Fuel Pump "Calibration"? - BMW F800 Riders Forum & Registry
Results 1 to 6 of 6
    Points: 8,345, Level: 63
    David Bucher
    Lititz, PA USA
    Mar 2012
    '09 F 800 ST
    After fitting a new aftermarket fuel pump on my 2009 ST, the gas gauge and the computer info indicators of remaining miles to empty, useage, etc. don't seem to be functioning properly. Bike runs fine. I'm sure that I installed the pump assembly properly and that the fuel level float arm was free. However the Haynes manual notes that "If a new fuel pump is fitted the machine must be taken to a BMW dealer so that the engine management adaption values can be reset to recognise the new pump." Before I pull the pump to double check my installation, can someone explain exactly what that Haynes advice means? And, is a trip to the dealer really necessary?
    Points: 11,973, Level: 75
    That advice anticipates that the replacement fuel pump creates a different amount of fuel pressure than the old one so the engine management system should reset its adaptations to "learn" the new parameters. A GS-911 or the Motoscan app can so instruct the ECU in lieu of the dealer.
    That being said your problem sounds more like an issue with the fuel level float mechanism.
    Points: 12,914, Level: 78
    Claudio
    Winnipeg, MB, Canada.
    Dec 2006
    '10 F800GS
    Quote Originally Posted by LititzDB View Post
    BMWRoadster is correct. The pump would not have an effect on your gas gauge or the statistics. Most likely the float maybe being interfered with or the electrical contact relating to the float has been affected inadvertently during the install. Definitely pull the pump out and check your installation.
    Claudio
    Pat H's Avatar
    Points: 145,677, Level: 100
    Pat
    Ware, Herts, UK
    Aug 2006
    15 Hours Ago
    11,208 / 0 / 160 / 1332
    When you have it pulled out check the fuel gauge reading while manually moving the float up and down.
    Points: 8,822, Level: 65
    Mine gauge stopped working many years ago and it turned out being one of the wires getting caught on the float pivot point. I bent them out to the side, put the whole unit back in the tank, and it's worked perfectly since.
    Hopefully it's that simple for you.
    David Bucher
    Lititz, PA USA
    Mar 2012
    '09 F 800 ST
    I removed the pump assembly and bent the arm slightly away from the direction of the adjoining tank wall. After replacing it, everything seems to be working as it should. That float arm wire is really hard. Can't see how it might have got bent when I was refitting the pump assembly. My best guest is that in trying to manipulate the pump assembly through 9 dimensions while struggling to properly seat it with that God-awful gasket, it got hung up somewhere it shouldn't have been and was simply stuck on full. Glad you talked me into pulling the pump again before I went running to the dealer.
  9. Likes ccramerusc, Claudio_S liked this post
