How to replace front Left turn signal: How to separate wire connector. - BMW F800 Riders Forum & Registry
Results 1 to 4 of 4
    Points: 5,941, Level: 52
    John Robert
    Temecula, CA
    Nov 2012
    Hello Folks,
    My grandkids accidentally broke off my front left turn signal. I purchased the replacement unit. I'm in the process of trying to remove the old unit. My question is what is the proper procedure for disconnecting the wire from the bikes internal connector? The connector doesn't have a place to squeeze to separate. I just don't want to break the connector.
    Many thanks for the guidance.
    John
    Temecula, CA
    2013 F700GS
    2019 R1250RT
    Points: 15,658, Level: 86
    1,101 / 0 / 0 / 0
    Fully disassemble the turn signal unit. The wires can be released from within and then pulled out.
    Disassemble the new unit, push the wires through, connect the leads (there is no wrong order) and then reassemble.
    A note of caution: the plastic lens releases with a single screw (on the back side) but pivots out. There is a small tab - don't just yank! Also, don't overtighten the screw when reassembling. This is the voice of experience.
  4. Likes Daboo, mervingry liked this post
    Points: 11,843, Level: 75
    That connector is a pain as you say but there is a slot in one half and a small locating lug in the other half. I found that if you cut a small tab of old credit card then insert it between the slot and the lug the connector just pulls apart. It's a bit fiddly but I've used this trick several times and it works quite well.
    18 F800GT
    Points: 1,066, Level: 18
    Jul 2019
    Quote Originally Posted by Right Hand Drive View Post
    Many thanks for the insight into how to separate the connector. I ended up taking it to the dealer. They were able to replace the turn signal for me. Next time I'll be good to do it myself.
