Deka Replacement Battery for F800 ST? - BMW F800 Riders Forum & Registry
Results 1 to 23 of 23
    Elk Grove, Ca
    Hi,
    My OEM Exide battery died and will not take a charge. I have less than 1000 miles on my bike, but was lax in getting it on the Battery Tender Plus in time for the winter. I have a local supplier that can sell me a Deka ETX14 for $85, but I am not familiar with the brand. I know of WestCo and Yuasa. Is this a comparable/good battery? Is this also the correct AGM replacement for an F800 ST?
    Lastly, on the F800, do you need to remove side fairing to remove the battery, or can you get it out ok just removing the seat and 'fake' tank cover?
    Thanks.
    SunnY's Avatar
    Points: 25,620, Level: 100
    Sandro P
    Ontario, Canada!
    Jan 2009
    2,774 / 19 / 192 / 677
    '08 F800S
    Thats a "real" tank cover, not a "fake" one.
    Never heard of Deka. Doesn't mean they are no good. No fairing removal required.
    What feels better than banking a motorcycle over into a corner?
    mXarad's Avatar
    Max Schling
    Albany, NY
    Jan 2009
    I understand that DEKA gets rebranded as H-D oem equipment.
    <intentionally left blank>
    N4HHE's Avatar
    Points: 16,752, Level: 89
    David Kelly
    Madison, AL
    Feb 2010
    1,811 / 18 / 47 / 424
    '16 FJR1300A
    '09 FE450
    Unlike many other brands, Deka is a real battery manufacturer. As stated by others already, Deka manufacturers batteries for other brands as well.
    Deka is good stuff.
    Elk Grove, Ca
    Thanks for the responses.
    Made the mistake of having my local dealer cross-reference the Deka part number to verify it was comparable/compatible as far as cca and Ah, only to be told that "if I install an aftermarket battery it will void the remaining year and a half on my electrical warranty".
    I find that to be crap. It is not like I am modifying the bike, and even BMW has to know that the OEM batteries are junk. But, fyi, the Deka ETX14 is a proper and compatible replacement part for the F800S and the F800ST.
    N4HHE's Avatar
    David Kelly
    Madison, AL
    Feb 2010
    '16 FJR1300A
    '09 FE450
    Quote Originally Posted by tjmmav21 View Post
    Magnuson-Moss Warranty Act of 1975 places the burden on dealer and manufacturer to document that your use of non-OE replacement caused the damage. Exactly the same thing applies to selection of motor oil, you can not be bound to use only BMW oil to retain your warranty unless free BMW oil is provided for the duration of the warranty.
    Your dealer is telling falsehoods with respect to an aftermarket battery voiding your electrical warranty.
    WANG's Avatar
    North Carolina
    Jun 2007
    301 / 0 / 13 / 46
    What N4HHE said is my understanding as well.
    However, your dealer should give you a new (apparently prone to failure) BMW/Exide battery under that same warranty that they claim will be voided by use of a (likely better) aftermarket battery. When my original battery failed, the repairing dealer told me that the battery itself had a 2 year warranty.
    viper's Avatar
    Perth, Western Australia
    Feb 2007
    Had my first OEM Exide battery replaced after 10 months. The second has been playing up for a while with the dashboard rebooting after startup and cranking sounding decidedly ill. The replacement OEM Exide lasted about 2 years so I can't say that there was a problem with it but after reading this thread and checking out the cost of a replacement Exide I hunted for a Deka Power Sports AGM Battery and found the cheapest ETX14 online at Batteries Direct. At AU$143.20 plus AU$20 shipping from Sydney to Perth it was about AU$60 cheaper than buying accross the counter at Battery World in Perth. The Deka was delivered to my door 4 days after placing the online order. Can't comment on longevity or reliability but the Deka slipped straight in, cranking was very healthy and starting was within a few turns of the crank again.
    Like to share a good experience so have attached their website below.
    www.batteriesdirect.com.au
    BrENDURO's Avatar
    Brendan
    Greensboro, NC, USA
    1,128 / 0 / 265 / 162
    Deka would work for me. I've had one of their car batteries and didn't have any trouble out of it for several years.
    Brendan
    N4HHE's Avatar
    David Kelly
    Madison, AL
    Feb 2010
    '16 FJR1300A
    '09 FE450
    Quote Originally Posted by viper View Post
    Dekka is not Yuasa, but I believe the same applies. See item 4 on page 12 of Yuasa Tech Manual. Never mind the new battery happily started your bike, this initial low rate change serves to "break in" the battery.
    Item 6 on page 27 says the same thing. As does page 31.
    Several years ago someone from Yuasa launched an education campaign insisting that new batteries be charged for up to 6 hours before initial use. That otherwise failures as commonly cited here will occur and keep occurring. Have not been successful in finding documents tonight directly linking short battery life to improper "activation."
    Yes, the bike will charge the battery but the bike will not be kind. Yuasa states the initial activation charge current should be limited to 1/10th the battery's rated AH capacity.
    f800gecko's Avatar
    Land of the haircut
    May 2007
    1,749 / 4 / 101 / 208
    Make sure it will fit. I went with Yuasa because there was no jinking around required to get it in the space. In it went & never a problem since.
    “Do we behave reasonably well as a species? Or are we perhaps one of the mistaken evolutionary branches?" - Farley Mowat
  14. #12
    Rob's Avatar
    Points: 205,789, Level: 100
    Rob Werksman
    Pittsburgh, PA, USA
    Sep 2005
    5,186 / 3 / 158 / 851
    '90 K1
    '10 F800GS
    I'd just suck it up and snag a Yuasa or WestCo replacement. You know that it's going to fit and it's going to perform for years. The last thing (beyond a helmet) that I'd want to skimp on is a battery. If it fails, you're on the side of the road.
