Front End Issues - BMW F800 Riders Forum & Registry
Results 1 to 6 of 6
    Points: 7, Level: 1
    Sep 2020
    Hi, I've just bought myself an 2010 F800s and it feels very vague unstable when turning into bends. It almost feels like the tyre is a bit flat but it's got a new front tyre and the pressures are fine. Has anyone else come across this and is there a fix for the problem?
    Points: 8,822, Level: 65
    Check the steering head bearings. You'll have to lift the front wheel off the ground and push/pull on the front forks forward and backward to see if there is any play. It's hard without a center stand, but you can put a jack under the oil pan if you have some way to stabilize the bike with weight on the rear.
  4. Likes Daboo liked this post
    Points: 12,914, Level: 78
    Claudio
    Winnipeg, MB, Canada.
    Dec 2006
    '10 F800GS
    Quote Originally Posted by Suavemaerk View Post
    Cramer is correct. High probability of the steering head bearings pitted, too loose, or both. Here are some possibilities to check (easiest to most involved).
    1. Check for play in the bearings as per Cramer's instructions
    2. In addition to checking for that, check for any play in your front wheel bearings as this would also cause cornering shenanigans.
    3. Check that your fork tubes are installed at the right height relative to the triple tree. Too high or low can create an odd feeling when cornering as well.
    4. Ensure that your front brakes are not "dragging" excessively. A slight drag will make the bike feel like its twisting.
    5. Check for pitted bearings. If you don't detect any play (clicking) after lifting the bike to check for play, the easiest way to check for pitting is to:
    a) disconnect the steering dampener.
    b) I like to remove the front wheel (technically optional but having zero weight on the bearings allows you to detect the pitting more readily).
    c) If there is significant pitting, you will feel a "ratcheting" effect when turning the steering and/or there will be a tendency for the steering to "lock" in the pits at in the centre position.
    Let us know how you make out
    Claudio
  6. Likes Daboo liked this post
    Randyjaco's Avatar
    Points: 2,235, Level: 30
    Randy
    Friendswood TX
    Probably time to replace your shock oil or just check to see if it's at the right level.
    Randy
    2010 F800ST
  9. Likes Daboo liked this post
  10. #5
    Points: 7, Level: 1
    Sep 2020
    Cheers for the advice. Looks like the head bearings are a good place to start. I'm going to have a crack at it this weekend once I've found a good way of getting the front wheel of the ground. I miss the days when bikes had centre stands as standard.
  11. #6
    Pat H's Avatar
    Points: 145,677, Level: 100
    Pat
    Ware, Herts, UK
    Aug 2006
    14 Hours Ago
    11,208 / 0 / 160 / 1332
    May be worth removing the steering damper assembly before you check the bearings as that can "hide" an issue. Also the steering damper should be checked off the bike for smooth operation from one end to the other. I've had a few go.
    Also what the back tyre like? A good rounded front can feel horrible with a squared off rear tyre.
  12. Likes Daboo liked this post
