Failure to start - BMW F800 Riders Forum & Registry
Results 1 to 10 of 10
    tnfiddler's Avatar
    Points: 358, Level: 7
    Jeff
    Kingsport Tn. US
    Jul 2020
    Maybe I'm just being paranoid but.. I started to go for a ride today and the first time I pushed the start button nothing happened. I was in neutral and was rolling the bike backwards when I tried to start. I switched the key off and next time it started as normal. It has a new battery. Should I be concerned? How many of you guys have the GS911 and is it something I should be considering?
    Sent from my XT1585 using Tapatalk
    Points: 26,336, Level: 100
    Charlotte, NC, USA.
    Nov 2007
    2,181 / 0 / 166 / 204
    I have a GS-911 and like it a lot.
    If i didn't already own one, I'd be reading up on this unit to see how the capabilities compare...
    https://advrider.com/f/threads/app-r...ition.1130770/
    To your battery issue, i've occasionally had that problem.
    Sometimes I think I just wasn't "mashing" the starter button with "dedication"
    Twice now over the life of my bike the GS-911 has reported low system voltage when there was no good reason that I knew of for that to happen...
    Once I did have a new-defective battery.
    Points: 1,949, Level: 27
    Yes buy a spare handlebar switch as they are known to pack in, oh and a t8 torx to get the old one off. Mine started to to become intermittently faulty and eventually packed in. It was always on hot sunny days so maybe park in the shade.
    tnfiddler's Avatar
    Jeff
    Kingsport Tn. US
    Jul 2020
    Do you have to wait until the bike goes thru all the checks before it will start?
    Points: 8,816, Level: 65
    Have to? No. Should you? Yes. At least from what I've been told by a BMW dealer. I've certainly started it many times without waiting and everything seemed fine, so I'm not personally convinced it's necessary...
    Points: 215,824, Level: 100
    9,753 / 15 / 698 / 2031
    Quote Originally Posted by tnfiddler View Post
    You don't have to, but that is what I have always done with all of my FI BMW motorcycles. I wait until the yellow triangle goes out before hitting the starter button. I also keep the throttle closed when starting. Fortunately, my F650GS goes through its pre-starting checkup very quickly.
    tnfiddler's Avatar
    Jeff
    Kingsport Tn. US
    Jul 2020
    Yeah, that yellow triangle light stays on for a few seconds after all the others go off. Expecting my Haynes manual any day now
    Charlotte, NC, USA.
    Nov 2007
    One other suggestion ...
    Make sure all battery connections are clean and tight, as well as connections @ starter relay (under left side cowling), hot lead at starter.
  11. Likes tnfiddler liked this post
    tnfiddler's Avatar
    Jeff
    Kingsport Tn. US
    Jul 2020
    Efin8r, where is the best place to buy a handlebar switch. It failed to start a couple of times this morning, but turning key off and on it fired right up. I started to disassemble tonight thinking I might be able to clean any contacts but I need a smaller torx
    308bever's Avatar
    Points: 2,876, Level: 34
    bever
    geelong vic au
    Jun 2018
    '13 F700GS
    are you sure it`s not your side stand switch?
