noisy vibrating fairing - BMW F800 Riders Forum & Registry
Results 1 to 13 of 13
    Points: 257, Level: 5
    angus cargill
    kirkcaldy fife scotland
    May 2021
    I am new at this F800GT thing------love the bike but it does have its foibles----the fairing seems to vibrate badly when giving it the beans accelerating through ( I think 4000rpm) it passes after that. Is it just me or does everyone's GT do that?.
    Points: 11,091, Level: 72
    1,179 / 0 / 2 / 32
    Which part of the fairing in particular? Does it feel like loose body work, or simply engine vibrations being transmitted through the frame?
    Points: 1,700, Level: 24
    Lonnie
    Selah, Wa
    22 Hours Ago
    nope, mine doesn't - but then it just turned 4k miles on tuesday - mileage, or lack of it, may contribute -
    '93 DR350S
    Points: 17,406, Level: 91
    45 Minutes Ago
    1,180 / 0 / 0 / 0
    Little to no movement (on my ST) which is what I would expect.
    Maybe a double check of the fasteners?
    Points: 1,441, Level: 22
    West Yorkshire, UK
    Feb 2021
    '18 F800 GT
    Quote Originally Posted by guscsr65 View Post
    Just you. Seems an odd sort of issue, I'd be checking the fastenings
    Ajay
    F800GT 2018
    Points: 13,079, Level: 78
    Does your bike have the stock windscreen.....or something bigger/heavier?
    I don't have any fairing vibration related to engine rpm or acceleration - when I mounted a larger/heavier windscreen I noticed it flexed more and the fairing moved more as well.
    I do have a heavy "clunk" noise when I hit big potholes. I have not yet figured out if that is the front fender slapping the tire, or the brakes discs being jolted.....or something in the bodywork.
    Points: 3,686, Level: 40
    GB
    Aug 2016
    17,000 miles and no fairing vibration on mine. And all the panels have been off numerous times
    BMW F800 GT
    angus cargill
    May 2021
    Thanks to all for your replies, I will have a closer look----although none feel loose at first feel.
    Points: 3,290, Level: 37
    Norton, Kansas
    Mar 2017
    I had this thread in mind yesterday as I was listening to a horrible vibrating sound coming from somewhere in front of me. It sounded like the bike was falling apart. At one point, I decided to even stop and see if the fairing pieces were still tight by.
    When I stopped to get the mail, I found the culprit. I use a magnetic holder for my radar detector. The magnets on the underside were loose and vibrating. It wasn't the fairing at all.
    Blapper's Avatar
    Points: 2, Level: 1
    Mar 2021
    By 4000rpm mine is smooth, but I wondered if it really is 4000 and not 3000 because 3000 in the higher two gears is too low and that may shake things a bit.
    @thumpin: yours is most likely front fork internals over potholes.
    Points: 1, Level: 1
    May 2020
    For me I had this issue and it turned out to be my cell phone holder clipped to my handle bar.
  14. #12
    Lag's Avatar
    Points: 6,485, Level: 55
    Lyle
    Whiterock British Columbi
    51 Minutes Ago
    '15 F700GS
    Angus, I cant speak to the GT, but my GS had a plastic buzz right a round 5,000 and I chased it and chased it,,. I used to put the throttle lock on at certain speeds and press here and there, finally after taking the fairings off I put a couple of furniture leg pads between the fairing and the air box for no particular reason and low and behold my vibration/buzz stopped, not sure if it was the placement of the pads or the refitting retightening of everything,,.
    Another bike I had, a none BMW, had a plastic buzz at 4500 rpm, which was not particularly a very vibey part of the rev range however it drove me nuts, tried weights, tried masking tape, tightening, loosening. Finally I found that If I put a silicone bead between the two pcs of dash that it resolved the problem,,. Bit of a pain each time you take it apart but better then a buzz,,. All this might not be much help for the GT however the point is that if your OCD enough you will eventually find it,,.
  15. #13
    Quote Originally Posted by Blapper View Post
    Thanks for reminding me of that issue......I had somehow forgotten that it was a "thing" on this bike.
    That is definitely something I want to fix - it makes the bike sound cheap!
