black plastic tube - BMW F800 Riders Forum & Registry
Results 1 to 7 of 7
    Dogulator's Avatar
    Points: 1,531, Level: 23
    Dec 2018
    Can you tell me what's the black plastic tube that leads from engine to the skid plate. I'm guessing its fuel tank vent,,,, but can't find it in my manual
    Thanks...
    Dogulator
    Points: 15,487, Level: 85
    44 Minutes Ago
    1,084 / 0 / 0 / 0
    I suspect you'll find it leads to your lead acid battery.
    Points: 510, Level: 10
    Yorkshire Dales, UK
    Oct 2020
    How old is your bike? I think it could be some sort of drain from the water pump that became a feature somewhere along the line because of small leaks. Mine melted on the exhaust so I cut the melted section out and replaced it with a piece of silicon tube. (2019 GT)
  5. Likes IanA liked this post
    IanA's Avatar
    Points: 19,525, Level: 96
    Ian
    Jun 2012
    1,434 / 12 / 326 / 820
    I had exactly the same same issue on my '19 GT, Phil! Fixed it the same way, too...
  8. Likes Dalesman liked this post
    Yorkshire Dales, UK
    Oct 2020
    Quote Originally Posted by IanA View Post
    Great minds and all that...
  10. Likes IanA liked this post
  11. #6
    Yorkshire Dales, UK
    Oct 2020
    Quote Originally Posted by Dogulator View Post
    Thanks...
    Dogulator
    BTW. Nice name Dogulator!
  12. #7
    Points: 11,621, Level: 74
    That pipe on my GT was all coiled up and strapped tightly to the oil cooler metal downpipes. The cable tie was so tight it effectively sealed the rubber pipe - no way was that going to drain anything. I bought a new pipe together with the locating plug for the sump. So it's now as the maker intended. I could have done what others did though and it would have worked equally as well. As it came from the factory, it wasn't draining anything.
    18 F800GT
  13. Likes Dalesman liked this post
