Oil change - BMW F800 Riders Forum & Registry
Results 1 to 8 of 8
    Points: 4, Level: 1
    May 2021
    Hi there, this is my first post. I have a 2009 F800ST and I want to do an oil change. I don't have a manual. The sump plug appears to be a Torx 55. Can anyone confirm this?
    Points: 267,030, Level: 100
    8 Minutes Ago
    10,336 / 15 / 698 / 2031
    Welcome to the forum. I just checked my 2009 F650GS, which should have the same engine as yours. The oil drain plug is a standard 24mm hex bolt.
    Points: 9,165, Level: 66
    NA
    Feb 2013
    1,436 / 0 / 0 / 12
    15/16 actually fits better than 24mm for my ‘07 ST drain plug.
    They’re basically the same size, with the 15/16 being a few thousands under size.
    Cheers, Harvey
    07 F800 ST
    Points: 5,968, Level: 53
    Peterborough, Cambs, UK
    16 Hours Ago
    Unless of course someone has changed the standard plug.
    Carefully try a T50 torx and Allen key. By the way I thought the 24mm refered to the thread size???
    It should be obvious which fits properly.
    On my 2016 GT its a hex (Allen) recess.
    8 Minutes Ago
    When I mention bolt sizes I think of the tool needed to loosen the bolt. I rarely have any idea what the actual diameter, thread size, pitch, etc. is of a fastener. All I ever care about is the tool needed to loosen and tighten the fastener - and where it is located in my tool box.
    NA
    Feb 2013
    1,436 / 0 / 0 / 12
    Sorry for the confusion.
    I use a 15/16 socket on the drain plug on my ‘07 because I do not possess a 24mm socket, and they are the same size anyway.
    i do have a 22&23mm for my milling machine. And a 26mm for my tractor.
    a lot of the larger metric & imperial tools will interchange.
    i actually have a 1-13/16 socket if I ever (God forbid, knock wood) have to replace the infamous rear wheel bearing.
    cheers, Harvey
    07 F800 ST
    Sundog52's Avatar
    Points: 8,327, Level: 63
    Geoff
    Birmingham in Alabama
    '94 R1100RS
    10mm
    Sundog
    Points: 773, Level: 15
    Geoff
    Rochester, New York
    Jun 2020
    It's confusing because there are two bolts used, Sundog is right, it's a 10mm Allen. I have an 08 F800ST which has a 24MM Hex bolt (not socketed) which requires a 24MM socket, a 15/16" socket will also fit as it's only about 0.0074" smaller (hence the tighter fit some people are mentioning). The newer bolts being used by BMW are M24x2 but are NOT hex, they have a 10MM Hex shaped recess (Allen).
    This is the newer bolt that came out sometime around the 2008-2010 timeframe so you can confirm, this is the one that uses 10MM Allen.
  11. Likes 308bever liked this post
