Rear Wheel Balancing - BMW F800 Riders Forum & Registry
Results 1 to 15 of 15
    Points: 3,805, Level: 41
    Glenn
    Chelmsford, UK
    Apr 2017
    '57 G80s
    '66 A65 Lightning
    '05 999
    '15 F800 GT
    I have to get some new tires fitted and it always seems a problem to find anyone local that can balance the rear wheel. I just wondered if you know if car tyre dealers are able to balance our single sided wheels.
    I realise I could get BMW to do it but I would rather not pay over the odds for this basic service.
    Points: 74,667, Level: 100
    4,901 / 0 / 9 / 3
    This isn't a direct answer to your question, but an alternative thought.
    I used to have the local dealership change and balance my tyres. Then I got fed up at the price increase they made and started changing my own tyres. One of my big concerns was on how to balance the tyres.
    I bought some balance beads and used those the first time. One ounce for the front wheel and two ounces for the rear wheel. The next set of tyres, I decided to see how bad they felt without the balance beads and to my surprise, they felt fine. I've changed about 5 sets of tyres at least since then and only on one other set have I added balance beads to them.
    So you may want to see how bad the tyres are without balancing the wheels.
  4. Likes N4HHE, notacop liked this post
    Points: 11,500, Level: 74
    1,270 / 0 / 2 / 32
    Quote Originally Posted by trig View Post
    Not had any issues at any Motorbike fitting place i've ever been to. Have you checked with your local tyre dealer (if they also sell motorcycle tyres)?
    BMW F800ST, 2010, Black, Fuzeblock, Sat Nav, BMW Tank Bag, Givi Touring Screen, Denali Spotlights, Denali CANSmart, Wunderlich Crash Bars, 62K Miles & counting
    Points: 20,387, Level: 98
    1,962 / 18 / 47 / 424
    Marc Parnes sells a balancer and necessary adapter for single sided bmw wheels. Do it yourself. First time will take about as long to balance as it takes to remove/install the wheel.
    Very low friction gravity balancer. It can not go out of calibration. More sensitive than 1/4 oz.
    Use tape to hold weights to the rim until you find correct balance. Then use the super sticky tape the weights come with.
    With shipping, adapter, and everything the Marc Parnes will probably be over $150. But it doesn’t occupy much space and is a good lifetime investment. Might balance tires for friends in exchange for lunch or beer.
    Points: 9,108, Level: 66
    Dave Watson
    Nov 2014
    I do balance front and rear. I've found that although I may not feel any vibration from a slightly out of balance wheel, the tyre wear is not even around the circumfrence (at the end of their life the tread depth is none existant in some places and 0.5mm in others). I've bought some roller bearings that fit either end of the wheel axle (this needs to be done because using the axle alone, the dust seals in the wheel create too much restistance), and put the whole sheerbang on a pair of car jack stands. There are also a number of cheap motorcycle balancers that use a similar technique available on the net.
  9. Likes N4HHE liked this post
    4,901 / 0 / 9 / 3
    So I'm curious about this. A dynamic wheel balancer would be the best option, but at the prices they go for, it isn't going to happen. So last night I was looking at static wheel balancers. Then I got to thinking of the difference between how a dynamic wheel balancer works, and how a static one works. With the dynamic wheel balancer, you're counteracting lateral as well as vertical rotational forces. With the static balancer, you're only affecting the vertical rotational forces.
    At that point, I'm not sure I see any difference between using stick on weights with a static balance machine or products like balance beads or Ride-On. The static balancer determines the amount of weight to affix permanently. The balance beads or Ride-On adjusts as you ride using centrifugal force.
    What do you think? Am I missing something?
    I'm not saying you didn't experience this, but I haven't found it happening on any of the tires I've mounted. Maybe there's other causes to your tire wear?
    Closterman's Avatar
    Points: 1,248, Level: 20
    Martin
    Montreal, Quebec
    22 Hours Ago
    Aren’t all car wheels single sided?
    Anyway... last spring I took my bike tires along my car tires to my usual mechanic. I asked if they could balance them as well.
    The only limitation was the axle diameter. The rear wheel axle hole was big enough to slip on the wheel balancer shaft but not the front one.
    Points: 15,082, Level: 84
    I had one tire mounted and balanced by Wheeler's in Robbinsville, NC. His dynamic balancer had several cones that he sorted through to find the one that fit best......the back side of the wheel goes against a flat surface and the front side is centered on the tapered cone (I was out on a ride and I needed a tire ASAP). The balancing machine he used appeared to be very similar to the ones in shops that service cars - however the adapters might be different for motorcycle wheels....the only way to find out is to go visit your tire shop and find out.
    I mount and balance my own tires when I am home. I built a static balancer that works very similar to the Marc Parnes one - I have tools and prefer to build things when I can avoid paying money.
    I had to make an adapter for the BMW rear wheels - one side fits my F800 and the other side fits the R1200. The adapter is made from plastic and slides into the wheel center, then a tapered cone is fitted on the other side and fastened with 3 screws.