    Forum Owner Emeritus
    Rob Werksman - Owner, Motorcycle Insight, LLC
    F800 Depot | S1000RR Depot | Adventure Motorcycle Depot | Twalcom USA
    North American Importer - Globescout, Twalcom, [email protected], Hornig, AC Schnitzer (Motorcycle)
  15. #13
    Nashville TN kismetcapitan is offline Volunteer Moderator - F800S/ST, S1000RR
    kismetcapitan's Avatar
    Toby
    Nashville TN
    Nov 2007
    3,680 / 0 / 63 / 339
    '12 S1000RR
    '00 ST4
    '10 S1000RR
    '03 GPR80
    think I'm going to have to get some kind of battery. 10ah...my old Aprilia 2T bikes had a 9ah battery to save weight and to manage very minimal electronics. I'm beginning to kill my battery with the twin 55watt HIDs I'm running (dash resets now), so that doesn't bode well for the heated grips I plan to install this winter...
    2015 Ducati 1299S Panigale - red
    2014 Ducati Multistrada Granturismo - matte grey
    2011 Ducati 796 Monster ABS - red
    2007 BMW F800S - sunset yellow...Bumblebee! (sold)
  16. #14
    Flopp is offline F800Riders.org Supporter
    Flopp's Avatar
    Winnipeg, Manitoba, Canad
    Mar 2007
    1,106 / 0 / 4 / 70
    Heated grips on S1KRR?!?! What's next - a tape deck and foot boards? Just trade it in a on a Goldwing and be done with it. lol/
    ST - all options from the factory, sport panniers, stock screen Vario, "tank" mount Zumo, Throttlemeister, Stebel Nautilus, Hyperlites, Hyperpro fork springs, Centech AP-2, Evos, misc farkles and yes, it is Black and Yellow
  17. #15
    N4HHE's Avatar
    David Kelly
    Madison, AL
    Feb 2010
    '16 FJR1300A
    '09 FE450
    Quote Originally Posted by kismetcapitan View Post
    If you are killing your current battery with electrical loads you will kill any battery. If the alternator can not source enough power to drive your loads then the battery only temporarily band-aids your "deficit financing" situation. No matter how large your bank account it will be depleted if you spend faster than you earn.
  18. #16
  19. #17
    Aa3jy's Avatar
    Points: 1,125, Level: 19
    Clay
    On a boat somewhere
    Mar 2019
    '73 TR5T
    '05 Troyka
    '16 R1200GS ADV
    Yes I know this is an old post but was looking for a battery replacement info for my 2016 F800GT.. FYI..pulled out my oem BMW battery and it was made by Deka in Lyon Station,Pa.
  20. #18
    Points: 42,080, Level: 100
    4,123 / 0 / 9 / 3
    My suggestion is to find another battery of the proper size and not worry about the name brand. Batteries are commodity type items any more now. The name on the outside is different, but the insides are all pretty much the same. So I just look for the model number which seems to stay pretty much constant. Then I look for the most CCA (Cold Cranking Amps). Then I look at the price. High price does not equal more performance. Lastly, I look at customer reviews...especially the bottom rated reviews. You can quickly determine if the reviewer really knew what they were talking about and the battery or seller has issues...or if the buyer had issues and just doesn't want to take credit.
    I paid less than $50 for my last battery.
  21. Likesccramerusc liked this post
  22. #19
    Aa3jy's Avatar
    Clay
    On a boat somewhere
    Mar 2019
    '73 TR5T
    '05 Troyka
    '16 R1200GS ADV
    Can’t go wrong with either Deka or Yuasa both made here in Pennsylvania..probably make most of the re-branded batteries on the market..
    Picture of my BMW 2016 F800GT oem battery made by Deka
    https://ibb.co/vhBrFs0
  23. #20
    Randyjaco's Avatar
    Points: 1,267, Level: 20
    Randy
    Friendswood TX
    15 Hours Ago
    From the photo, I would say that only a very small part of that battery was made in Pennsylvania
    Probably glued it together and stuck on the lables and boxed it in PA.
    Randy
    2010 F800ST
  24. #21
    Points: 4, Level: 1
    Dec 2019
    So the dashboard rebooting after starting is not normal? Tnx in advance..
  25. #22
    Points: 590, Level: 11
    Germany
    This is my first gel battery. Hope I'm lucky! https://www.motorcycleparts-hornig.c...battery-2.html
  26. #23
    MGD109's Avatar
    Points: 2,811, Level: 34
    Lancashire
    Apr 2018
    Not sure how much difference it makes but the original battery is an AGM type not gel.The Exide AGM battery is this one:-
    https://www.ebay.co.uk/itm/EXIDE-AGM...72.m2749.l2649
    Article outlining the differences between gel and AGM:-
    https://www.batterystuff.com/kb/arti...el-vs-agm.html
    Sorley missed Honda TLR200
    Enjoy the ride
Similar Threads
  1. F800S Replacement battery
    By F800SofOZ in forum F800S & F800ST Discussion
    Last Post: 04-25-12, 06:53 PM
  2. Battery replacement under warranty?
    By flatulence in forum F800S & F800ST Discussion
    Last Post: 02-09-09, 12:24 PM
  3. Replacement Battery?
    By blackie in forum F800GS & F650GS Twin Modification Nation
    Last Post: 10-30-08, 04:51 PM
