voltage and battery state of charge - BMW F800 Riders Forum & Registry
Results 1 to 8 of 8
  1. Joined
    Jump to Comments
    7 Comments by Richard230 Published on 10-23-21 08:52 AM
    Here is a little chart that I was sent by Batterystuff.com which shows the relationship between measured voltage and the remaining level of charge of a typical lead-acid battery:
    State of Charge Voltage
    100% 12.7 - 13.2
    75% 12.4
    50% 12.1
    25% 11.7
    Discharged 0 - 11.6
  2. Total Comments 7
    Comments
  3. #2
    Points: 52,115, Level: 100
    13,623 / 8 / 110 / 2177
    That's reasonable but. I noticed my G650 was charging at 14. 4 volts on a run but when I attempted to start the bike after lunch it balked a little. i checked at home and the battery was down on fluid so I topped the battery off. 650 Forum guys blame the boiling over due to the battery location. Same place as on my F800ST and it never has a fluid loss.
    So voltage only won't necessarily tell you the whole truth of battery health.
    Points: 81,182, Level: 100
    5,025 / 0 / 9 / 3
    I have read the forum posts that call for a certain amount of voltage and found I rarely get that. I think there are a lot of factors that play into this, like where you're measuring voltage.
    One of the features on my Uniden DFR9 radar detector is a voltage readout. Rarely does it read 14.0 or 14.1. I don't think I've ever seen it at 14.2. Where it is usually reading is in the mid-13s. Maybe because the battery is charged?
    Points: 3,876, Level: 41
    15 Hours Ago
    '20 F900XR
    Where are you pulling power for the detector from?
    Kevin313's Avatar
    Points: 12,690, Level: 77
    Owings Mills, MD
    Aug 2008
    289 / 0 / 35 / 48
    Looks like a decent 'rule of thumb' for a battery at rest/ignition off (and at least a couple hours or so since charging).
    For the heck of it, just measured mine at 12.86V, ~ 1 year old battery, last ridden/charged 48 hrs ago.
    2020 F900R Blue
    N4HHE's Avatar
    Points: 20,867, Level: 99
    David Kelly
    Madison, AL
    Feb 2010
    35 Minutes Ago
    1,999 / 18 / 47 / 424
    '16 FJR1300A
    '09 FE450
    The chart is a good starting place but there are other complications. Voltage depends on temperature. Also there is a thing known as a “surface charge” which can result in 1,2V higher reading. There is relatively little power in the surface charge so it is easy to burn off by turning the headlights on for 30 seconds.
    Lead-acid batteries need 0.2V more to take a charge. 12.6V battery has to have at least 13.8V to charge to 12.6V. Higher voltage will pass more current which will charge faster, up to a point. As a result we commonlty see 14.2V on a battery being charged.
    N4HHE's Avatar
    David Kelly
    Madison, AL
    Feb 2010
    35 Minutes Ago
    '16 FJR1300A
    '09 FE450
    Never add water to an AGM battery. Some require field activation (longer shelf life) but for that one application should never be serviced.
    My F800S battery lays at an angle no flooded lead-acid could function without spilling.
    MN4, Mine is your average run of the mill lead acid battery. Dinosaur like me. I have some battery water I use to top it off.
    One of the newer designs would be a mo bettah thing but I just grabbed what was available at Auto Zone.
