Low fuel indicator -- does it require riding to clear? - BMW F800 Riders Forum & Registry
Results 1 to 26 of 26
    Points: 2,063, Level: 28
    USA
    May 2019
    My 2016 F800GT low fuel indicator came on and started the "countdown to empty" bit. I put a couple of gallons of fuel in the tank from a can, more than enough for the indicator to turn off -- but it hasn't yet. I haven't moved the bike since putting the gas in -- does it need to be ridden in order for the low fuel indicator to turn off? My 2019 Triumph Street Twin needs to be ridden to turn it off.
    Points: 7,393, Level: 60
    Lansing, Kansas
    Aug 2012
    '12 F800ST
    On my ST it seems to require that I actually ride the bike some distance (less than a mile, maybe?) before the gauge moves back to full and the low fuel light goes off. Seems to work about the same way the TPMS sensor/gauge works, you have to ride a ways before the low tire light goes off. And the same way the ABS light works. However, I have never actually tried putting something less than a full tank.
    Royce
    On the coast of Kansas
    2012 F800ST
    Points: 1,429, Level: 22
    Lonnie
    Selah, Wa
    pretty sure the answer is yes, it needs to be ridden ---------- one sure-fire way to find out - (like we need another excuse to ride) " honey, i'm gonna go ride to see if i have any gas" -
    '93 DR350S
  5. Likes zulujams, Swamp Fox liked this post
    USA
    May 2019
    Quote Originally Posted by Royce View Post
    Thank you.
    USA
    May 2019
    Quote Originally Posted by Elizdad View Post
    Yes, I will eventually find out. Due to some family emergencies I haven't been able to ride lately. I siphoned the old gas from the tank before adding the new gas, about 2 gallons, and added some Stabil 360.
    Points: 11,747, Level: 74
    Ian
    Nr Norwich, UK
    Apr 2014
    740 / 2 / 18 / 28
    Quote Originally Posted by DArtagnan View Post
    Just a warning: - The GT doesn't "countdown to empty" but counts up from zero from when the low fuel warning first comes on. I can get about 30 miles before the bike stops.
  10. Likes Kukopia liked this post
    USA
    May 2019
    Quote Originally Posted by Norfolk UK View Post
    OK, thanks.
    Points: 272, Level: 5
    Somerset, UK
    Aug 2020
    Still new to the bike, I had my low fuel light and the 'count up' come on today, with two bars on.
    Now, I'm one of those riders/drivers who as soon as they get that yellow light of doom on their clocks/dash starts to break out into a cold sweat and suddenly worries that they're middle of the outback with the next fuel station 200 miles away.
    This whole count up from when my first bike told me that it was running a touch low wasn't a great thing for my range anxiety
    Points: 243,426, Level: 100
    10,091 / 15 / 698 / 2031
    Quote Originally Posted by chutzpah View Post
    You are probably not a good candidate for an electric motorcycle, then.
  14. Likes zulujams liked this post
  15. #10
    Points: 607, Level: 12
    May 2020
    My 2013 F800GT has the same gas indicator. It seems to me that it "self corrected" pretty quickly once in motion. It did not clear at the gas pump. Also, remember that due to the geometry of the tank, anything above about half full is not indicated.
  16. #11
    Points: 11,240, Level: 73
    Confirmed this yesterday. My tanks was down to no bars showing on the gauge, and the low fuel warning light was on - so I added a couple of gallons of fuel.
    I turned the key on to see how much fuel was in the tank - no bars and the warning light was still on.
    I put on my helmet, jacket and started up the drive - I got about 50 feet and the warning light cancelled, 3 bars of fuel showed on the fuel gauge.
  17. Likes Runmyownlife, Kukopia, PhotoAl liked this post
  18. #12
    USA
    May 2019
    Confirmed this yesterday. My tanks was down to no bars showing, and the low and the warning light was on - so I added a couple of gallons of fuel.
    Thanks.
  19. #13
    Lag's Avatar
    Points: 5,387, Level: 50
    Lyle
    Whiterock British Columbi
    '15 F700GS
    Off topic but just checking the capacities and count down on reserve,,,,,, You should run out just around 50 miles or 80 kilometers,,.
    I think Ive seen mine as high as 50 Kilometers
    Fuel capacity: 16.00 litres (4.23 us gallons)= 12.00 litres (3.17 us gallons)
    Reserve fuel capacity: 4.00 litres (1.06 us gallons) You should run out just around 50 miles or 80 kilometers,,!!
