Change PW w/o PW? - BMW F800 Riders Forum & Registry
Results 1 to 5 of 5
    Points: 2,585, Level: 32
    United States, WI, SE
    23 Hours Ago
    '74 T150T Trident
    '07 Ninja 650R
    I got a new PC.
    I want to log into F800riders on it. The PW I've written down isn't correct...
    I'm writing this on my old PC. The PW is saved (in/on the browser).
    I can't change the PW because the first step is typing in my current PW, which I don't have.
    How do I change / reset my PW now?!?
    '08 F800ST Low
    Points: 2,894, Level: 34
    26 Minutes Ago
    In Chrome you an access stored passwords, there's probably a way in other browsers too.
    23 Hours Ago
    '74 T150T Trident
    '07 Ninja 650R
    Quote Originally Posted by rcb78 View Post
    SWEET I DO use chrome on this PC - I'm trying out Edge on the new one
    THANKS!
    '08 F800ST Low
    26 Minutes Ago
    So I guess that means you found them? If not then go to settings and then passwords, then search for the ones you need. If your PC has a startup password or pin you will probably need it, but it's pretty straight forward tracking them down. What I'd recommend since you are using Chrome is to enable the sync feature and then every device you log into will have access to them. IF you go that route, be sure to stay on top of security and use some form of 2FA so your stuff stays secure.
    23 Hours Ago
    '74 T150T Trident
    '07 Ninja 650R
    Yep. I found it - I'm writing this on my new PC!!
    '08 F800ST Low
  8. Likes rcb78, Richard230, Oleran, HalfPint liked this post
