F800GS front drive sprocket 'welded' to spline - Any ideas regarding how to budge it? - BMW F800 Riders Forum & Registry
Results 1 to 8 of 8
    Viferpilot's Avatar
    Points: 4,827, Level: 47
    Wellington
    Jan 2015
    '14 F800GS
    Front sprocket appears to be 'welded' to the spline. Gear pullers won't budge it! Even after a bit of gentle heating
    - Anyone experienced this challenge before?
    - Any ideas on how to get this worn pinion off, safely?
    The bike is otherwise pretty well maintained.
    What would cause this pinion to 'seize' this firmly to the spline?
  2. Thanks Damon thanked for this post
    Viferpilot's Avatar
    Wellington
    Jan 2015
    '14 F800GS
    Found my own solution : Lubricant+gear-puller+patience (leave it for an hour or so)
    Cause = rust
    I might have thought it difficult for moisture to get in there? Particularly if there had been grease in there originally (?)
    Now what? i.e. rusty spline+shiny new pinion. Doesn't sound like a 'nice' union to me (just setting up for another 'welding by rust')
    Points: 10,450, Level: 70
    1,049 / 0 / 2 / 32
    i would clean it up thoroughly, and paint it with an antirust inhibitor to know it is all killed off. Then use something like Hammerite, or any other rust prevention paint and put a thin coat on it to prevent a resurgence of it.
    Dalesman's Avatar
    Points: 893, Level: 16
    Yorkshire Dales, UK
    Oct 2020
    Paint might work as DJ says.
    I would give it a good clean up with WD40 and some wire wool and then a thin coat of grease before reassembly. It'll come off more easily next time.
    ccwatchmaker's Avatar
    Points: 1,389, Level: 21
    James Sadilek
    Carson City, Nevada U.S.A
    Nov 2020
    '72 R60/5
    Anti-seize compound is what is commonly used by the construction (earthmoving) industry for these sorts of connections on heavy equipment. The are different kinds; the most common is finely ground aluminum in some sort on binder to form a paste. Probably grease. Also it is available in copper and nickel. Google the word anti-seize. This is truly the best treatment for any sort of metal to metal joints that need to be able to easily come apart when necessary.
    James Sadilek -- ccwatchmaker
  9. Likes Oleran, Roy Barnes, BoxerBits liked this post
    Points: 50,917, Level: 100
    13,540 / 8 / 110 / 2177
    Always lube splines. Axles too. I've got a container of copper anti seize I've used for years and many bikes. Would I trust that the manufacturer properly lubed the splines on assembly, NO!
  11. Likes 308bever liked this post
  12. #7
    Points: 7,090, Level: 58
    Sydney, Australia
    Sep 2011
    Hi, dealt with this only a couple of days ago on my 09 R. I actually shattered my original sprocket mine was on so tight.
    Douse liberally in wd40 or other penetrating oil. Leave it, spray on again, aiming to try and force some between the teeth.
    Get the puller fitted (use a high tensile bolt in the bolt hole, not the original, and only about 18mm long so it does not trash the thread in the spline) get it under tension then heat. I only used a heat gun (air) but get the pocket smoking. Yes there is a gasket behind but so long as you just aim the heat at the sprocket should be alright.
    It may take a day or two of this, but it works.
    The key is to apply the heat whilst it's under pressure.
    give it a good clean with a wire brush then make sure to put plenty of high temp copper grease on the spline. 50nm torque on the bolt.
  13. #8
    Points: 241,246, Level: 100
    10,074 / 15 / 698 / 2031
    Quote Originally Posted by zoefoster View Post
    great
    You asked for it. Into the spam can for you.
