Seat Cushion - BMW F800 Riders Forum & Registry
    Points: 4, Level: 1
    Being of a shorter inseam - my 2015 F700gs low seat is not very comfy - my delicate tush hurts after riding an hour. Any suggestions on comfort specifically when my legs meet my tush? Contour existing seat or buy a new cushion / seat?
    Points: 6,932, Level: 57
    Welcome, Delicate Tush, from the coast of Kansas. Glad you found us.
    There are lots of options for after-market seats and cushions. My advice: don't spend much money (definitely do not buy a custom seat=$$$) until you try the cheap solution. I have used an Airhawk and Bead Rider from time to time on new bikes until my less-than-delicate tush got used to the stock seat. But after a few days in the saddle, on every one of my bikes over the years, my tush has grown accustomed to the seat and there were no problems thereafter. I reckon I have saved thousands and thousands on unneeded custom seats.
    Melbourne, Australia IanA is offline F800Riders.org Supporter
    IanA's Avatar
    Points: 18,910, Level: 95
    Ian
    Jun 2012
    1,419 / 12 / 326 / 820
ID:	369267The extralow OEM seat on my '19GT is a bit firm and can get a little achey on long trips. much improved by a 12mm gel pad (EBay $15), shaped and stitched into homemade cloth cover, held on the bike with velcro tapes. Works remarkably well, not much seat height sacrificed and easily removable.
    Points: 1, Level: 1
    Aug 2019
    Well mine was the same, too hard and after an hour was looking to get off and have a break. Bought a gel pad off ebay cut out a recess in seat foam and it made little difference only marginally better. Tried again with a piece of memory foam which I bought from a fabric / diy place cost me £4 , cut it to shape put into the recess I had cut for the gel pad (junked that) stapled the cover back into place and hey presto...brilliant much more comfort and I don't even notice now.
  7. Likes Daboo, IanA liked this post
    Points: 3,851, Level: 41
    I have the OEM comfort seat on my GS and I find it pretty cushy, I also own an Airhawk and have tried it with the comfort seat and it doesn't really help,,. I've been able to put in some long days on the GS and I find conditioning helps as the season progresses,,.
    The Airhawk makes a world of difference on my Ninja 1000 which has a firmer sport style seat, it may likely be the answer on your harder OEM style seat,,.
    Points: 2,294, Level: 30
    United States, WI, SE
    '74 T150T Trident
    '07 Ninja 650R
    If by " when my legs meet my tush" you mean 'where' your legs meet your tush, I suggest you try compression shorts (underwear), and specifically ones that don't have any seams where your legs go over the top-side corners of the seat.
    '08 F800ST Low
