F800GT out side air temp Whats up ? - BMW F800 Riders Forum & Registry
Results 1 to 11 of 11
    Points: 171, Level: 3
    May 2020
    My Temp Gauge always reads 57 . Do I need a fuse, sensor, or what ? Did work just fine now it reads 57 regardless . Any ideas where i should start ? Any help will be welcome !
    Thanks
    Points: 184,215, Level: 100
    9,453 / 15 / 698 / 2031
    Perhaps the wire connector to the temperature gauge sensor has become disconnected or is corroded?
    May 2020
    Quote Originally Posted by richard230 View Post
    perhaps the wire connector to the temperature gauge sensor has become disconnected or is corroded?
    richard do you happen to know the location of the sensor ? Anyone else ?
    Thanks
    Points: 7,391, Level: 60
    Dave Watson
    Tasmania
    Nov 2014
    Rapid. The sensor is up under the nose of the fairing, a fair way back,on the left, about level with the left indicator. Black, 3/16" diameter, 1 1/2" long. I've given the measurements in imperial as I assume either your in America or Britain/Ireland.
  7. LikesRichard230, PhotoAl liked this post
    Points: 10,947, Level: 72
    13 Hours Ago
    Rapid - Dave described the sensor position exactly. It has a long pointed nose on it and is a push fit into a hole under the left fairing. The connector wire comes off the sensor by pushing a tab in on the side. Might be loose or the sensor could be faulty.
    18 F800GT
    May 2020
    Thanks guys this site rocks !
    I might add that my 2007 R1200R had a recall for its temperature sensor, which was replaced by my BMW dealer when I still owned the bike. However, I never noticed any problem with the sensor before or after it was replaced. My guess is that the recall had something to do with emissions compliance and some of the temperature probes were likely giving incorrect readings that resulted in a Booster Plug type fueling alteration.
    13 Hours Ago
    Rapid, are you referring to the ambient air temperature readout on the dash or the engine temperature readout? The later GT's have both.
    18 F800GT
    May 2020
    Ambient
    Points: 3,626, Level: 39
    Robert
    Poland, Gdansk
    Mar 2017
    If it looks ok and the connector is ok I'd start with a 2nd hand sensor. The ambient temp sensor is used on pretty much every BMW car and motorcycle in the last 10+ years.
    Points: 5,277, Level: 49
    Massachusetts
    Sep 2013
    Any resolution?
