F800ST stator/voltage regulator replacement and oil - BMW F800 Riders Forum & Registry
Results 1 to 13 of 13
    Points: 5, Level: 1
    May 2021
    I know its probably been done to death on the forum, but I couldn't find the answers with a search and I'd appreciate a couple answers;
    I'm in the process of changing a burnt stator (voltage regulator while I'm at it) on my 2008 F800ST. A decent amount of oil came out of the engine stator cover, which I assume is normal?
    Am I correct in saying the oil inside the stator assembly is normal engine oil? I just had a car mechanic tell me it was gearbox oil which doesn't seem right.
    Thanks for any input
    Points: 5,832, Level: 52
    Peterborough, Cambs, UK
    Engine oil. Gearbox shares the same oil - common on most bikes.
    Points: 17,227, Level: 90
    1,164 / 0 / 0 / 0
    Engine oil. Lubricates and helps cool the engine, clutch, stator, gears.....
    There are only four fluids - brake fluid, coolant, suspension fluid and engine oil. And gas.
    The mechanic may want to stick to diagnosing things with four wheels. Or not offer unfounded advice.
    Points: 47, Level: 1
    May 2021
    It's the reason we have the alternator. The alternator is the part that creates that power. As you're driving along, the alternator makes energy to control the framework while the overabundance energy is utilized to re-energize the battery.
    Points: 259,597, Level: 100
    29 Minutes Ago
    10,234 / 15 / 698 / 2031
    Welcome, Jacquelartin. Why don't you fill out your profile and let us know what motorcycle you ride and where you live. That would help us answer any questions you may have.
    N4HHE's Avatar
    Points: 19,613, Level: 96
    David Kelly
    Madison, AL
    Feb 2010
    1,903 / 18 / 47 / 424
    '16 FJR1300A
    '09 FE450
    I thought blinker fluid comes out when the stator cover is removed!
    'cause, you know, the stator drives the blinkers, right?
    But seriously, it is easier to make stator windings run in motor oil than it is to seal a chamber to keep oil and water out. Plus the motor oil can help keep the stator from getting extremely hot in a sealed compartment. Motor oil is hot but not as hot as wires can get.
    Points: 9,702, Level: 68
    As mentioned above, the oil is there to cool the stator. There were lots of early model stator failures due to the rotor design that didn't let much oil through. The newer design (2010ish) looks more like Swiss cheese which aids in cooling and prolongs stator life. I replaced my stator 4 times on my 08' ST before finally upgrading to the new rotor. It's been great since then.
    bmwroadsterca's Avatar
    Points: 12,849, Level: 78
    More like 2013ish.
    Points: 3,171, Level: 36
    Rod
    Walnut Creek, Ca
    May 2019
    I'm pretty sure my stator is burnt out as well. I tested the reg/rec and it seems fine, haven't tested the stator yet (that plug is a PITA to get to), but voltages at idle are between 11.7-12.3, with occasional spikes to 13.3V while riding. Voltage does not go up uniformly when I increase throttle, but the spikes seem to suggest the stator is working SOME of the time (but usually not).
    I'm about to order a new stator from electrosport once I confirm the stator is dead, but how much of a pain was it to upgrade the rotor?
    N4HHE's Avatar
    David Kelly
    Madison, AL
    Feb 2010
    '16 FJR1300A
    '09 FE450
    Quote Originally Posted by rodzghost View Post
    You have proven the problem is not the battery? A perfect stator can't punch a battery with dead cell much over 13.2V.
    It's a bit of a pain, but I have found that heat and a good impact wrench make it manageable. The rotor is heavy so it takes a while to get it up to 350 degrees f. You'll need a powerful torch (not a flashlight!). Once it's hot, hit it with an impact wrench. Don't try to lock the engine in TDC and use a big cheater bar like the shop manual says. The impact wrench is much more effective. Be prepared to catch a very hot rotor when it breaks free. Oh yeah, you will need a puller like this: https://smile.amazon.com/dp/B002308E...ing=UTF8&psc=1
    The biggest challenge is finding a new one to install. BMW only sells them as a kit with a stator. You will need special thread locker for the installation.
  14. #12
    Rod
    Walnut Creek, Ca
    May 2019
    After reading all these posts about looking at reg/rec and stator first, I was a bit wary about just popping in a new battery and testing that. But I suppose that battery could be a good second step now that I've confirmed the reg/rec is at least preventing the battery from being over-charged. It also looks like the diodes are all functioning properly, as my meter shows that current can only flow one way.
    Now that I think about it, my new battery was able to get up to 14.5v on my battery tender, but the old one never goes past 13.3v, so it could very well be what you say about a dead cell.
  15. #13
    N4HHE's Avatar
    David Kelly
    Madison, AL
    Feb 2010
    '16 FJR1300A
    '09 FE450
    Put the questionable battery on a maintainer or proper charger and see what its doing the next morning. 13.3 is right in that magic range which shouts, "Dead Cell!"