  20. #14
    Points: 622, Level: 12
    Classified
    Charles Town, WV
    Sep 2020
    '16 F800GS
    What????? No updates? Curious if riding it worked out.
  21. #15
    Dalesman's Avatar
    Points: 893, Level: 16
    Yorkshire Dales, UK
    Oct 2020
    I've had 42 miles on the 'count up' from empty!
  22. #16
    Points: 12,114, Level: 76
    I've had this too. Light comes on so fill the tank with fuel. Light stays on and no fuel registered until the bike has run a few metres down the road. Then all is well.
    18 F800GT
  23. #17
    Points: 724, Level: 14
    London, GBR
    Aug 2020
    I start getting bothered at about 20 miles of count up past the fuel light. But I've never managed to put more than about 13.5 litres of fuel in when I refuel it.
    How much fuel can you put in the tank if you run it until it conks out?
  24. #18
    Dalesman's Avatar
    Yorkshire Dales, UK
    Oct 2020
    Good question. I'll try to remember to make a note next time it gets near empty.
  25. #19
    If I remember correctly - I once rode 32 miles after I got the notice and still made it to the gas station without pushing. (YMMV).
  26. #20
    Points: 10,510, Level: 70
    1,065 / 0 / 2 / 32
    The most i've been brave enough to do on my ST was 194 miles, and got in 14 litres. I can't recall how much i was on the fuel counter at the time.
    I generally average 55 UK MPG on my bike, i usually aim to fill up at around 150 miles.
  27. #21
    I don't know if the GT and the GS have the same size fuel tank or not. However, I once put in 4.4 U.S. gallons into my F650GS's tank. On my bike the fuel warning kicks in around 60 miles and starts counting down from there to zero, at which point you are pretty much out of fuel. But you don't want to do that if you can avoid it as the fuel pump is in the bottom of the tank and likes to be both cooled and lubricated by gasoline. If you run it dry you might be damaging your fuel pump and those things are both expensive and somewhat labor intensive to replace. Plus, if they fail they will leave you stranded and that is no fun, either. It is best not to push your luck if you don't have too.
  28. Likes DJ123 liked this post
  29. #22
    Points: 2,886, Level: 34
    Methow Valley
    Nov 2018
    13 Hours Ago
    This issue was very much on my mind yesterday. My fuel light came on at 200 miles and 26 miles later, I pulled into a fuel station. My 2013 800GT took 3.786 gallons of fuel. Was not sure I would make it, 20 mile per hour winds and I was not getting any cell service.
  30. #23
    Ian
    Nr Norwich, UK
    Apr 2014
    740 / 2 / 18 / 28
    I tested this once in my GT in very early ownership. Not realising the count was from 0 upwards when the red light came on (our car counts down), I got 36 miles and coasted into the fuel station which just happened to be in the right place - on a dead engine.
    I now know I can get close to 180 miles before reserve if driving ordinary roads, or about 20 miles less at legal motorway speeds.
  31. Likes Biscuits liked this post
  32. #24
    Points: 3,841, Level: 41
    26 Minutes Ago
    '19 Tracer GT
    I could get 140 miles before the light went on at enforced speed limit of 80MPH. Once time got over 200 miles out of a tank. Also put in 4.09 gallons after riding about 20 miles after the count up started. Always filled mine to the same place - half the vent holes in the tank covered and noted when the display changed to half tank. That gave me a pretty good idea of how far I could get before needing gas. Of course it does matter if the first half and second half are similar riding. I got pretty good at figuring out how far I could reasonable get before needing gas. Had lots of practice!
  33. #25
    Points: 863, Level: 16
    West Yorkshire, UK
    Feb 2021
    '18 F800 GT
    Just an observation, I see milages/gallons from both the US, and the UK
    Be aware when comparing, that a US gallon, is approx 0.833 UK gallons. The F800GT's stated fuel capacity is 15 litres (3.3 imperial gal; 4.0 US gal)
    Ajay
    F800GT 2018
  34. Likes XR1000, Richard230 liked this post
  35. #26
    Paulius55's Avatar
    Points: 9,968, Level: 69
    Paul
    Rushden, Northants
    Apr 2008
    '66 T20SH
    '17 F800 GT
    I had a previous ST800 with countdown, which I liked (I also very much liked the separate indicator switches) and I really don't like the count up of the GT800 as it is pretty meaningless with an unknown "target". I once went into count up mode on a motorway with no services and finally got to 51 miles of count up before I reach a fuel station off the motorway. I was riding very economically and hardly touched the brakes or the throttle.
  36. Likes Richard230 liked this post
