're experiencing.
    Lag's Avatar
    Points: 2,538, Level: 32
    Lyle
    Whiterock British Columbi
    22 Hours Ago
    '15 F700GS
    What are you hearing? Change of helmets or even the visor can make a difference in the sound,,.
    Sound recordings don't to a very accurate job of replicating sound of a motorcycle,,. Those exhaust note samples never do the actual sound justice,,.
    I get a buzz at 6000 rpm that sound more like a vibration then something from the engine, I have never found the source and notice its seems to vary from day to day!!
  12. Likesgtutunjian liked this post
  13. #8
    Points: 6,766, Level: 57
    Rob Stevens
    Nottingham
    Apr 2012
    '10 F800R
    Is the noise that you can hear (and are worried about) present in that sound clip? Cos you mention after 5-10 mins of riding but that clip is only 20 secs long..... But it sounds OK to me.
  14. #9
    Mar 2020
    Thank everyone for the replies (and apologies for the lack of response, but... well other priorities, mucho work, bad period,you know what I mean...)
    the noise is just getting louder and louder, I tried to isolate it in the video, it the same on but with some adjust (and it was after a 2 hour ride), it's this weird growl when I rev up
    Last time I went to the dealer, he fond a small leak coming from the oil pressure sender installed in place of the stupid bolt, and just said " thats because of that, it cause a pressure problem, but I still don't hear it"
    Sender removed, stupid bolt installed, no oil leak, still the noise...
  15. #10
    Simmacus's Avatar
    Points: 6,097, Level: 53
    Sims
    Massachusetts
    Jan 2014
    '12 F800R
    Oh that sounds funky
  16. #11
    11 Minutes Ago
    4,318 / 0 / 9 / 3
    The sound is hard to pick up as to what is at fault. Sound recordings are better than nothing, but I've never heard them record on my own bike in the playback, what I thought I was hearing to my own ears.
    So I'll take a guess that you're commenting on the high pitched kind of raspy noise??? If so, my guess is that you're hearing the cam chain tensioner. Do a search on the forum, and maybe on other forums as well. I have a vague recollection that the cam chain tensioner on the F800 is much like that on my Subaru. It's driven by oil pressure. On the initial startup, you'll hear it some of the time. I also vaguely remember something about a mechanical cam chain tensioner being sold as a replacement. Again, do a search and see if the other threads match what you're experiencing and if so, they'll mention what the replacement part was.
  17. #12
    Points: 2,065, Level: 28
    16 Minutes Ago
    Totally out on a limb here, but it sounds like there's some extra gear whine going that follows the engine revs. I have heard of people talk of similar noises when the water pump drive gears started to fail, but that is just a long shot guess based on a internet sound clip. It's in the valve cover area so a bit of a pain to take a look at, and expensive to have someone else do it if it turns out to be nothing, but you'd get a chance to check the cam chain out while you're in there.
  18. #13
    11 Minutes Ago
    4,318 / 0 / 9 / 3
    Harbor Freight sells a cheap mechanic's stethoscope. It might be handy to use to isolate where the sound is coming from.
