Accessory switched circuit question - BMW F800 Riders Forum & Registry
Results 1 to 3 of 3
    Lag's Avatar
    Points: 6,089, Level: 53
    Lyle
    Whiterock British Columbi
    16 Hours Ago
    '15 F700GS
    On the F700GS?
    I've been running a set of axillary lights off the switched circuit that is located above the battery,,. The set up came with a 30 amp fuse so I left it on the wiring harness which is wired into the switched circuit with the Motorrad adapter plug,,.
    I was planning on cleaning up the wiring harness wires and it occurred to me that I likely don't need the 30 amp fuse block serves no purpose.
    Dose anyone see a potential problem with removing it?
    308bever's Avatar
    Points: 3,475, Level: 38
    bever
    geelong vic au
    Jun 2018
    '13 F700GS
    can`t go wrong with the extra protection, leave it in. 30 amps seems high!
    Points: 5,832, Level: 52
    Peterborough, Cambs, UK
    Yes, the circuit is electronicaly limited to 5A.
