2013 gs acceleration stutter - BMW F800 Riders Forum & Registry
Results 1 to 19 of 19
    Nolan6838's Avatar
    Points: 2, Level: 1
    Sep 2021
    Hey there, I have a '13 f800gs US model that has recently started stuttering and missing under hard acceleration. I cleaned the IAC and it seems to be functioning properly, I changed the O2 sensor, plugs, and will be changing the fuel filter as well. Is there anything else I should look into? I'm wondering if there is any bench test procedure for the fuel rail pressure sensor as that is my next suspect.
    Thanks
    Solved fyi, new fuel pressure sensor.
    Points: 11,683, Level: 74
    1,293 / 0 / 2 / 32
    When were spark plugs last changed and gapped?
    Points: 28,479, Level: 100
    Charlotte, NC, USA.
    Nov 2007
    2,235 / 0 / 166 / 204
    Do you have access to a GS-911 a motoscan? A scan for fault codes might be helpful.
    I have not tried this my self, but the advice of one of the old experts was/is that if you suspect the fuel pressure sender unit to be bad
    it can be unplugged for diagnostic purposes. The ECU is smart enough to recognize that the sender is not on-line and then
    guesstimate what to do without it, but the ECU may not always detect a situation where it is sending a bad signal.
    It is also possible to bypass the fuel-pressure regulator / FPR (that sits on top of the fuel tank) to see if that makes any difference...
    Nolan6838's Avatar
    Points: 2, Level: 1
    Sep 2021
    I do not have a scan tool. One thing I did try was unplugging the sensor and running it on the stand. It seemed to not make a difference with it plugged in or not. This is why I'm leaning in this direction. I'm mostly looking to see if anyone else has had the same symptoms fixed by a new pressure sensor.
    Nolan6838's Avatar
    Points: 2, Level: 1
    Sep 2021
    New spark plugs were just installed, no change.
    Points: 290,368, Level: 100
    10,524 / 15 / 698 / 2031
    I am cheap and lazy so the first thing I would try is to dump in some fuel injector cleaner to see if that makes any difference.
  9. Likes 308bever, Roy Barnes liked this post
    1,293 / 0 / 2 / 32
    Quote Originally Posted by Nolan6838 View Post
    Sorry, i missed that in the original post.
    have you used a different fuel station recently, or a different grade of fuel?
    Is the air filter cleaned and installed correctly? Is the air box secure on the throttle bodies, no air leaks?
    Nolan6838's Avatar
    Points: 2, Level: 1
    Sep 2021
    Same fuel grade and usual stations, all air box hoses and filter is in check.
    1,293 / 0 / 2 / 32
    when you say hard acceleration, is that in any gear and winding the throttle fully open? or is it at high revs this occurs?
    Nolan6838's Avatar
    Points: 2, Level: 1
    Sep 2021
    I mean quick acceleration at any rpm, any gear. If I ease into the throttle it usually doesn't happen. Doesn't matter if it's a quick half or full twist.
    Side note; when I pulled the old plugs they were black like it was running rich. I haven't pulled the new ones yet to check what they look like.
    1,293 / 0 / 2 / 32
    The fuel rail is always pressurised as the F8 engine has no return/bleed back to the tank. If you were failing on low fuel pressure i would think you'd feel it all across the rev range, regardless of throttle input (i am only assuming here - i have no experience in fuel issues on this bike)
    Have you done a TPS (throttle position sensor) reset?
    1. Turn on ignition but do not start the bike
    2. Turn the twist grip from zero to fully open and hold fully open for 5 seconds
    3. Wait 5 seconds and repeat step 2. another 4 times (do 5 times in total)
    4. Then turn off the ignition and wait at least 15 seconds before turning the ignition back on.
    5. Ride and try
    Nolan6838's Avatar
    Points: 2, Level: 1
    Sep 2021
    5. Ride and try
    I haven't found a straight answer yet so correct me if I'm wrong. I've gathered that the fuel pump runs at 2 different speeds based off of demand so if the pressure sensor is failing in that it reads lower than actual, wouldn't the pump try to compensate by running at the higher pressure and possibly causing more fuel to be injected on each injector pulse?
    As far as a tps reset, is there any sort of visual or audio confirmation that it has completed? Ive read about it before and each person's process is slightly different so I don't know which one is technically correct.
    1,293 / 0 / 2 / 32
    If the fuel pump does, then even rolling on the throttle and running at higher RPM's i would think you'd have stuttering issues too. If the sensor is faulty it would still reach that point where it is not supplying enough for what is being asked. (i have no experience of this, or in-depth knowledge about the fuel pump.)
    There's no TPS reset confirmation on the F series, as far as i'm aware. But usually you can 'feel' if there is a difference when you next ride it.
    Does it do the same stutter if you rev it when stationary?
  17. #14
    Nolan6838's Avatar
    Points: 2, Level: 1
    Sep 2021
    Yes it stutters on the stand on a quick throttle rip.
  18. #15
    1,293 / 0 / 2 / 32
    Have you ran it with the fuel pressure rail disconnected? I think it should run, but may show an EML.
  19. #16
    Nolan6838's Avatar
    Points: 2, Level: 1
    Sep 2021
    If you mean the sensor disconnected, yes briefly on the stand. I didn't notice any difference. I bit the bullet today and ordered a new sensor. Turns out it's available through bmw car dealerships as it was also used on some cars. I'll find out Tues if that was it.
  20. Likes DJ123 liked this post
  21. #17
    Charlotte, NC, USA.
    Nov 2007
    There is no test for the fuel pressure sender in the BMW manual. But it infers that a fault code would generally be stored.
    Here's what the Haynes manual has:
Name:	fuel pressure sensor.jpg
  22. #18
    Nolan6838's Avatar
    Points: 2, Level: 1
    Sep 2021
    Solved. New fuel pressure sensor fixed the issue (I hope). Went for a couple rides a day apart and at first it had some slight hesitation but once warmed up it went away. 2nd ride was fault free.
  23. Likes Richard230, 308bever, IanA, DJ123, jrwooden liked this post
  24. #19
    Charlotte, NC, USA.
    Nov 2007
    I'm guessing that the initial ride was slightly off due to the "adaptation" values for the engine re-settling.
