Gear Selector potentiometer - BMW F800 Riders Forum & Registry
    Points: 1,049, Level: 18
    On my 2013 F800GS the gear indicator became erratic. I hooked the GS911 and get 2 error codes, only one being persistent (10202):
    2 fault codes found:
    10115 Gear position potentiometer
    The fault is currently present.
    10202 Supply voltage (5V) to Gear Selector potentiometer
    Is the 10202 error caused also by a faulty potentiometer, or it means something else?
    Points: 279,982, Level: 100
    10,466 / 15 / 698 / 2031
    Could it be that the wire connected to the gear position potentiometer has become disconnected or one of the wiring contacts are corroded and need to be cleaned?
    I have mount today a new potentiometer, cleaned the contacts, but the error is still there ...
  5. Likes Randyjaco liked this post
    Points: 6,751, Level: 57
    Tony Turpin
    Plymouth UK
    Mar 2013
    '14 F800GS
    Did you clear the fault code with the GS-911?
    Points: 28,217, Level: 100
    Charlotte, NC, USA.
    Nov 2007
    2,223 / 0 / 166 / 204
    Apparently the unit is not well sealed and water crossings or use of a pressure washer can cause issues.
    There was a thread here or on ADVRider of a guy disassembling his using contact cleaner and WD-40 on his re-assembling and having good luck.
    Mine is throwing intermittent fault and often tells me I'm still in 5th gear when I am in 6th....
    I'll be getting to it soon....
    Blue 2009 F650GS - H-B crash bars, TT luggage rack, Pelican top case, BMW Vario Panniers & bash plate, 20mm handlebar risers, LED voltmeter, Sargent seat, MudSling, a few other trinkets ... I may be just about at the end of the farkle train
    Points: 458, Level: 9
    Giff Plume
    North Scituate,RI
    Dec 2020
    Quote Originally Posted by jrwooden View Post
    I have a persistent problem with my gear indicator on my 2017 F800 GS ADV. Basically after running in 6th gear the indicator goes dead. Resets every once in a while, but eventually after coming back goes dead again. Problem coincides with dropping a tooth on the countershaft sprocket. My error codes are 4480,4481 and 4482, with 4482 (“gear selector sensor, implausible signal or value”)being predominant. I replaced the gear indicator potentiometer, but still get the same issues. Anybody out there with a similar issue?
    bmwroadsterca's Avatar
    Points: 13,228, Level: 79
    Quote Originally Posted by gplume View Post
    This is a known issue on 2017+ bikes when fly by wire and ASC were introduced. For whatever reason the ECU calculates what gear the bike "should" be in using RPM and the speed of the bike and compares that to what the gear indicator says based on the potentiometer reading. If the two don't agree because the secondary ratio has changed from stock you get the symptoms you describe. I have yet to see anyone post a solution.
    guenner's Avatar
    Points: 3,471, Level: 38
    Guenther
    Colorado Springs, CO
    Calculating the gear number this way may be off if the sprockets for the chain have been changed.
    /Guenther
    2017 F700GS - I wish it had a drive shaft
    Quote Originally Posted by guenner View Post
    /Guenther
    Yes. That's what I said.
    guenner's Avatar
    Guenther
    Haha, that was too 'abstract' for me.
    /Guenther
  14. Likes bmwroadsterca liked this post
    Points: 629, Level: 12
    NL
    I have an F800 GSA from 2017 and changed the final drive ratio. Right after this change, the gear indicator display went blank, including neutral light. The GS911 showed an error that kept coming back after resetting. Now, after ~500km, suddenly the gear indicator started working again! It seems the onboard software recalibrates itself after a while
    Charlotte, NC, USA.
    Nov 2007
    Quote Originally Posted by arnoud520 View Post
    yeah...
    I have a GS=911 also, and from looking at the "adaptation values" it appears the potentiometer/sensor just sends analog voltages for the positions,
    and the bike figures out what's what ...
    I've tried resetting my "learned" values with the GS-911 which then "coaches" me to start in 1st and then run the bike in each gear for 10 or 20 seconds....
    so the ECU can re-learn ... but ...
    either my ECU rides the short bus,
    or my sensor needs cleaning or replacing...
    as it never consistently registers 6th gear correctly...
    I'm guessing sensor issues ... when I get a chance I'll pop it off see if I can disassemble, clean and re-assemble.
    I think @reaver had some success with that a while back.................
