Sudden loss of...everything!....whilst riding - BMW F800 Riders Forum & Registry
    ChrisK's Avatar
    Points: 366, Level: 7
    NSW Australia
    Nov 2019
    '10 F800 ST
    I started the bike this morning as usual, and it ran for over an hour with no issues. On the return journey, it seemed very slightly hesitant to start. I managed about a kilometre before all the gauges started misfiring, then total power failure. Zilch, nought, nothing.
    Battery, or what?
    Roadpizza's Avatar
    Points: 89,839, Level: 100
    Philip
    Cascade Locks, Oregon, US
    May 2007
    14,737 / 37 / 2548 / 3082
    No engineer but, my money is that it is the battery or a connection to the battery. Maybe corrosion on the negative. contact. That's my grain of salt.....
    BMW F800S…….
    There is no words to adequately describe the batshit crazies....
    ChrisK's Avatar
    NSW Australia
    Nov 2019
    '10 F800 ST
    Quote Originally Posted by Roadpizza View Post
    Would a battery fail result in such a sudden and catastrophic loss of power do you think? It just seemed odd to me that it should occur after the bike was already started and running (but I'm no engineer either... )
    Points: 7,083, Level: 58
    Dave Watson
    Nov 2014
    Chris. Batteries do have occasionally have instantaneous catastrophic failures. As our bike's CPU and other electronic wizardry depend on a stable voltage supply, any failure to it and the bike stops. Older bikes (and cars), without all the modern day electronics, would continue to run on just the alternator or generator, not so these days. So agree with Philip, probably the battery.
    Points: 1,873, Level: 26
    '17 SV650
    Start with battery connections because they're easy, but still get the battery checked out. Fully charge and then load test. Once the battery is replaced (or ruled out) then check your charging system. The battery HAD to be good enough for the bike to start, if it died while riding then that indicates that the rate of charge could not keep up with the rate of loss, in other words you may very well have a charging system fault that caused the battery failure.
    Points: 3,027, Level: 35
    Quote Originally Posted by rcb78 View Post
    Start with battery connections because they're easy, but still get the battery checked out......
    Would agree that the most obvious cause would be battery connection/leads and certainly first place to start, I have stopped for a stranded motorcyclist with identical symptoms (bike had cut out and nothing when he hit the starter button) he'd already diagnosed the problem because he could easily see the earth lead was no longer fastened to the battery!!
    Simple first check would be to measure the voltage across the battery terminals then measure the voltage from the positive lead clamp to an earth on the bike if there is any drop in voltage it would strongly point to lead/clamp issue.
  9. LikesRoadpizza liked this post
    Points: 49,105, Level: 100
    13,282 / 8 / 110 / 2177
    SBD, Sudden battery death. It's on all the forums for motorcycles and has been for years. BMW actually replaced the original battery in my ST during a service because they had a batch of potentially bad ones and were proactively removing them. Loose battery connection are the second leading cause of electrical problems followed by kill switches, clutch switches and side stand switches. Some bikes have fall down detectors and cut out electrical stuff to protect the bike.
    Roadpizza's Avatar
    Philip
    May 2007
    My first SBD was a day or so before the original warrenty ended. BMW picked up the tab and the tow to Portland.
    Quote Originally Posted by notacop View Post
    BMW F800S…….
    Points: 1,233, Level: 20
    Could be any if these and more...
    However, I'd suggest to the OP to follow a systematic method to diagnose the fault rather than a blunderbus approach.
    MGD109 has outlined a good traditional starting point.
    Sent from my moto g(6) play using Tapatalk
    ChrisK's Avatar
    NSW Australia
    Nov 2019
    '10 F800 ST
    Many thanks for your help everyone.
    It was indeed 'sudden battery death', and a spanky-new battery got it up and running and safely returned home.....less than 12 hours before the Do Not Travel restrictions hit Australia. Phew!
  14. LikesRoadpizza, dew liked this post
    Flook's Avatar
    Points: 119,547, Level: 100
    Dave (yes, another Dave)
    East Northants
    7,405 / 12 / 365 / 797
    Now that was cutting it fine there ChrisK, however I am sure if it was after then an explanation to the relevant authority IE good morning officer bright day is it not! or something like that, and continue with something like, Just been out for a jolly ole jount you know some while back and believe it or not the blasted battery failed, so huh, had to order the blighter didn't I, just fixed it too, so sorry an all that, you can understand yes Officer.
    Well something like that, but won't happen now will it.
    Stay safe all you F8 buddies. . . See you on the highway's again when this CV thingy is over.
    Flook
    Please note, the thoughts and opinions of Flook does not necessarily reflect the thoughts and opinions of other posts & site users therein
  16. LikesRoadpizza liked this post
    Roadpizza's Avatar
    Philip
    May 2007
    I had it explained to me awhile back that the placement of the battery right over the engine heats the battery but, more importantly, it tends to vibrate and shorten the life of the battery by breaking down the cells inside. The standard battery had no real containment and was prone to failure at and early age.
    BMW F800S…….
  18. LikesFlook liked this post
