F800GS - 2017 - Fuel Pump Controller - BMW F800 Riders Forum & Registry
Results 1 to 8 of 8
    Points: 577, Level: 11
    Asuncion - Paraguay
    Oct 2019
    I have noticed that my bike does not have the FPC which is used on previous models above the fuel pump assembly
    Is the Fuel Pump controlled directly from the ECU? or is there a relay somewhere else on the 2017+ models?
    Points: 25,403, Level: 100
    Charlotte, NC, USA.
    Nov 2007
    2,163 / 0 / 166 / 204
    Not aware of it being moved...
    I have older bike but with (what I think was 2017) sender/pump assby.
    On the later models the FPC is black powder coated instead of raw aluminum ... but that's all I've got...
    Asuncion - Paraguay
    Oct 2019
    Mine does not have the black controller. A friend has an 2015 F800GSA and his has it
    I will post a pictures when I go home
    AKBeemer's Avatar
    Points: 8,020, Level: 62
    Kevin Huddy
    Silver City, Montana
    Sep 2011
    lukin, find your bike on this site and see if you find a FPC. Likely in the fuel supply section.
    https://shop.maxbmw.com/fiche/partsfiche.aspx
    Kevin
    Team Pterodactyl
    Asuncion - Paraguay
    Oct 2019
    AKBeemer: I looked at another site and already confirmed that there is no FPC above fuel tank. I also look at the electrical parts and could not find any pump relay what so ever, that is why I am assuming that the pump is controlled directly from the ECU
    A wiring diagram will be great. There is very little official information from BMW for the end users
    Asuncion - Paraguay
    Oct 2019
    Here is a picture. You can see that 4 wire are connected to the pump assembly. 2 for pump and 2 for fuel level
    Points: 13,865, Level: 81
    This help?
    Asuncion - Paraguay
    Oct 2019
    This help?
    what helps?
