Magnetic Interference? - BMW F800 Riders Forum & Registry
Results 1 to 4 of 4
    DriftlessMike's Avatar
    Points: 1,412, Level: 22
    Michael Kalinosky
    Viroqua, Wi
    So I'm considering a magnetic tank bag. I have a micro bag from Firstgear that will hold just enough. It's small enough that it won't get in my way standing on the pegs. The Wolfman bag I've used on my RT is overkill.
    https://photos.smugmug.com/Motorcycl...nk%20bag-L.jpg
    The bag will stay in place if I glue some of these neodynium magnets under the "tank" cover.
    https://photos.smugmug.com/Motorcycl...0magnets-L.jpg
    They are very strong magnets, and their field extends farther in space than a typical one made of iron. There are a lot of electronics in the vicinity. Anyone know if the magnets will cause trouble?
    Points: 306,034, Level: 100
    10,628 / 15 / 698 / 2031
    While it has never happened to me because I don't have any electronic do-dads, some magnetic tank bag manufacturers say not to carry any electronic gadgets in their tank bags as they might be damaged. However, I doubt there will be any impact on the bike's electronics. They are probably well shielded.
    Points: 81,182, Level: 100
    5,025 / 0 / 9 / 3
    I bought a nice magnetic bag, just before buying my F800GT. It was brand new, barely used. I thought about the magnets and tried to see if they'd work by taping them under the plastic panels. What I had for magnets, just wasn't strong enough.
    I ended up buying a Givi bag that uses the "gas tank" locking bracket. An advantage there, is you can swap amongst the bags in the line that also use the locking mechanism. SW-Motech makes some that are similar. Our gas tank opening isn't where the "normal" location is, but both companies make a bracket to use instead.
    RoadRogue's Avatar
    Points: 6,919, Level: 57
    JR
    Eagle, WI, United States
    Feb 2012
    '19 F750GS
    '14 R1200GS
    '07 F650GS (Single)
    The magnets won't hurt yours or the bikes electronics but don't put any credit cards near then if you intend to use the magnetic data strips. I can't tell you how many cards I wiped out while working on MRI systems. The electronic devices were always fine - if they didn't get yanked off my person. It seems I'd always find out on Friday nights when I'd go to use my ATM card. The chips in the newer cards aren't susceptible even if the redundant (vestigial?) magnetic strips are.