    It works great and I use the stick on weights. The only big issue is that wheel weights are no longer lead and it takes more of them to balance, and the BMW wheel is not balanced as the TMPS sender throws it out of balance. (I am tempted to epoxy or bolt a weight on the inside of the rim that offsets the amount of weight needed to balance the wheel/tire........I am just not sure the epoxy or bolted weight would stay attached at 100mph......however the TPMS sender is bolted and doesn't come off).
ID:	374353   Click image for larger version.
ID:	374355   Click image for larger version.
  13. Likes Richard230 liked this post
    Spin balancers look high tech and sexy. Their main purpose is to be idiot proof because skilled labor is harder to find than a few thousand bucks for a spin balancer. Problem is these machines are not idiot proof and require periodic calibration (or at the very least an attentive operator) to verify they are actually balancing the tire+wheel assembly and not making it worse. Cycle Gear will balance any motorcycle tire in store for free. I took the first tire+wheel I mounted to my local Cycle Gear for balance. Watched with fright as the clown spun the wheel, affixed weights, spun the wheel, affixed more weights, spun the wheel, affixed more weights, and finally declared my wheel balanced with 10 weights. I had balanced it before he started. Took it home and put it on my balancer. Verified it was wrong. Took the weights off and balanced it again. Took 2-3 7g weights.
    Yes, on a wide tire an imbalance to one side or the other can induce a gyroscopic procession making the wheel want to turn. A good spin balancer can place weights in different places inside and outside to compensate. But these days most would rather have the weights hidden on the inside.
    Balance beads have to re-balance every time the wheel gets up to 40 MPH. Several problems. The beads will not move unless the wheel spins out of concentric. This also means the beads move on every crack or irregularity on the road. Also, note the bead instructions state once beads are installed one can not spin balance the wheel because the beads will never move with wheel held rigidly on the spin balancer's axle.
  15. Likes Richard230 liked this post
  16. #10
    4,901 / 0 / 9 / 3
    Thanks, David. I was hoping someone had some insight.
  17. #11
    Points: 9,983, Level: 69
    Roy Barnes
    Pasco Wa.
    Jan 2009
    Quote Originally Posted by N4HHE View Post
    Also remember the beads will move with any change of speed.
    Riding for the SON
  18. #12
    Forgive me if this is dragging the thread off topic - it is related to the balancing beads in a small way.
    When I was a kid back n the 60's, my dad was an Allstate Insurance agent and his office was in the Sears store. In the automotive department I remember seeing wheel balancing discs for sale.......and you can still buy these today.
    https://www.centramatic.com/wheel-balance.rhtml
    If his technology is so good - why aren't they used more often? If "cost" is the reason - why aren't they factory installed on luxury cars or trucks? Why aren't the bead balancers incorporated into factory wheels? If these things are so good and were factory installed - balancing wheels/tires would no longer be necessary.
    For my cars and motorcycles having the wheels balanced when new tires are mounted works just fine.....even my static balance seems to work just fine on my motorcycles and I have never felt any tire related vibration (the one exception to this was when a wheel weight came off of my R1200......the rear wheel created a noticeable vibration while riding - it went away when the rear wheel was removed and balanced).
  19. Likes N4HHE liked this post
  20. #13
    Points: 278,401, Level: 100
    25 Minutes Ago
    10,462 / 15 / 698 / 2031
    My dad installed a set of JC Whitney automatic wheel balancing rings on his '57 Ford sedan. They bolted on to the outside of the wheels and consisted of a ring with lead weights that could slide around the ring to "balance" the wheel as you drove along. I thought it was a crazy idea, but he believe they worked - along with his Fire Injectors, magnetic fuel line supercharger and various other gadgets bought from ads in the back of his Popular Science magazine. (And no, he wasn't a Republican, but a dyed in the wool Democrat. ) Personally, I always thought that nothing he could do would make that 6-cyclinder Ford run any better.
  21. #14
    Yes. The physics is sound for an ideal environment but hitting cracks and bumps on the road throw the beads requiring a rebalance. Perhaps advocates don’t notice double or triple hits when they hit bumps?
    I absolutely would not use on a wheel with TPMS
  22. #15
    4,901 / 0 / 9 / 3
    ...If his technology is so good - why aren't they used more often? ..
    Actually, I think the principle is used more often than we think. I think the balancing beads use the same principle.
Name:	2021-09-16 19_38_40-2021-09-16 19_36_06-Counteract Balancing Beads _ The only tire balancing pro.png
    From what I've seen, the rebalancing when hitting a bump, happens so fast you don't know it happened. The beads are so tiny, it isn't like a one ounce weight is shifting and trying to sort itself out. I've had the bike in triple digits and not had a problem.
    As far as the TPMS sensor goes, that also hasn't given me an issue beyond the battery going bad over a couple years...which is normal.
Name:	2021-09-16 19_36_06-Counteract Balancing Beads _ The only tire balancing product proven to impro.png
