F800GT narrower bar - BMW F800 Riders Forum & Registry
Results 1 to 9 of 9
    Points: 144, Level: 2
    Mar 2021
    Hi,
    this is my first attempt to change my status from a lurking guest to an active member. Hope this works!
    I've ridden my 2015 GT for two years and made some 24,000 km.
    The rear got a new spring to suit better our two up riding (progressive). Next thing is to test Ricor Intiminators to keep the front happy.
    I'd prefer a narrower handle bar. There is much discussion of rising the bar but nothing about narrowing them.
    The bar is abviously not easy to change: heaters, switches, bar end weights.
    Does anybody know a substitute for the OEM bar?
    Harri Vanhala
    Nummela Finland
    Points: 10,682, Level: 71
    2 Minutes Ago
    1,101 / 0 / 2 / 32
    Why would you prefer a narrower handlebar?
    emlevy's Avatar
    Points: 15,488, Level: 85
    emlevy
    Evergreen, CO
    1,994 / 2 / 6 / 59
    Not sure of your location, but check with Flanders Company in California. They offer a wide selection of bars.
    Mar 2021
    I checked the Flanders but they did not have a fatbar type bar for the GT. Thanks for the hint anyway!
    I prefer a slightly narrower position. One interesting problem is how the thumbs will meet the "tank" with a narrower bar.
    Not a big issue!
    Points: 251,125, Level: 100
    10,146 / 15 / 698 / 2031
    Could you just hacksaw a bit off of your existing handlebars? Or would the switches and lever pivots no longer fit on the bars? If that is the case, perhaps you could live with slightly shorter grips.
    Points: 5,905, Level: 52
    Steve Clarke
    Bay Village, OH
    May 2013
    17 Hours Ago
    DJ123 - exactly: Why??
    2 Minutes Ago
    1,101 / 0 / 2 / 32
    Quote Originally Posted by Harri Vanhala View Post
    Not a big issue!
    What bike are you comparing the the GT about the narrower position?
    I think you might encounter clearance issues on the tank the the screen at full lock/close to it. And lose some steering leverage too - you can be more precise with a wider bar that takes less effort to move.
    Mar 2021
    Actually I do not compare the bar width with any other bike although my previous bike was R100RS with a narrow bar. I rode on it 286,000 km so if there is a reference it is the RS. These bikes are totally different in all respects (tank badge excluded) so I pretend not letting old experience affect my opinion.
    I just prefer a little narrower bar and maybe a slightly different angles. Helmut Boensch (in his book Einfuehrung in die Motorradtechnik) wrote of a research on the forces used to steer a motorcycle. If memory serves an average rider wants to feel a force corresponding to 200 grams weight in his palms. Maybe I'm on the heavy side in this respect. My background is in motocross and enduro where the feel and steering forces are under continuous variation.
    There is a huge variation of bars available. The problem is that BMW bars have some special features so direct replacement is not possible.
    I love this bike and can easily adapt to the OEM bar. I had some trouble with my butt but dropping the pegs with 25 mm solved that problem totally. I'm 190 cm tall so the riding position was slightly cramped ("the bureau was too small").
    Thanks for comments!
    Points: 2,198, Level: 29
    Actually I do not compare the bar width with any other bike although my previous bike was R100RS with a narrow bar. I rode on it 286,000 km so if there is a reference it is the RS...
    You did well with that R100RS Harri.
    Used to love the 82 twin shockone that I owned some time back. Ironically I found the standard narrow bars fitted hard on the wrists on long trips. Great bike apart from that though, looked the part with the 3/4 seat fitted.
    Hope that you find a way forward with your F800GT.
    Ride safely.
