Does this brake line fit my F650GS correctly?? - BMW F800 Riders Forum & Registry
Results 1 to 5 of 5
    Points: 208, Level: 4
    Boise, Idaho
    Sep 2020
    I removed the Rox bar risers from the 2009 F650GS (with ABS) that I bought last year. With the risers gone, the brake line was too long and seriously rubbed and caught on the instrument cluster when turning left. I tried to get the BMW part, but, according to the local dealer, there aren't any in the US. They would need to get it from Germany which could take several weeks.
    I ordered a stock length cable from Spiegler Performance parts. They made it the day I ordered it and I got it 2 days later. However, I am concerned about whether it fits the bike correctly or not. The new line also hits the instrument cluster turning left, but not nearly as bad. As you turn left is slides across it. Turning right is more of a concern. At hard lock right, the line seems to have a pretty sharp bend on the bottom fitting and a fairly sharp bend at the top.
    Are there any F650gs owners out there with the stock brake line and no bar risers? Can you please compare how your brake line fits to the pictures I am attaching and the video link? I am considering ordering the stock line, which will take weeks to get. I may be able to get by with this line in the mean time, but I REALLY don't want to take a chance with a front brake line failure. However, riding season is rapidly coming to an end here and I want to ride.
    Here are the pics:
Name:	20200916_083845 (Medium).jpg
ID:	368277 Click image for larger version.
Name:	20200916_083826 (Medium).jpg
ID:	368279 Click image for larger version.
Name:	20200916_083749 (Medium).jpg
ID:	368281 Click image for larger version.
Name:	20200916_083753 (Medium).jpg
    Here's a link to a video I uploaded to YouTube:
    https://youtu.be/W24_zxIRnNw
    P.S. I appologize for the redundant post. I asked the same question at the end of my "What tools to remove bar risers from F650GS" thread, but I was afraid the question got lost at the end of a long thread and I really need some feedback on this.
    Points: 206,086, Level: 100
    25 Minutes Ago
    9,661 / 15 / 698 / 2031
    Here are pictures of the routing of the brake line of my 2009 F650GS.
ID:	368287   Click image for larger version.
ID:	368289   Click image for larger version.
ID:	368291   Click image for larger version.
    Boise, Idaho
    Sep 2020
    Richard,
    Thanks for the pictures. Actually I am only concerned with the line going from the brake lever/master cylinder to the "distribution piece". I have a few questions if you don't mind:
    • Do you know if that is the original line from the master cylinder?
    • Does that line rub against your instrument cluster when turned to the left?
    • How tight is the curve at the point it connects to the "distribution piece" when you turn full lock right?
    Thanks again.
    25 Minutes Ago
    Quote Originally Posted by Jimbo99 View Post
    Richard,
    Thanks again.
    That brake line appears to be the one that came with the bike. It is marked J.Juan, which is an OEM brake brand. It does not rub against the instrument cluster or change its contour as the bars move from side to side. One thing I might mention is that I special-ordered my bike without ABS, so that might be the reason that it doesn't look like yours. The metal distribution plate at the bottom of the head-stock seems to be there to make sure that the line is completely stationary, relative to all other parts on the bike, when the bars are rotated side-to-side.
    Boise, Idaho
    Sep 2020
    ... One thing I might mention is that I special-ordered my bike without ABS, so that might be the reason that it doesn't look like yours...
    Yup, that's it. Mine has ABS and the brake lines are very different than yours without. Bummer.
    Anyone out there have an F650GS with ABS, no risers and the stock front brake line?
    Last edited by Jimbo99; 4 Weeks Ago at 06:17 PM. Reason: Removed links that didn't work
