Delkevic end can - BMW F800 Riders Forum & Registry
Results 1 to 7 of 7
    Points: 1,099, Level: 18
    Somerset, UK
    Aug 2020
    Fitted this the other day after reviewing a few posts on exhausts on here. A Delkevic DL10. I paid extra for the black as I think it sits perfectly with the black of the bike.
    I wanted a nice sound without being overly obtrusive and after a couple of rides it seems to be just right.
    Thinking my next mod will be quite humdrum, just some tank pads as I want more purchase when I'm trying to brace against the tank (battery). I like the Wunderlich ones Nippy Norman offer but... £47
  2. Likes theSpeedRacerX liked this post
    Points: 1,700, Level: 24
    Lonnie
    Selah, Wa
    14 Hours Ago
    looks good -
    '93 DR350S
    Points: 27,838, Level: 100
    Charlotte, NC, USA.
    Nov 2007
    2,213 / 0 / 166 / 204
    I have a similar unit on my F650GS.
    It's a great piece of equipment, but I picked up some vibration that makes it through the metal-on-metal rear hanger.
    The OEM unit has a nice big soft rubber bushing ...
    Has anyone found a way to "bush" the rear hanger?
    thanks!
    theSpeedRacerX's Avatar
    Points: 56, Level: 1
    Banish
    Birmingham AL
    Jul 2021
    I had a Tomei on my WRX that had a rubber insert (Google Tomei Exhaust Silencer Rubber Band, I'm too new to post a URL) that was form-fitted to the hanger and around the muffler can. I've recently learned to love Hi-Temp RTV silicone. What if you removed the hanger and lined it with the RTV silicone so simulate this band, let it set and then hook the hanger back? With the silicone, you could make the inside of the hanger as thick or thin as you would want to dampen vibration. The silicone would be heat resistant which you would want on a hot exhaust and if it doesn't work, just remove the hanger and rub the silicone off.
    Charlotte, NC, USA.
    Nov 2007
    Thanks Banish!
    mine came with rubber insert for the can strap(hanger) ....
    and it is helpful... but am still wondering if there is a way I can "replicate" the OEM isolation mount more or less...
Name:	isolation mount.jpg
    Points: 1,470, Level: 22
    Wales, United Kingdom
    Oct 2019
    I have never bothered with aftermarket exhausts, the stock ones are just fine. I bought a BMW R1100S that had a Two Brothers carbon fibre tail pipe. Zero baffles in it and it could wake the dead. Managed to obtain a standard BMW tail section from the USA (none 2nd hand in UK at the time) and peace returned for the remaining 11 years that I had the bike.
    Charlotte, NC, USA.
    Nov 2007
    Quote Originally Posted by mh374 View Post
    I hear ya...
    I bought the Delkevic as this was the ad copy that came with it... the ad copy was correct, but the "suspension" / hanger system ... like pretty much every aftermarket can I've seen...
    Leaves something to be desired...
    Delkevic 18" carbon fiber oval mufflers are manufactured from a pre-formed carbon fiber composite sleeve and 304 stainless steel. This muffler has the quietest, deepest tone of mufflers we offer. This will be the closest sounding to stock available and best for long haul trips.
